Question about Cobra Radio Communications
Cobra microtalk PMR300 shows "Err"
When pressing the PTT, the display shows "Err". The set does not work. Even a reset (Function+turn on) does not help
    Top Expert:
  • Cobra Master
  • 2,931 Answers
zeusfaber
  • 247 Answers
SOURCE: Brand New Cobra microtalk won't work!
Double check against all the instructions - in particular, make sure the batteries are charged according to "before first use" spec, that the volume is turned up, and that the squelch (if fitted and not automatic) is adjusted properly. If it still doesn't work, take it back to Wal-Mart. If the product doesn't work, there's no need for the packaging to be in good condition - it's not as if they'll be needing it to resell the goods to anybody else. A.
Posted on Apr 08, 2007
Neto
  • 123 Answers
SOURCE: One way comm only
swap batteries if does not work this unit should need repair or replace, display blinking can be produced for power failure ( battery, contacts, circuits) or can be a controller issue.
Posted on Feb 14, 2008
Gavin93
  • 66 Answers
SOURCE: Cobra microTALK PR 3500-2 DX VP 2-Way
The Cobra microTALK PR-3500-2 DX VP Radios are supposed to be equipped with acoustic noise filters that are built in the microphone. This problem could have been caused from the radios getting wet, damaged, or the microphone going bad, the microphone can be replaced if you still have the warranty, but if you want to save money you may wan to get a new set of 2-ways. I suggest the Uniden GMR325-2, these models are inexpensive and have an approximate 5 mile range in good conditions.
Good Luck!
Posted on Jul 05, 2008
  • 14 Answers
SOURCE: Constant RX mode on cobra microtalk PR3850WX
Sounds like the radio was subjected to electrostatic discharge. If you have your manual, and it describes a way to do a "master reset" on the radio, follow the instructions. This usually involves pushing down on one key while turning the radio on. Otherwise you have to find a licensed dealer for factory service, as there is no way to repair the radio yourself. The use of surface mount technology still confuses many Techs unless they have been to a company's two or three week seminars.
Posted on Jul 24, 2009
BillB-SA
  • 2761 Answers
SOURCE: we have lost manual for cobra microtalk walkie
I couldn't locate your specific model, but all of the Microtalk series radios seem to be basically the same as far as operations. Follow the link below to a manual that you can download/print -- it should work fine with your radios:
http://www.cobra.com/downloads/manuals/PR4000WX_manual.pdf
Bill B
Posted on Apr 18, 2010
Cobra microtalk
Try having a look at the manual on how to turn off VOX or change the sensitivity of the mic ok
Jun 27, 2014 | Radio Communications
Loud crackling noise
The monitor function is turned on, on the unit that is noisy.
The manual describes the procedure for setting the monitor function the manual is available here.
https://www.cobra.com/support/product-manuals
May 11, 2014 | Cobra Microtalk 100 FRS Walkie Talkie...
How to use radio in my walkie talkie
press & hold "mode" then use the channel up & down button until you hear it, depress the PTT to return to normal
Apr 19, 2014 | Cobra Microtalk 100 FRS Walkie Talkie...
How do i turn off the beeping from cobra microtalk 2 way radio
  1. Press the menu button to scroll through the features.
  2. When it says "set roger beep on/off" press the up or down arrow to turn the roger beep off.
  3. Now press the talk button to return to stand by.
  • If you have any comments please feel free to leave them here.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Oct 14, 2011 | Cobra Electronics microTALK® PR 3850 WX ...
E004 (IR 400)
This is the error for the temperature of the fixing assembly not being detected or getting too hot. The thermisitors will most likely have to be replaced. First try resetting the error by pressing the additioanl function key, then press the 2 & 8 keys at the same time and then the additional function key again. The display should show COPIER - press this to highlight and the display show then show a series of keys at the top. Press FUNCTION, then CLEAR, then ERR, and then OK. Turn off the copier and turn back on again. This resets the error and if the error comes back up again then the parts will have to be replaced. Good luck.
Jul 27, 2011 | Canon imageRUNNER 400S Copier
One of my Cobra Microtalk radios is stuck on RX. Everything else seems to work. What could be the problem?
Hi!
Almost always, the problem here is that the micro switch for the Push-to-Talk (PTT) button has failed. Your radio should have a warranty, but even if the warranty has run out, it isn't horribly spendy to fix. I'd get in touch with Cobra Electronics, I have heard they're extremely helpful. Try this link and good luck!
https://www.cobra.com/help/
Jul 05, 2011 | Cobra Electronics microTALK® PR 3850 WX ...
Cobra microtalk Pr 17 OC
Dear sir,
Open the unit & check PTT switch check it by manually closing the circuit ..it will come in tranmission mode .i think ur PTT switch is out of order & nothing else .
Regards
Raj
Dec 11, 2008 | Cobra MicroTalk PR 1100 WX (15 Channels)...
Transmitting
Hello lstimpson,
You may have the CTCSS privacy code function enabled on one radio and not on the other. This function keeps your radio's received muted unless it receives a signal from another radio using the same privacy code. If you have Privacy Codes set for radio A but not for radio B you will still be able to transmit from A to B but when you transmit on radio B your signal will not be heard on radio A.
Make sure that both radios are set to the same privacy code or that the function is turned off on both radios.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 19, 2008 | Cobra MicroTalk PR 1100 WX (15 Channels)...
Radio Communications Logo
26 people viewed this question
Top Cobra Radio Communications Experts
Steve
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
