Question about Hannspree Televison & Video
Adjustable wall mount for HSG1075
Where to find a VESA compatible wall mount: VESA 100 X 200, 6 holes, M4, 8mm, 20 kg.
4 Suggested Answers
SOURCE: 47lc7df
I ordered a Sanus VMB1 kit for the some problem and I believe it should fix it for mine.
Posted on Jan 14, 2009
SOURCE: having trouble mounting a LC420SS8 VESA mount
There are 6 mounting screws located on the back panel that can be used as mounts points if you wish to construct a DIY mount (or if you don't want to purchase the official mounting bracket). See the manual for their exact locations.
I used 2 of these screws (the top two) to anchor a twisted steel cable that I designed to work in the same manner as a picture frame cable mount. I then drove a masonry nail into the brick chimney above my fireplace, and connected this steel cable to that mount point. The TV is mounted there, much like the way you would hang a painting (a very large & heavy painting). The bulk of the weight is supported by the front edge of the TV, which rests on a brick mantel that is part of my chimney. The steel cable, while strong enough to fully support the TV, only acts as a balancing wire, or to catch the TV should it topple forward off of the mantel.
Be sure you know how to work with steel cable and have a strong anchor point if you try to use this method. DO NOT USE THIS METHOD FOR DRYWALL ONLY APPLICATIONS. USE FOR EITHER WOOD STUDS or MASONRY APPLICATIONS ONLY.
Posted on Jun 11, 2009
budmrtn
  • 11361 Answers
SOURCE: Mounting a Toshiba 32HL95 on a Wall
Yes you can:
http://www.skakawack.com/wm11-3496.html
or OMNIMOUNT P/N U2-T, U2-F.
Posted on Oct 29, 2009
Testimonial: "Many thanks. The bracket claims that it is specifically good for the 32HL95, so I'll give it a try! Great response, thanks again, Dave"
Is ther a wall bracket for the 32BV501B
Your TV has a standard VESA compatible mounting arrangement, 4 screw points in the back of the TV, You can buy a standard Gereric LCD Wall mount and it will be compatible with your TV.
Either Ebay or your local appliance/electronics/home improvement store will have them.
Mar 06, 2012 | Televison & Video
I have SOYO MT-+SYTPT3227AB TV and cannot locate mounting holes to wall mount the TV.
This TV is not Wall Mountable as the Control Box protrudes and is therefore not suitable for a VESA Wall Mount.
Jun 10, 2011 | Soyo Televison & Video
I need a wall mount bracket
Most if not all tv's are VESA compatible. All wall mounts are VESA compatible, meaning you can buy any wall mount you see fit to mount your tv.
I'd look into Sanus brand mounts, they're pretty decent.
Mar 08, 2011 | Emerson LC320EM8 32 in. LCD TV
What wall mount do I need for a Hisense 20" LCD. Is it VESA compatible?
you can use an universal 20" from Walmart, bestbuy, most places. or you can buy one just for your tv for about $50.00 on Amazon. $30.00 on E-Bey.
Sep 08, 2009 | Televison & Video
Can the 19av500u be mounted on the wall
yes to find proper mount google 19av500u wall mount PLEASE make sure it is screwed into a 2-by-4 in wall
Sep 02, 2009 | Toshiba 19AV500U 19 in. LCD HDTV
Monitor stand and power cable needed
Hi Kiran,
If the power cable matches the power cable of your computer, it's a standard 3 prong power cable and you don't need a specific kind. If it's a small circular type you will need an external AC adapter, the type will depend on the manufacturer and make of your monitor. These can be found on eBay usually. Most monitors use different types of stands, but if your monitor has the standard VESA 75 or 100mm mounting holes on the back, you can find many monitor stands that are compatible with it. The standard VESA mounting holes are usually used for wall mounts but lots of stands connect to the monitor this way. You can tell by a set of 4 holes for screws or bolts on the back that are either 75mm or 100mm apart (vertically and horizontally). Don't forget to get the right kind of bolts for the stand, if it doesn't include them.
Jun 10, 2008 | AOC Computers & Internet
Cannot find VESA holes...Samsung Syncmaster 970p
I have looked at the specification for this, and although it does show as being VESA compatible (This is a display standard) There is no mention of any "wall mounting" capabilities at all, which would lead me to believe that this is not designed to be put on a mount. also the "Magic Rotation" Technology which is part of this device may rely on it using the proprietory stand, it may well be possible to remove the stand however, but it would require some significant dissasembly as the power connector is on the signal box, and this would need to be seperated from the stand itself. The mounting bolts look to be hidden behind the round pivot cover on the back, and it may be possible to see if mounting is possible simply by removing this, however I would seek information from the manufacturer about this as removing any of the covers would most likely invalidate your warranty, it is possible that this was missold to you and you should be able to take it back as not being fit for purpose.
Sep 15, 2007 | Samsung SyncMaster 970P 19" LCD Monitor
Televison & Video Logo
111 people viewed this question
Top Hannspree Televison & Video Experts
Ricky Lee
Level 1 Expert
Are you a Hannspree Televison and Video Expert? Answer questions, earn points and help others
