Question about Bobcat Miller 225 Welder Generator 907209 Or 907210
Have a miller bobcat 225D Plus welder that trips circuit breaker CB-8 when running,about 5 seconds after shifting to run or after shifting to run/idle & striking arc
4 Suggested Answers
  • 18 Answers
SOURCE: Bobcat Miller 225 won't start.
Check the oil safety switch maybe it is bad. It will stop running if low on Oil or wont start.
Posted on Feb 19, 2011
luis_david
  • 407 Answers
SOURCE: will not strike an arc,
Hi:
Probably your machines overloaded. Check your fuses F1 and F2 and if they are open replace them.
Both fuses are located at left hand side of machine, open it and you will find them on the bracket.
Good Luck.
If this was useful please vote, thanks.
Posted on Apr 28, 2011
  • 1212 Answers
SOURCE: have a 225 bobcat welder wont stay running can add fuel to carberator but if i stop sparing fuel in unit stops??
The fuel pump is one of the probable faults, or the needle valve in carb is stuck in closed position.
If the fuel hose is removed at carb, it should squirt gas as the engine is cranked over. If not, look in tank to see if the screen on the barb threaded into the tank has not clogged up with debris. If it is clean, replace fuel pump.
If it squrits gas- open up the carb and check to make sure the float is able to pull the needle valve down as well as the float level setting. When the bowl is exposed, look for sediment as well.
Posted on Jan 04, 2012
I have a 2007 miller bobcat it has spark cleaned carb new plugs new filter and it won't start
did you try a touch of starter fluid in the carb just to verify that the engine is getting spark? ethanol gas... if it hasn't run in a few months and you left the gas in it... you better revisit the carb cleaning
Dec 13, 2015 | Bobcat Miller 250 Welder Generator 907212...
225Bobcat gen.runs but will not excite when trying to strike arc
#Tags bobcat 250 welder service manual
coop.bounceme.net/term/bobcat-250-welder-service-manual
Why does my miller bobcat welder generator not stay at an idle when swithed to low idle, insted it goes back and ... Won't strike an arc,fuses ok brushes and slip.
Aug 11, 2015 | Electrical Supplies
I have a miller bobcat 225, it keeps blowing 30 amp inline fuse on a blue wire that runs to the hot side of the starter, any idea?
millerwelds.com will let you down load a manual for this unit, it can help you with this problem, also you can call miller and tech support should help
Jan 22, 2015 | Bobcat Miller 225 Welder Generator 907209...
Why does my miller bobcat welder generator not stay at an idle when swithed to low idle, insted it goes back and forth to high then to low idle?
The unit may need recalibrating the idle/run setting. Instructions found in manual at 8-6 (subaru engine) and 9-5 (kohler). Idle speed around 2200rpm. Simple screw adjustment. PDF manual here :- http://www.millerwelds.com/om/o4434l_mil.pdf
Aug 02, 2014 | Bobcat Miller 225 Welder Generator 907209...
My welder only welds for about 2 seconds then trips house breaker. i have a good dedicated 20amp breaker for the welder. what could cause this? the welder breaker in back of machine does not trip.
Is enough for this machine, but probably is not a fuse dedicate it just for this end side.
If you can turn all lights off and other items that might be in use with the fuse. If you can't then upgrade the fuse to a 30amp.
Jan 10, 2011 | Miller MilWeld MLL907263 /AutoArc XLT142...
Bobcat 225 does not produce ac current 110 or 220?
Probably you need to act the braker, put the idle at max (pull throtle) and let it run for a minute, that will reset the braker.
Dec 03, 2010 | Bobcat Miller 225 Welder Generator 907209...
My new Miller Bobcat has low amperage on 120 volt outlet.
Increase your idle setting on the 1/8" threaded rod protruding to the left of the carburetor until V= 125. Then run your drill. Actuating the drill should call the throttle solenoid to open up to produce more power.
May 12, 2010 | Miller Electric Manufacturing Electric...
Bobcat Miller  225 Welder Generator 907209 Or 907210 Logo
44 people viewed this question
Top Bobcat Welding Tools Experts
freddyfox
Troy
Troy
Level 1 Expert
Lawrence Oravetz
Are you a Bobcat Welding Tool Expert? Answer questions, earn points and help others
