Question about Sony Cyber-shot DSC-W50 Digital Camera
Auto focus not working
Recently, my camera only takes focused pics if I have'ed zoomed at 1.5x, if it's any less or more it's very blurry, I tried playing around with the settings but that didn't help, is there anything I can do to fix this?
    Novelist:
  • 198 Answers
Hello, Most probably your camera has a lens assembly problem. The lens mechanism is composed out of tiny servomotors and moving parts that can easily get damaged if the camera receives a mechanic shock. Sometimes simply out of nowhere some of the small plastic components may become loose and affect other componets near it. In your case, it's pretty clear that the lens can't seem to move corectly in order to achive best focal lenght. Maybe something is obstructing them in some way. Because of that the camera only achieve a correct sharp picture at a fix autofocus point. When the lens try to move away from that point, something obstruct them or they have become decalibrated and the picture gues blurry. The only way to fix this would be to send it to a qualified service center because the lens assembly is very fragile and small. Some times they need to use a microscope and small specialised tools in order to realign the lens. Other then that, there could be a problem with your camera firmware but also this will lead you to a service center in order to have the firmware rewritten. There are some firmware versions on the internet but I don't recomand you try to update the firmwware yourself. Some of this versions are "cracked" or from uncertain sources and if you fail this upgrade you may render the camera useless.
Posted on Sep 25, 2007
Non-zoomed pics are in focus but as soon as I zoom in, even slightly, pics get very blurry. What settings should I be adjusting, please?
M stands for macro.this is for extreme close so dont take photos with m displayed unless extreme close
Jul 06, 2015 | Sharp Cameras
Blurry pictures
You did not say which lens or lenses you are using, but most auto-focus lenses have a switch for selecting manual or auto-focus. First, check your camera's menu settings to make sure auto-focus is enabled and then your lens to make sure you did not accidently leave it in the manual focus position? If it is in the auto-focus position and still not taking sharp pictures, switch it to manual and see if you can get it to focus correctly. It is also possible that your auto-focus alignment is out because your camera was bumped, jolted or dropped. If realignment is necessary, you can send the camera and lens to Nikon for repair or find a knowledgeable camera repairman.
Jul 29, 2012 | Nikon D5000 Digital Camera
My Olympus e 510 is one year old. worked fine, but now is taking blurry pics. I tried all focus setting, including manual setting, auto-focus and even tried a different lens, still takes blurry pics. It...
I have the same problem and I strong suspect the circuit board is going bad. No matter what lens I use, distance from subject, etc. makes any difference. Unfortunately, the fix is about $200.00 - and having to invest $200.00 per year to keep it going is not a viable option for anyone.
Jan 23, 2011 | Olympus EVOLT E-510 Body Only Digital...
When i turn on my camera to take a pic it is blurry but if i zoom the lens all the way close to the object it takes a good pic.
Your auto-focus is not working. Inside the camera is a motor that adjusts the lens to focus on an object automatically. It is currently stuck to "close" or near focus. However, it doesn't go far focus. Check the focus functions of you camera - try to use manual focus.
Dec 01, 2010 | General Electric A735 Digital Camera
Im looking for a lens that i don't have to set up the focus. im taking a trip and my husband doesnt know how to use the camera and this 18-105mm lens needs to be focus if not then the image will be...
Sorry, but there is no auto focus or fixed focus lens available for your camera. You might consider purchasing an inexpensive fixed focus camera for your photo-challenged husband -- it will cost considerably less than an extra Nikon lens would.
Bill B.
Nov 01, 2010 | Nikon D90 Digital Camera with 18-105mm...
''New'' Lens will not Focus,how can I fix this problem
Try Nikon's website for connection to their Technical Support. www.nikonusa.com
Jun 11, 2009 | Cameras
Blurred images on the lcd screen and pics come out blurry
number 1,make sure you have lithium batteries,energizer prefered.2 put it on auto focus.3dont be too close on the object your trying to photograph,and 4 do not zoom in too close on object either.this should solve your problem,good luck,hope i helped
Apr 30, 2009 | Samsung S860 Digital Camera
Manual Focus won't work
Which camera are you using? If the body has AF/MF switch, put that also to MF.If this fails to help, take out the lens and try to change it to MF.
Feb 05, 2009 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED...
Focus and or Zoom problem
double check that its still in auto focus, i went a whole day trying to figure out why my camera wouldnt focus, and i had auto focus off
Jul 12, 2008 | JVC GR-D770 Camcorder
Auto focus
Make sure the macro funcion is off sometimes I forget to turn it off and when I try to take a normal picture it has a bad time focusing.
Jun 25, 2008 | Sony Cyber-shot DSC-H7 Digital Camera
Sony Cyber-shot DSC-W50 Digital Camera Logo
87 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Terry Weaver
Terry Weaver
Are you a Sony Camera Expert? Answer questions, earn points and help others
