Question about Garden
My craftsman lawn tractor LT 3000 model number 917276813 goes dead when foot is removed from clutch
  • 246 Answers
SOURCE: owners manual for a craftsman model 917255812 lawn tractor
Hello:
>>You can Use the Site Addys at this Site Addy; http://www.yetmans.mb.ca/antiques.html to Search and Locate New/Used Parts or for Manuals for this Unit.
Respectfully
John
Posted on Apr 21, 2009
wadembly
  • 448 Answers
SOURCE: Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
Posted on Jun 08, 2009
  • 138 Answers
SOURCE: Craftsman LT 1000 with Briggs and Stratton 20 OHV
lift your seat and look at the label that you got your model number from. to the right of the model number is the serial number. the first six digits of the serial number is the date your tractor was made - for example: serial no. 060802D002756 would make the unit made June 8, 2002
Posted on Aug 18, 2009
  • 138 Answers
SOURCE: how do you hot wire a craftsman 3000 lawn tractor
now why would you want to do that? are you stealing it? why don't you use a key? they are cheap and a lot easier. - hot wire it same as you would a car
Posted on Aug 22, 2009
mowerman1857
  • 389 Answers
SOURCE: looking for wiring diagram for sears tractor
Go to www.searspartsdirect.com Enter your model number in the appropriate box, when the page loads, look on the left side of the page where it says "Browse sub-components" and click on "tractor-schematic" this will open to a total wiring diagram for you
Posted on Oct 22, 2009
Manual pdf Repair manual Lt 3000 Model 917276813
http://www.searspartsdirect.com/partsdirect/user-manuals/10409/917276813-Craftsman-Parts-TRACTOR-manual?pathRender=fromManualTabPage
Jun 02, 2013 | Craftsman 20 Hp 42" Deck Lawn Tractor
Replace drive belt lt 1000
look for tag on inside of hood for belt numbers. Or get model number off of tag under seat that starts with a 917. then call the 800 number.
instructions... Remove deck, remove pto pulley/ clutch, lock brake, remove crank pully and belt from crankshaft then remove belt from transmission and idler pulleys. Reassemble in reverse order with new belt ensureing the belt is not snagged on any belt guides and all idler pulleys are free.. ( PS sharpen blades while deck is off and check deck belt)
Oct 24, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a craftsman lt 1000 riding lawn mower and it runs, but it won't go into gear it goes into gear, but clutch won' engage the gear.
Look under the mower to see if the drive belt has come off or broke. It is the belt that runs from the bottom of the engine to the rear axle.
Oct 01, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I have a DLT 3000 mower every time I let off the clutch it goes dead either in gear or out....HELP
With out more information it sounds like one of the safety switches is faulty -most likley the one under the clutch pedal .To test this locate and unplug the ignition wire coming from the engine to the wiring harness the engine should keep going -- you will need to plug it back in to stop the engine.If this works then repair or replace the faulty switch.
I hope this helps
Andrew A
Apr 14, 2011 | Craftsman YT 3000 42" Kohler 22 hp Gas...
I just recieved craftsman lt1000, 19.5 b&s, 42 in. cut with hydrostat that was fine but I think I tripped a kill switch and it won't even try to engage the starter. What kill switches are there beside...
You didn't indicate what model number you have. You can download a manual here:http://www.managemylife.com/mmh/owner_manuals/21205/CRAFTSMAN-Lawn,-Tractor-L0306104?brand_name_search=917272672+CRAFTSMAN if the 917272672 isn't the right model go to www.searspartsdirect.com and enter you model number. When the parts come up look over on right had side of page for button to select manual. To start, you must have foot on clutch, PTO disengaged. The seat switch doesn't come into play until the PTO is engaged. Check for voltage at the B terminal on the start switch to be sure fuse is good. From there check the S terminal when you turn key to start. From there it goes to the clutch/brake switch (when depressed) then to pto clutch then to solenoid. GOOD LUCK!
Aug 14, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Model # 917256563 19.5 hp Craftsman. Ran fine until the front tire fell in a small hole. I heard a poping noise from rear of tractor I lifted the wheel out the hole and now the tractor will only run if I...
If the tractor stopped abrubtly, you may have bent something pertaining to the frame or the clutch pedal assembly if you caught your weight on the clutch when it stopped. Sears parts.com has en exploded view if you enter your model number
Aug 21, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
62 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
