Question about KitchenAid KFCO22EVBL - French Door Bottom Mount Interior Dispensing
My Kitchenaid French door fridge's water filter
My Kitchenaid French door fridge's water filter won't rotate. The filter is inside the refrigerator not at the bottom. Any ideas please?
    Scholar:
  • 50 Answers
If I remember correctly it requires a quarter to half turn to disconnect in the counter clock wise direction. May take some grunt to free it. If that fail try channel lock pliers and be careful to not break it. once turned it should pull straight out. Try that as maybe its not twisted into place properly to start and just needs to be pulled straight out.
Posted on Oct 13, 2013
Testimonial: "I very much appreciate the suggestion, unfortunately, it didn't work. We tried the pliers. I think I'm just going to have to call a repairman tomorrow. Thanks and, if you come up with any more suggestions, we'll try them."
  • 1314 Answers
SOURCE: Water Filter Kitchenaid Superba...Where is it??
look for a round peice on the kickpanel at the bottom of the unit it twists and slides out
Posted on May 13, 2008
  • 4 Answers
SOURCE: Hissing noise in freezer
When you observe this is your compressor quiet? Then most likely your refrigerator is in defrost mode. The water is coming off the evaporator (think of a very cold radiator) as the defrost heater element warms. This element is similar to the electric heating element in the bottom of your electric oven. the water hits it and it will hiss. This is part of the normal operation of a refrigerator. The defrost cycle usually lasts from 20-30 mins and will occur 4-6 times a day. If you are having trouble with frozen food melting then re-freezing, or the temps are on the warm side, you might need to have your defrost timer or defrost termination switch looked at.
Posted on May 26, 2009
SOURCE: Kitchenaid fridge #KSCS25INSS hot door frame
how to change the waterhose my Kitchenaid fridge #KSCS25INSS
Posted on Sep 12, 2009
  • 12 Answers
SOURCE: How do you replace the water filter on a
under the freezer door there is a nob like thing. turn it and pull on it. instead of replacing it, rinse it out under runing tap water and put it back were you removed it from and push the fridge light botton 5X in a row
Posted on Oct 19, 2009
machinetech7
  • 1344 Answers
SOURCE: 15 month old Kitchenaid french door refrigerator - water pooling and freezing on the bottom of tthe freezer. Seems like the grids on back wall may be the culprit, as after ice is removed they seem to
more than likely you have a clogged drain. This occurs when the machine goes into defrost and the melted ice somehow is prevented from draining and therefor refreezing and blocking the drain for the next defrost cycle. Over time it gradually builds and starts voer a larger area. Being you have a top mount refrigerator(freezer on top) there are air ways that connect the freezer to the fridege, which is how its cooled. The best way to resolve this is to unplug the machine for atleast 24-48 hours to let all ice melt
If thats not an option that you want to use the actual repair method would be to 1) unplug the machine 2) empty everything out of the freezer so you'll have room to work 3) take all the shelving and baskets out 4) locate the screws on the rear wall inside the freezer and remove them 5) take the back panel off exposing the evaporator coils ( the aluminum ) 6) directly below the coils is a trough of sorts and the drain is usually in the middle and runs out the bottom, remove the ice by carefully chipping it out or by using a hair dryer or hot water. 7) once all the ice is gone, the drain is visible and water can flow smnoothly down the drain dry the area and reassemble.
Note that on your machine you should pull the machine away from the wall so you can get behind it and remove the lower panel. Locate the drain tube that runs from the freezer, usually a black or white tube, and at the end verify it there is a rubber piece that looks like a duck bill of you will. If it is there, grab said piece and remove it from the drain line. This is the cause of the water not draining out of the freezer
Posted on Jun 20, 2012
KitchenAid KBFA25ERSS01 I replaced the water
if its computerized make sure someone didnt turn icemaker off check to make sure its in all the way
Oct 27, 2013 | KitchenAid KBFS25EVMS Stainless Steel...
How to change the water filer on a rf4267hars 25.5 ft
You must shut the water valve to change the water filter. If you don't havewater valve near the fridge, shut the main water valve for few minutes. If you turn the water filter to change without shutting the water valve, lots of water flooring the fridge and you do lots of work to remove the water inside the fridge. Shut the water valve, and then replace the filter. Then turn the water valve.
Apr 02, 2013 | Samsung RF4267HARS 25.5 Cu. Ft. French...
How to remove water filter do i have to rotate it or just pull it out
Open the door, this shuts off the water supply to the filter reach in and turn the filter counter clockwise a 1/4 to 1/2 turn and pull the filter down. Replace filter the same way, close the fridge door and away you go! Takes about thirty seconds to complete.
Oct 14, 2012 | KitchenAid Superba KSRG25FK Side by Side...
How do I remove the water filter cartridge in order to replace it?
On the link belwo page 14 and 15 will tell you how to replace the water filter. If this is not your fridge please give the correct make and model # so I can get you the right info.
http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%2012828140.pdf
Jun 01, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Icemaker fill leaking on new LG LFX28978SW french door refrig
Do you have the "dummy filter plug" installed and not the actual water filter in the upper left of the inside of the fridge?
Jul 01, 2010 | LG Refrigerators
No water to ice maker or water dispenser
You have a bad water valve . It needs to be replaced.
Jan 23, 2010 | KitchenAid Architect® II KBFS20ETSS...
Our new Samsung fridge has horrible tasting water
add water filter system to the unit ..
if it is not the water from the unit that bad then filter change might need to be done...or a new filter need to put inside.
Dec 30, 2009 | KitchenAid Superba Architect KSCS25INSS...
Spilled milk inside the fridge ends in the catch tray
The pan is for holding the defrost water for it to evaporate. If the milk creates an odor, you can acces the pan by removing the front panel under the door (usually). The pan will probably come out so you can clean it.
May 06, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
KitchenAid KFCO22EVBL - French Door Bottom Mount Interior Dispensing Logo
88 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
