Question about Acer Computers & Internet
Lights dimming - Acer Computers & Internet
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 156 Answers
Ussally this is caused by a bad connection to the power adaptor a good way to find out is if it does it without the power adaptor while using just the battery
Posted on Oct 14, 2013
The dashboard illumination is dim and won't go bright also the Foglights will not turn on and also the stereo is dim. Changed the light switch but still the same
is it adjusted by the light switch left on bright right dim all when lights are on all dash lights will dim thats normal
Apr 19, 2016 | 2008 Volvo XC90
The light is dim with the door open or closed running.whats wrong?
Lights lowering in the kitchen when turning on microwave ...
diy.stackexchange.com/.../lights-lowering-in-the-kitchen-when-turning-o...
Nov 4, 2012 - Lights lowering in the kitchen when turning on microwave oven: symptom of an ... In the best case, this may be normal if the dimming is minor.
Possible causes of dim Microwave Oven display ' All About Circuits
forum.allaboutcircuits.com > ... > Electronics > General Electronics Chat
Jun 13, 2013 - I've seen some Microwave ovens that will not display a backlight anymore. They still work, but the display is so dim, you have to be inches away to. ...Monitoring the output of a light-dependent resistor, or photoresistor, allows ...
What Is Causing My House Lights To Dim?
blog.1000bulbs.com/what-is-causing-my-house-lights-to-dim/
Dec 21, 2015 | Microwave Ovens
Light is dim
Why do my lights in my house dim when I use the Microwave or dryer ...
https://answers.yahoo.com/question/index?qid...
Jan 16, 2010 - I dont run a lot electricity. It seems that if I run something like themicrowave any lights that are on dim. Is something wrong here? I dont see why ... Light on microwave too dim to read -- can it be fixed? ' Yahoo ...
May 11, 2014
My lights dim when I turn on a powerful electrical device ...
Dec 31, 2007
Why causes all the lights to dim and then brighten repeatedly ...
Dec 28, 2006
More results from answers.yahoo.com
Dimming Microwave Light - Breville Support
brevilleusasupport.com/bmo734xl/dimming-microwave-light/
Apr 10, 2014 - Occasionally, when using power settings that are lower then the normal 100% cooking power, the light inside the microwave cavity may dim.
The indicator light on my FFAA52P fridge freezer has gone dim any answers
I have had a similar problem my light is very dim after contacting manufacturer I was told if the fridge freezer is still working fine then just put up with the dim light.
Feb 04, 2015 | Refrigerators
What would cause instrument and radio light to dim
With the lights on auto, the dash will dim when the lights go on, based on the dimmer setting. If it's set low [wheel] they will be really dim. If it's light outside it will be hard to read. there are not many other causes other than a low battery or bad alternator.
Jul 29, 2014 | 2004 Buick LeSabre Custom
2005 buick lacrosse cxl... dash lights and interior lights are going dim to bring to dim to bright very rapidly
First, check that the battery connections are clean and not corroded. If not look for the ground wires that connect to the chassis. Check to see if any are corroded or loose. Finally if that has no effect, you have a short somewhere in your wiring. The easy way to isolate it is to pull the fuses for each device one by one and see if the dimming stops. The last one to cause the dimming is the problem. If it happens when you hit a bump it also might be a ground fault in the interior car grounds....good luck!
Jan 02, 2013 | 2005 Buick LaCrosse
Gmc envoy bright lights work dim lights will not work
Your circuit lights may be bright or dim according to how your electrical system was set up. It may dim when lights are off and get bright when lights are on. ------------------------------------------------------------------------------------------
Car Diagnostic Tools
Nov 24, 2012 | Buick LaCrosse Cars & Trucks
Brake lights work but are very dim
It can be loose wiring or issue with bulb or the battery is weak or brake light socket getting short somewhere.Car lights getting dim,there are many such common issues noticed.I will share some familiar help links,related to your problem.
Click the link below:---2004 Dodge Ram: High Beam Light is DIM? http://technoanswers.blogspot.in/2012/04/2004-dodge-ram-high-beam-light-is-dim.html
----------Ford Odometer Dims intermittently http://schematicsdiagram.blogspot.in/2012/07/ford-odometer-dims-intermittently.html
---------Turn Signals Don't Work When Brakes Are Applied? http://schematicsdiagram.blogspot.in/2012/04/2005-gmc-envoy-turn-signals-dont-work.html
Brake light Switch Location? http://schematicsdiagram.blogspot.in/2012/04/1996-buick-regal-gran-sport-brake-light.html
----------- No brake lights on Buick? http://schematicsdiagram.blogspot.in/2012/04/no-brake-lights-on-buick.html
----------- Brake lights not working on 1989 BUICK REGAL? http://schematicsdiagram.blogspot.in/2012/04/brake-lights-not-working-on-1989-buick.html
These will help.
Thanks.
Nov 06, 2012 | 1999 Ford Contour
Computers & Internet Logo
12 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
