Question about Directv Televison & Video
Receiver humming the reciever wont turn on, and humms on and off like: woosh....woosh...woosh. any ideas on how to fix it so i can watch some tv?
    Master:
  • 359 Answers
Have you tried unplugging the Receiver from the power outlet and plugging it back in? Is your Receiver a service providers set top box DVR? It sounds like you may be hearing the Hard disk drive spinning on and off. But that's all I can tell from the description. Hope this helps.
Posted on Oct 13, 2013
2 Suggested Answers
SOURCE: Iomega Screenplay buzzing no Disc wont bring up Folders
I have a Screen Play HD. It was working fine until today when suddenly all my computers can't detect it. I tried a different external disk, it worked fine.
Posted on Sep 14, 2010
My RX-530 Reciever has a humm internally. What is it?
The innards of this device use Direct Current. Your outlets provide Alternating Current. To convert one to the other, we need to first run it through a transformer. Same exact principle as the big can on the power pole next to your house (or the box, if you have underground utilities in the area). A slight hum from the case itself is normal. If it gets loud and annoying, or is being heard through the speakers, then that's a sign of larger problems, and needs to be shut off and looked at by a technician before things get worse.
Oct 13, 2014 | Audio Players & Recorders
My Harman Kardon 300B receiver has a humm in the left channel. What should I check first? Any ideas would be greatly appreciated!
Isolate it to a source if possible; make sure none of your cables or speaker wires run by power cords or sources of high magnetic fields. I had hum caused by track lighting.
Jul 03, 2010 | Audio Players & Recorders
Hi, I have a Yamaha RX-V596 that all of a sudden developed a hum throughout ALL speakers, it is coming from the receiver. Any idea how to fix it? Thanks, Adam
reconnect all wires (make sure are placed in correctly) and make your connection with wires kind of tight (no druppy wires if extra coil it up) between devices....your receiver should have small wire hanging this is the antenna and the other wire should be grounded...and should take care of the humm....
feel free to rate the help
Jun 12, 2010 | Yamaha RX-596 Receiver
YAMAHA HTR 5560 KEEPS TURNING OFF
sounds like you have the polairity reversed on the speakers
and yes it does make a difference
check polairity also make sure unit is well ventelated
you wouldnt use your compouter if it was inside a card board box
so make sure the reciever can breath also
recievers get too hot and they start blowing chips off the board
Jul 25, 2009 | Yamaha HTR-5560 Receiver
Jul 06, 2009 | Iomega ScreenPlay
Yamaha sourround sound reciever HTR 5920- not working
Can you remove connection between the receiver and TV and then try ? If it still turns hums and turns off, then try disconnecting all the speakers and power it on. If it still turns off, then you have a bad receiver...Let me know..
Mar 20, 2009 | Yamaha 5.1-Ch. Surround Sound Home Theater...
Humming sound on cable setting
have you tried to input another audio source into the audio inputs on the reciever that the cable box outputs are going into on the reciever ?
you may also need to ground the recievers frame and cable box frame to earth ground.
you also may have a bad connection in the wires or jacks for the audio connections
or the cable box audio out circuit needs repair
Feb 04, 2009 | Onkyo TX-SR606 Receiver
Connection a JBL surround cinema speakers with sub to a Yamaha
if you do not have the digital hook up from the tv to the reciever
304c659.gif then you will not get the subwoofer sounds or the dolby digital sounds
if you don't have this on your tv then just turn off the dolby digital when watching the tv , and you should be able to hear the subwoofer thru the virtual surround sound
hope this info is worth a fixya and if you need other help then just ask me and
i'll be glad to help
electech
Nov 23, 2008 | Yamaha HTR-5850 Receiver
Acoustimass Subwoofer has a low "hummm" sound when turned on.
Sounds like an inadequate ground wire in the signal cable. You may have to replace the cable between the reciever and bass module. It also, however, may be IN the bass or reciever module.
Aug 04, 2008 | Bose Acoustimass 15 System
Televison & Video Logo
50 people viewed this question
Top Directv Televison & Video Experts
john milligan
rundiggity
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
