My laptop doesn't have a VGA or an HDMI port. Which cables do I need to make a connection to my TV, and how do I connect the cables?
SOURCE: can i connect toshiba satellite a205 to tv?
Yes VGA carries RGBHV--RGB and Horizontal and Vertical Sync information along with DDC info where available.
Now is that port on your TV a d-sub 15 pin standard VGA connector?
http://en.wikipedia.org/wiki/VGA_connector
If it is, then yeah you should be able to output VGA from a PC to the TV with a proper cable.
However if the TV has DVI or HDMI connections on it, it's better for
you to connect it that way. DVI/HDMI is a digital signal and if it's a
digital-based display tech TV, then you're better off using that. Also
if the TV does resolution above 1360x768 (i.e. if it does 1080p) you
can get higher resolution by going via DVI/HDMI...
SOURCE: how to get audio by connecting pc to tv using hdmi
In your internet option and the menu advanced, you've got a sub-menu "multimedia" ,disable the box with "play sounds in webpage"
tell me if it's works.
cheers
SOURCE: no picture connecting laptop to LCD TV both Toshiba
Try the fn key and the monitor key (f4?)at the same time to activate external monitor
SOURCE: How can I connect my Toshiba Satellite A305-S6872
VGA to RCA adapter (ebay listings, none are mine), just add the audio cable out to the TV...
SOURCE: VGA connection from PC to TV --TV says "no signal"
On the remote control for your television, there should be a source or input button. Pressing the key repeatedly will switch from cable input to standard tv input, to s-video, or ypbr, or game, or various others. Try doing this and see if the image appears, this awlays works for me. If I am telling you something you have already tried, i am sorry!
Hope this helps someone! If you have any other ideas or suggestions, please feel free to comment!!! Thanks!
