Question about JVC Televison & Video
JVC D series clarity issue
Hello, I have been having an issue with my TV for a while now and was wondering if there was any way to fix this. There is an issue with the writing on the screen, it appears very blurry and almost unreadable (especially around the edges). Is there a setting in which I can change the sharpness or something? Thank you in advance
jomaru
  • 337 Answers
SOURCE: Help: My tv picture has started going blurry
The picture tube is going bad,not worth repairing,better invest in a new set. The rating response is important to the person helping you.
Posted on Oct 12, 2006
  • 308 Answers
SOURCE: JVC AV-32F704 32" TV Picture is blurry - cannot read any writing on the screen
You didn't mention if you saw fine white diagonal lines running through the screen from top to bottom. If so, you likely have a shorted Picture Tube which is not usually fixable. If there are no lines seen running through the screen, then it is possible the High voltage transformer which also has a screen voltage and focus control built in that could be bad. I would expect the cost of that part to be about $100, so the repair cost total could approach that of a new set I would guess.
Posted on Apr 12, 2007
sonysonyman
  • 68 Answers
SOURCE: TV wouldn't turn on.
i think you have a burn element called PTC in it it is a kind of remegnetizing the screen to get no magnetic fields affect the screen needs diagonous by qualified regards , plz don't forget to rate thx
Posted on May 03, 2007
  • 317 Answers
SOURCE: blurry tv monitor
try to adj picture settings.
Posted on Aug 03, 2008
  • 146 Answers
SOURCE: I have a sony trinitron
it is very easy you just need a very small straight edge screwdriver
you should try to adjust sharpness setting with on screen adjustment first
if tv is too old tube might be going "soft" and sharp focus might not be able to be fully achieved anymore
good luck
Posted on Mar 13, 2011
JVC LT-42E910 LED flat screen TV, backlight comes on, menu box is displayed but after about 5 seconds backlight goes out. Picture and sound still working but no backlight. How can I troubleshoot?
jvc tv backlight Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Get free help, tips & support from top experts on jvc tv backlight related issues. ...JVC LT-40SX6AT flat screen. Was watching TV ... ...jvc logo, has sound but nopicture Backlight is defective. I suggest ... Question about LT-42E910 42" LCD TV.
EASY MOST COMMON TV REPAIR EVER!!! - YouTube
? 13:13
https://www.youtube.com/watch?v=SXqSg2A5b7I
Jan 6, 2012 - Uploaded by Tampatec
Must See TV FIX EASY COMMON Samsung TV Repair Repairing LNT LCD ... LNT KDL Sanyo ln FLATSCREEN TV REPAIR FLAT SCREEN FIX - Hear Clicking .... i have a JVC LT42E910 WITH a cracked screen. there are all these color .... Vizio LCD Powers on with backlight, Wont power off, No video ...
Jan 11, 2016 | JVC Televison & Video
I have just purchased a used JVC D series tv and the screen rolls until tv warms up what can i do to troubleshoot this issue myself?
got a jvc d series floor model projection tv, it turns on but it rolls till it warms up what is the problem...
Oct 01, 2010 | JVC Televison & Video
My tv will not turn on and the on timer light is
Try the following blog. It has detailed instructions on how to fix a common problem on this JVC TV series. I did and I fixed my TV for 2 bucks at home.
Good Luck...Kim
http://brentlavelle.blogspot.com/2007/12/i-fixed-my-jvc-av-36980.html
Jan 14, 2010 | JVC AV-36950 TV
I have a Maytag Gase Double Oven Range Precision Touch 750 Series and having a problem with temperature control for lower over how can I fix. Jim
Hello Jim,
Can you clarify the problem you're having, or how the temperature control issue manifest's itself, i.e. can't set temp in display, too hot, too cool, won't ignite etc.
Just some clarity to move you further, hope I can assist further.
thank you
Oct 27, 2009 | Ovens
Jvc av27d201 tv screen problem
You need to have the vertical output IC pins resoldered
Jul 16, 2008 | JVC AV-27D201 27" TV
I just bought a JVC THD50 surround sound system. I want to hook up the system to my television and cable so when I watch cable I can hear the surround sound. I bought a digital optical audio cable and...
See below for the correct setup to get the best clarity sound possible.
From Set top box:
  1. Audio: optical or digital coax cable output --> jvc system Input
  2. Video: hdmi output--> jvc system input
From JVC System:
  1. Video: HDMI output---> TV HDMI input
TV:
  1. only accepting HDMI input from JVC System.
This will provide you will sound from your jvc system at all times. Your JVC system is made to be used as a hub. So essentially what you are trying to do is connect all components into the JVC system. Then only connect the video portion to your TV. The TV itself should NOT be emitting sound.
Note: You may need to turn off the speakers in the TV setup menu to acheive no sound from the TV. This will make for the ultimate experience.
Apr 03, 2008 | JVC THD-50 System
Need help with same prob you had with tv
Have you been able to fix this yet? I'm having the same issue..
Mar 09, 2008 | JVC AV-56WP74 56" Rear Projection...
Jvc 32" has grouping of thin white lines at top of picture extending 4" down from top of frame
It sounds like you have a bad capacitor in the vertical circuit. The circuit needs to be checked out by a technician. Stargazer
Aug 12, 2007 | JVC AV-32D305 32" TV
Televison & Video Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
