Question about Cameras
I have couple of XD cards which i formatted on my computer and now they won't work in my Fijifilm z10fd camera anymore. I gather that his is because I should have formatted them using the camera rather than the laptop. Is there any way to make them work again ? (some forums have suggested I reformat them using the camera but I can't do this because the camera doesn't recognise there is a memory card inserted and so only gives the option of formatting the internal memory. I also have other XD cards which have not been formatted (in my laptop or otherwise) and since inserting the laptop formatted cards, these aren't recognised either. I've 6 cards in total - help!
    Sergeant:
  • 305 Answers
The only thing I can suggest is that you try formatting them on PC again, but choose different format option. I think you can choose between 2 formatting options NTFS, and FAT32, but if cards are un-usable anyway try both settings and see if this helps.
Posted on Oct 18, 2013
pishta68
  • 593 Answers
SOURCE: Olympus Digital camera memory card problem.
clean the contacts with a pencil eraser gently, or use a little alcohol on a q-tip. The cards are pretty tough, but are not designed to be removed hundreds of times, can you use the USB cable? Clean and format. If the card has irreplaceable pics on it, you can use card recovery software available on the net.
Posted on Mar 24, 2008
SOURCE: Format Error in Sony Cybershot
there is no tools feature on the sony...select the 1st button lower right...all touch screen features appear...select menu in lower
left...select setup...camera 1 will display...select down arrow
twice until you reach format, the select...that should reformat
the memory...
Posted on Apr 07, 2008
SOURCE: 8GB SD card not working in Fuji Camera
switch around the 8gb memory card
i had the same problem
Posted on Aug 05, 2008
Steve5
  • 423 Answers
SOURCE: OLYMPUS XD Card - CLEAN or FORMAT - and not reading in computer
Your 2gb xd card would be of the "M" or "H" designation, which is a new type of card which is not always compatible with many cameras and card readers. If the other cards that work are not H or M cards, that is most likely the problem
Posted on Jul 03, 2009
  • 11967 Answers
SOURCE: Got the dmc-ts1 couple of weeks ago, can't read SDHC cards
The card needs to be formatted in the camera to work properly.
Posted on Sep 07, 2009
Purchased 8GB fijifilm card for A330 and can't insert it
The A330 uses xD Picture Cards, which top out at 2GB. Your 8GB card is some other type (most likely SDHC) which will not work in the A330.
Oct 25, 2012 | Fuji FinePix A330 Digital Camera
My Fujifilm 128MB XD card shows 'Read error' when inserted into my camera, but the photos will display on my computer - HELP!!
If you have rotated the images on your PC, you may find that your camera is not able to process the images correctly.
If not, try backing the photos up onto computer, format the XD card and then try copying the pictures back if you need to have them on the camera.
Feb 28, 2011 | Fuji FinePix Z10fd Digital Camera
Photos I want aren't on my xd card but on internal memory????
You'll need to install the software that came with the camera onto your computer then connect the camera with the USB cable that came with it to your computer. The software will start when it senses your camera is connected and you'll be able to access the camera internal memory. Otherwise, you can copy the internal memory contents to the memory card from the camera itself from the menu system.
Feb 04, 2010 | Fuji FinePix Z10fd Digital Camera
Cant get pictures off camera
You need recovery software to access the pictures.
This is free for private use:
http://www.pcinspector.de/Sites/file_recovery/info.htm?language=1
You can't use the software with the camera directly, so you also need a card reader that can read XD or SD/HC cards, depending on which type of memory card you are using in the camera.
Install the software on your computer, connect the card-reader to the computer, put the memory card in the card-reader and run the program. Follow the instructions in the program.
When images are successfully downloaded to the computer, you will have to format the card in the camera.
Oct 24, 2009 | Fuji FinePix Z10fd Digital Camera
Internal pics
if it's just seen on the XD card, then those pics were not saved in the internal/built in memory of the camera. Anyway, if you want to delete pics in the XD memory, just insert it in the card reader of your computer then just delete the pictures or format the memory card.
cheers!
Jul 11, 2009 | Cameras
Format-less
put it back in the computer and try to format it there.
Jun 14, 2009 | Olympus Camedia C-350 Digital Camera
Olympus xd card formatting problems.
If you like the camera and XD cards then I would use the USB cable to download the photos from the camera. When you plug the USB cale into the camera and then into the computer, the computer should recognize the camera and set it up as another disk drive. Copy or move the pictures from the card to your Photo location. Use the "Safely Remove Hardware" icon in the system tray to disconnect the camera and your done. The camera can format the XD card and the computer can read it through the camera.
