Question about Dualit 40352 4Slice Toaster
Faucigny mi2 timer instruments - Dualit 40352 4Slice Toaster
2 Suggested Answers
  • 11 Answers
SOURCE: Combi 2 plus one, bought
I think the MI7 timer is equivalent. The best prices are on ebay. You can also check in with appliance repair shops. Electra-Craft lists Dualit timers, but again, I am not sure if these are what you need: http://www.mcssl.com/store/electra-craft/catalog/search?keyword=dualit+timer
Posted on Jan 29, 2011
Where is the body control module located on a 2002 Ford explorer XLT
It's called a GEM - generic electronic module .It is located behind center of the instrument panel .
SECTION 419-10: Multifunction Electronic Modules 2000 Explorer/Mountaineer Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 10/07/2004 Module - Generic Electronic (GEM)/Central Timer (CTM) Removal
  1. CAUTION: Electronic modules are sensitive to static electrical charges. If exposed to these charges, damage may result. Depower the supplemental restraint system (SRS). For additional information, refer to Section 501-20B .
  1. Remove the audio unit. For additional information, refer to Section 415-01 .
  1. Remove the center instrument panel finish panel.
    1. Remove the screws.
    • Disconnect the electrical connectors.
  1. Remove the GEM/CTM.
    1. Remove the screw.
    1. Disconnect the four connectors from the GEM/CTM.
Feb 18, 2017 | 2002 Ford Explorer
NEED AN ENGLISH USER MANUAL
i have English user manual of toyota Premio 2nd genration .Pay only 25000/=
Oct 28, 2013 | Xiaomi Mi2 Unlocked White
Glow plugs not working relays timer etc all ok
try fuseable link at battery possitive. check all fuses
Nov 16, 2012 | 1997 Toyota Land Cruiser
Combi 2 plus one, bought in 2006. i need a new timer element type HI7 made by faucigny instruments. Where can i get hold of one of these spare parts?
Jan 25, 2011 | Dualit Vario 3 Slices Toaster
I am unable to load the drivers in order to operate the steinberg MI2 interface, I also encounter issues with latency in regards to real time play back
Nov 01, 2009 | Steinberg Cubase SE
Washing machine is on spin cycle, and spinning yet
There is a relay switch that is hooked to the timer and to valve that controls the water draining, this relay is worn out or just no getting the signal for the timer. Its a (timer) (relayswitch) or ( valve) Finding which one is easy, a cheap test light well do the trick. Start at the source of power and work your way to the valve when you stop getting power you are at the problem.
Aug 09, 2009 | Texas Instruments TI-83 Plus Calculator
I need installation directions for installation of a gem module
here it is but you must have it configured.
Generic Electronic Module (GEM) —Generic Electronic/Central Timer (GEM/CTM) Removal
NOTE: The GEM must be reconfigured upon replacement. Refer to the scan tool help screen on the Ford Service Function (FSF) card to program tire size and axle ratio.
  1. syo~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Electronic modules are sensitive to electrical charges. If exposed to these charges, damage may result.
    Disconnect the battery ground cable. For additional information, refer to Section 414-01 .
  2. syo~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use care when removing the instrument panel steering column cover (044F08) or damage to the cover locating tab may occur.
    Remove the instrument panel steering column cover.
    1. Unlock the retainers.
    1. Remove the instrument panel steering column cover.
  3. Disconnect the bulkhead connectors from the instrument panel fuse junction panel.
    1. Loosen the bolts.
    1. Disconnect the bulkhead connectors.
  4. Position the instrument panel fuse junction panel aside.
  5. Remove the nuts.
  6. Remove the bolts.
  7. Remove the generic electronic module/central timer module (GEM/CTM).
    1. Disconnect the electrical connectors.
Feb 20, 2009 | 2000 Ford F250 Super Duty Crew Cabs
Timer switch is not working stuck in the on postion
I just had the same problem. It's the knob itself. You have to extract the knob by pulling, gently, and squeezing it out. The plastic housing over the metal thing is cracked. I took some super glue and duct tape and wound it tightly around it and pushed it back it and it works.
Dec 13, 2008 | Starbucks Barista Burr Grinder
Dualit 40352 4Slice Toaster Logo
217 people viewed this question
Top Dualit Kitchen Appliances - Others Experts
Ross Keen
Piyal Perera
Piyal Perera
Joseph Hoffmann
Are you a Dualit Kitchen Appliances - Other Expert? Answer questions, earn points and help others
