Question about Palm m515 Handheld
Palm m515 When I use the stylist it will not work where I push I reset and it still did not work
  • 736 Answers
You need to recalibrate the touch screen ..
touch the "Home" button a few times until you get "system" in the top right corner .. then select "Welcome" .. that will let you calibrate the touch screen and set the clock/calendar ..
Posted on Oct 07, 2009
I was given a pilot m515 and i do not know anything about it. no instructions. i need to know how to turn it on and also, the slot where a "card" might go is empty. please help or steer me in the right...
hi betty .. the m515 is a nice machine still, and worth getting to know .. the card slot is for storing extra things its not needed to run the m515 ( you can put in an SD card if you want to store a lot of stuff but the m515 has lots of memory inside already ... you can charge the battery or run the unit on the charger ... push the top right button and the unit should come to life .. if you hold the on/off button for a few seconds then it will turn on or off the display backlight .. if the unit fails to start then you can do a "reset" .. that will reboot the machine and fixes most problems.. the top of the stylus unscrews .. this gives you a small probe that can be used to reset the machine .. on the back near the top is a hole marked "reset" .. poke the probe in there to reboot the palm ... if you want to do a "hard reset" (erases all data) then hold the power button in while you poke the reset .. that will give you a choice to "erase everything" .. if you chose to do that then you would be starting the palm like it came out of the factory .. all phone numbers and such would be erased ... that should get you going .. there is a tutorial included in the palm that can get you started .. if it works on the charger but not on the battery or if the battery goes dead quickly then new batteries are not expensive but you need a really small torx tool to get the back off to change it .. you can take it with you to the hardware to match it up with one .. if the battery is ok then you should be enjoying you palm about now ..
Sep 30, 2009 | Palm m515 Handheld
How do you turn on the Palm m515
the palm m515 has a button at the top right corner .. hitting the button quickly will turn the unit on or off ... holding the button for 2 seconds will turn the display backlight on or off ... if the unit fails to start then you can do a reset .. thats like a reboot .. the top of the stylus unscrews ... that gives you a little probe that you can use to push the reset button on the back top center ... if the battery is bad you can still run the machine with the charger hooked up ..
Sep 29, 2009 | Palm m515 Handheld
Do I need software to sync my new palm m515 with my laptop pc?
HI,
Yes you will need to install the Palm Desktop software on your computer or your laptop. Here is a link to the Palm Support site where you can download the software that you need. If you need any other help please let me know. Best wishes.
http://kb.palm.com/wps/portal/kb/na/m-series/m515/unlocked/downloads/page_en.html
Aug 09, 2009 | Palm m515 Handheld
My palm pilot m515 wont turn on or charge
try turning it on while its on the charger .. if that works then you might need a new battery .. if it doesnt then do a "reset" ... unscrew the top off the stylus and use it to push the reset button on the back (top center) ... if that doesnt get it going then you can do a hard reset but that will erase all your information (like telephone numbers and such) ... you do a hard reset by holding down the on/off button while pushing the reset .. if it works on the charger but quits when on battery then you need a new battery ..
Jun 27, 2009 | Palm m515 Handheld
M515 Palm Pilot
here is your manual in PDF form
www.palm.com/us/support/handbooks/m500series_ug.pdf
if the unit was new then you would charge it for about 10 hours .. but since its not likely new then it doesnt hurt anything to just leave it on charge ... you can even operate the palm while its charging .. over night charge should be enough to get pretty close to full ... the palm internally automatically turns off the charge when the battery is full .. so you dont have to worry about over charging .. if the unit wont come on then you can do a "reset" (back at top)
Apr 01, 2009 | Palm m515 Handheld
Softwares required
Sorry, but Palm is not providing an upgrade (at least for the M515 model) to a newer Palm OS (from the 4.1 that you already have). Palm is not known for supporting older products (yours dates back to about 2002).
As for bluetooth - the unit does have an SD card slot, and there are SD Bluetooth adapters made, but I don't know if they would work with OS 4.1 (and neither does Palm). Additionally, the cheapest I found after a quick search was $117 bucks. For a little more money than that, you can buy a new Palm, with OS 5.0, and bluetooth built-in. Wish I had better news for you...
Cheers
Nick
Dec 18, 2008 | Palm m500, m505 & m515 Install CD (pa1456)
Palm M515 general failure
You may perform full reset by pressing the reset and power button together. If issue persists you may try disconnecting the battery about 10 minutes and connect back. That procedure will erase all user data and will set the unit to the factory default
Aug 28, 2008 | Palm m515 Handheld
Instruction manual
http://www.palm.com/us/support/m515/
Follow this link. On the right-hand side of the page,near the bottom of the page, you'll see the handbook and setup guides for your palm pilot m515.
Feb 08, 2008 | RIM BlackBerry Pearl 8100
Palm M515 hot sync problem
I have a similar problem with my m515. I have 3 palms and 2 sync fine but the 3rd isn't even getting to the computer. There is no recognition from the computer that the palm is trying to sync even though I use the same cradle for all palms. The ensuing message is, "the connection between your handeld computer and the desktop could not be established. Please check your setup and try again". My settings are set Local and Cradle/Cable.
Dec 20, 2007 | Palm m515 Handheld
Palm M515 and compatibility with Vista Home Premium
I was having a similar problem with my M515.  I had originally installed the Palm Desktop from my CD, which was an older version.  When I totally uninstalled the old version and installed the newer version from the Palm website I was able to do a successful sync.  I'm using Windows Vista Ultimate and Palm Desktop version 4.1.4
Oct 24, 2007 | Palm m515 Handheld
Palm m515 Handheld Logo
116 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