May 28, 2009 | Olympus FE-340 Digital Camera
Card error
TRY TO FORMAT THE CARD INTO YOUR PC, USING A MEMORY CARD READER.
Aug 16, 2008 | Fuji FinePix Z10fd Digital Camera
Xd memory card
A card access error may indicate that an xD-Picture Card memory card is in a write-protected condition. xD-Picture Card memory cards have a special protection feature to ensure that your pictures are kept safe. NOTE: During this condition, you can still use the printer for printing and saving photos from the xD-Picture Card to a secure location, such as the computer hard drive. To resolve this error, try the following:
  • Reinsert the xD-Picture Card memory card into your camera and turn on the camera. In most cases, the camera automatically makes the necessary changes.
  • Reformat the xD-Picture Card memory card. See the documentation that came with your camera for instructions on reformatting the memory card. Note that this process erases the pictures currently saved to your memory card. To save these pictures, transfer them to the computer before reformatting the memory card. Once you reformat the memory card, transfer those photos back to the memory card using the computer.
Jul 29, 2008 | Fuji FinePix Z10fd Digital Camera
No Image
Please read these/the 2 posts that I posted prior for a similar XD mem card problem, as I firmly believe you are "formatting" your mem card improperly using your home computer instead of "formatting" the card on your camera.
Also the XD type card & size are very important also!!
What you will have to do is read and download the photos you have on that XD card using the same "card reader" you used before and then properly "re-format" that card in your "CAMERA ONLY". This should solve your XD card problems.
PRIOR POSTS:
Kristina,
Not knowing what model Olympus camera you have, or how old it is - your new memory card "format" problem is one of 3 possibilities.
1st - If you have an older Olympus camera more then 4-5 years old the newer M & H series type cards over 256mb will probably not work in your older camera, as by the camera's internal firmware chip design of the camera itself. Some cameras were upgradeable some weren't as to the internal firmware chip as well as available software drivers depending on which computer OS system you were using ie: (WIN98SE, WIN2000, etc). Has to do with the memory card read/write chip speed as well, and also has to do with the physical storage size of the card itself. Some digital cameras were MAXED OUT at 512mb cards, some as low as 256mb. A 2gb card simple won't work in that/your camera in that case.
If you read the camera's user manual it will possibly tell you this, or else go online to www.olympusamerica.com and use this link:
View which cameras are compatible
Select camera model series and scroll down the model # and research the max card size & type you can use (3 basic XD card speed types available - regular XD - M type - H type).
If you are using the wrong type & size card you will need to return that card (if you can) and get the right XD size & type for your camera.
2nd - You should always FORMAT (same as ERASE ALL and FORMAT modes on most Olympus cameras) the new card, or any XD card for that matter in your camera itself. NOT THE HOME COMPUTER!!! The 2 format procedures are not the same!!
If you are re-shooting (re-using) the same XD card over and over again and then downloading the JPEG pix directly to the computer using a USB interface cable there usually is no need to re-format the card again as long as the XD card stays the camera and is not downloaded into a home computer via a "card reader". If you do the latter "card reader" then I would advise doing a card re-format in the camera again just to be safe!!
And lastly - If your home computer recognizes the XD card via a good "card reader" (do not FORMAT the XD card here btw, as you are just checking the card out to see it is GOOD is all), but the camera will not then that is a good sign your camera is OK, but it's just the wrong type & size XD card.
Hope this helps solve your camera XD problem not knowing which model you have.
Best regards,
Frank
AND:
Follow up to previous post:
I didn't have the time to access the exact link below to check on your specific 2004 model year camera because I missed the Fuji camera model part, as I'm brand new to this site - so please forgive my previous oversight here.
I was right though in my initial posted assumption that you bought the wrong XD memory card based on your Fuji FinePix A330 Digital Camera - as to it's older model year - in that your camera is limited to a 512mb memory card.
Make sure you buy the 512mb standard card if you still can find them. Otherwise check with Fuji Corp to make sure the M type card (faster read/write chip) will work in your specific model. The M type cards work just fine in my Olympus C-740 even though it was told to me they wouldn't work at all, but each digital camera is slightly different as to it's internal firmware (BIOS) chip.
See the following camera info for your specific model at the link below under Storage Media:
Steves Digicams - Fujifilm FinePix A330 - User Review
I hope this now clears up any prior confusion from the previous post.
Best regards,
Frank
Feb 06, 2008 | Fuji FinePix A330 Digital Camera
Cameras Logo
27 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
