Question about Sony HDR Video Cameras
Restore video hdd camcorder - HDR Sony Video Cameras
E 31 00 code comes
E:31:00 error code indicates problem with HDD in camcorder that is not working for some reason. Please check flexible ribbon wire is connected properly in HDD to main board and if its OK then HDD is bad and will be replaced to solve the issue.
Also, you can try a hard reset. Unplug the camera from power supply and remove the batteries. Restart it after 30 minutes. This should drain all the charges and reset the unit.
Also try reset settings. Look for reset/restore settings in menu. If dont solve it, please call Sony to check on warranty.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jan 04, 2012 | Sony Handycam DCR-SR42 Camcorder
Tip
MOD Files on Mac OS, How to Play Camcorder MOD Files on Mac
Similar to TOD, MOD is a kind of recording format being used in digital tapeless camcorder like JVC, Panasonic, Canon. MOD video format is comparable to XDCAM EX, HDV and AVCHD.
MOD is used exclusively for standard definition video files, while TOD is used for high definition files. Both MOD and TOD are file-based formats that are stored on a random-access media. Directory structure and naming convention are identical except for extensions of media files. Standard definition video is stored in MPEG program stream container files with MOD extension; in most other systems these files have extension MPG or MPEG.
The following list is about JVC, Panasonic, and Canon MOD camcorders.
JVC MOD camcorders
* 2004: GZ-MC100 (SD), GZ-MC200 (SD)
* 2005: GZ-MG30 (HDD), GZ-MG70 (HDD)
* 2006: GZ-MG37 (HDD), GZ-MG77 (HDD), GZ-MG505 (HDD, SD/SDHC card)
* 2007: GZ-MG130 (HDD), GZ-MG155 (HDD), GZ-MG255 (HDD), GZ-MG555 (HDD, SD/SDHC card)
* 2008: GZ-MS100U (SD/SDHC card)
* 2008: GZ-MG7230 (30 GB HDD, MicroSD)
* 2009: GZ-MG630 (60 GB HDD, MicroSD), GZ-MG670 (80 GB HDD, MicroSD), GZ-MG680 (120 GB HDD, MicroSD)
Panasonic MOD camcorders
* 2003: SV-AV100 (SD card)
* 2005: SDR-S100 (SD card)
* 2006: SDR-S150 (SD/SDHC card)
* 2007: SDR-S10 (SD/SDHC card), SDR-H18 (HDD, SD card), SDR-H200 (HDD, SD/SDHC card)
* 2008: SDR-H20 (HDD, SD/SDHC card), SDR-H60 (HDD, SD/SDHC card)
* 2008: SDR-S7 (SD/SDHC card)
* 2008: SDR-SW20 (SD/SDHC card)
* 2009: SDR-SW21 (SD/SDHC card)
* 2009: SDR-S26 (SD/SDHC card)
Canon MOD Camcorders
* 2008: FS100 (SDHC), FS10 (SDHC), FS11 (SDHC)
* 2009: FS200 (SDHC), FS21 (SDHC), FS22 (SDHC)
For Mac users, when they want to watch MOD files shot by JVC, Panasonic, Canon camcorder with iPad, iPhones, iPods, in Quicktime, in iMovie, in iTunes, or on PCs, etc. They may be annoyed that how to upload MOD files to Mac and play MOD video on Mac OS.
Now, there are tutorial and guide for you below will help you solve these problems.
1. Connect your JVC, Panansonic, or Canon camcorder to your Macs or PCs with cable USB or Wifi.
2. Turn on your camera and select the mode of camcorder like PC mode. iMovie on Mac will open automatically the Import Window.
3. You can review your video or select "Import All"and select your JVC, Panasonic, or Canon camcorder on the computer screen and click "OK."
4. All camcorder MOD videos will have the file extension "MOD" Once the backup is complete, then close the program.
After uploading your camcorder MOD files to your PC or Mac, you can use
a MOD Video Converter for Mac to convert MOD files to Mac firstly, and then you can play JVC, Panasonic, or Canon MOD files on Mac. More information about how to convert MOD files on Mac and edit MOD files on MacOS you can click here.
on Sep 13, 2010 | Computers & Internet
Tip
How to Upload/Put and Play JVC, Panasonic, Canon Camcorder MOD Files on Mac
JVC MOD camcorders
After uploading your camcorder MOD files to your PC or Mac, you can use a MOD Video Converter for Mac to convert MOD files to Mac firstly, and then you can play JVC, Panasonic, or Canon MOD files on Mac. More information about how to convert MOD files on Mac and edit MOD files on MacOS you can click here.
on Aug 12, 2010 | Computers & Internet
E 31 00 code comes
How do you get rid of movie disabled on a sony video camera
The movie recording error message indicates that the Camcorder is not in a position to record videos. It may be due to shake, free space, corruption in the folder structure, bad sectors in the HDD.
Please follow the below steps and check the operation. Each step is a possible resolution, so please perform one by one and check the operation.
  • Place the Camcorder in a steady surface and press the record button.
  • Please press the reset button on the Camcorder and check if that helps.
Make sure that you have turned ON the Camcorder while pressing the reset button.. You can locate the reset button from the below figure.
  • If the issue persists again, format the HDD of the Camcorder and check the operation.
To format the HDD of the Camcordeer, you can use the HDD FORMAT option under the HDD set
Note:Formatting the HDD will erase all previously recorded videos and images from the Camcorder.
I hope this will resolve the issue
Jan 27, 2011 | Sony DCR-SR60 30GB PAL Handycam Digital...
How do you restore deleted movie files on your computer?
try opening your recycle bin and restore files which you deleted recently
May 22, 2009 | JVC GZ-HD3 HDD HD Camcorder - 60 GB USB...
Restore deleted movie files
It is still possible however you need to call a company to do it for you.
One example is drive savers
www.DriveSavers.com
Oct 31, 2008 | JVC GZ-HD3 HDD HD Camcorder - 60 GB USB...
Media recovery
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Feb 19, 2008 | Sony Handycam DCR-SR40 Camcorder
Video Cameras Logo
21 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
