Question about RotoZip Revolution Spiral Saw USED
My rotozip rz2000 xshield2 will not rotate under load
My dad has an old rotozip rev01. we can't remove the blade because the flange nut was overtighten. is there a way to remove the nut?
'Sprag' the blade to stop it from rotating. Apply some WD40 or kerosene around the area and use an impact gun or impact driver to crack the nut. Check the thread and make sure you are actually turning the right way to loosen the nut. Some are a left hand thread! Cheers Bob
Sep 29, 2016 | Bosch RotoZip Spiral Saw RZ10 - 2100
Whereto get manual for roto zip z20
The manufacturer's web site has the manuals for many of their tools on their support page: http://www.rotozip.com/en-us/support/Pages/Manuals.aspx . If you have the RZ-20, the direct link to the manual is http://www.rotozip.com/en-us/support/Documents/WEB2610938267%2002-07%20RZ1-25.pdf .
I don't know of a Z20 from RotoZip. I hope this helps.
Dec 28, 2015 | RotoZip RZ 20 RZ20-4300 Spiral Saw System
I have a rotozip rz20. The bearings are shot. Need to know where I can find a new set. Google has not been any help.
http://www.ereplacementparts.com/rotozip-parts-c-15402.html?utm_source=Bing&utm_medium=PPC&utm_campaign=rotozip%20-%20search%20-%20mike Try here.
Jun 20, 2015 | Saws
Wiring diagram for rotozip RZ2000
You may have a crippled display unit. Open the rear clamshell and see if there are any other parts missing, wires clipped. Draw the front casting and armature out and see if there's a hole drilled thru the field coil.
Mar 29, 2013 | RotoZip RZ2000-55 Variable Speed Spiral...
Rotozip manuals
Here is a link to their site. It would be under the section for "support."
Rotozip site
May 30, 2012 | Saws
I need rotozip bit change instructions
Press in shaft lock button, use supplied open-end wrench to loosen collet--RH thread and remove bit by hand.
Jan 31, 2010 | Bosch RotoZip Spiral Saw RZ10 - 2100
I was cutting 1/4" wall tile. On the 3rd or 4th cut my rotozip RZ5 quit working. There is power at the outlet. The machine was pretty warm. Is there a fuse or thermal reset or do I need to send it in foer...
I have had similar problems in the past using my Roto-Zip on jobs. You may want to check the internal brushes in the machine have not been clogged with the dust from the ceramic tiles. The unit may have simply overheated from the stress of cutting the tile. This will also affect the brushes in the Roto-Zip. A can of compressed air may help clear any dust built up around the brushes. If they brushes are caked with to much dust, you may have to take the unit appart and manually clean the brushes. But, be careful because the brushes are spring loaded. Hope this information is helpful.
Aug 17, 2009 | Bosch RotoZip RZ05-1100 RZ5 Base kit
RotoZip Revolution Spiral Saw USED Logo
35 people viewed this question
Top RotoZip Saws Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a RotoZip Saw Expert? Answer questions, earn points and help others
