Question about Harman Kardon Audio Players & Recorders
I have an HK AVR2600, after turning it on in about 30 to 40 minutes it makes a loud popping noise and shuts down. I can turn it right back on and it works fine, but only to do the same thing. I have no speaker wires touching, and checked all my connections. I have had this receiver for about three years with no problems.
3 Suggested Answers
SOURCE: Speakers pop and rear speakers cut out of surround sound
your problem is a bad solder connection of the relay linked to the lautspeaker sockets. I had the same problem and googled for the solution. Since I resoldered the pins everything is fine. That problem is well known and happens to a lot of Sony receivers.
I can send you a link with a detailed how-to-do solution with pictures, however it's written in german language. But you can use some online translators.
Here is the link: http://www.bmw-syndikat.de/bmwsyndikatforum/topic.asp?TOPIC_ID=28280&FORUM_ID=20&CAT_ID=9&Forum_Title=Geplaudere&Topic_Title=Problem+Sony+STR-DE445
Ralf (from Germany)
Posted on Feb 15, 2009
SOURCE: "Check Speaker Wire" error on my Yamaha Receiver
I undid all my speaker wires and reconnected them. I haven't had the problem since.
Posted on Jan 03, 2010
Samsung HLS5086WX/XAA made popping noise and shut off, then made whirring noise.
When my TV did this in the past it ended up being the color wheel. I had someone replace it and it worked fine. I asked it if had to be calibrated after it is installed and he said no. Also make sure the door switch is pushed down when you install the back bulb door. Sometimes this switch can go bad as well.
Jan 10, 2013 | Samsung HLS5086WX/XAA
Rear HVAC unit in 2002 trailblazer making loud poping noise and then quits after a couple of minutes
The only thing i can think this would be is a blower motor noise, have shop take a listen is my best advice.
Oct 25, 2012 | 2002 Chevrolet TrailBlazer
Toshiba TP50G90, makes a loud popping sound then shuts off. red light flashes
it sounds like its over heating.clean all the fans ,put new artic paste on the cpu
Jan 25, 2018 | Toshiba TP50G90 50" Rear Projection...
When I back out of driveway and turn rear of the car to the right a loud popping noise in the front right wheel area. Took it to a mechanic and they thought it was fixed. Charged me $287. to replace lower...
you don`t say if this is a 4x4 truck.if it is it could be the Ujoints/halfshaft joints on the side thats making the noise.another thing to have checked is the upper and lower control arm bushings for being worn out causing the noise.just suggestions.
Sep 08, 2011 | 1999 GMC Jimmy
Crosley CDE8000W Dryer has electric burning smell and shut down
it is most likely the belt. the squealing noise is because the motor is turning, but the belt is not. a replacement belt is not too expensive and it is fairly easy to replace. if you need directions how to replace it, let me know
Oct 27, 2008 | Dryers
Panasonic sa-ht700
same bro and its happening when there has no bass
Jul 29, 2008 | Panasonic Home Theater System System
Hitachi 51g500
Sounds like flyback shorting out and shutting down high voltage, causes TV to turn off for protection.
I would send in for repair cause this is big $$$ cost!
Jun 20, 2008 | Hitachi 51G500 51" Rear Projection...
Right Door is making loud popping noise
After reading these posts, I fixed my refrigerator door in less than 5 minutes. The little black plastic cam on the bottom hinge was loose. To fix it, take the hinge cover off of the top with an 8mm socket, and remove the three 8mm screws holding the top hinge on. Remove the door by lifting up off of the bottom hinge and set it aside. On the bottom hinge is a black plastic cam held on by an 8mm screw. The screw on mine was really loose. Tightening it and putting the door back on made it work like new. You probably don't have a bad cam, just a loose one.
Aug 25, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
