Question about Bosch Nexxt WTMC 3300 Electric Dryer
Bosch dryer not workin
Ok my stepdad gave me a bosch dryer. he told me the lint light was on and flashing and would not go off, also the wrinkle cycle light is flashing please help it is a bosch nextt wmct3300 i think
  • tiffanycrash Apr 24, 2009
    i would really like to do it myself...i have taken the back off and cleaned that, the lint filter is clean, its dark now and i cant see out side tomorrw i will take the front off and clean that part, is there a sensor that could be bad? i looked online to see if it had a sensor but couldnt find any thing.
    Genius:
  • 1,198 Answers
Sounds like the dryer needs a good cleaning inside the workings area. Have a technician take it apart, and have a vacuum handy to **** up all the lint. While in there, he can check the working parts.
Posted on Apr 24, 2009
  • mike kirschbaum
    mike kirschbaum Apr 24, 2009
    Repairclinic.com is a good site for parts and help, sometimes just seeing a part and it's name and description is helpful. A lot of times I will Google the appliance, find a lot of stuff. This site is very good, maybe someone more familiar with your unit will reply. Bosch is a good brand name, worth the effort.
Lint light flashing
The problem may be with air flow through the lint filter screen. The filter is a fine screen and even though it appears to be lint free, it may not be. Spray the screen with a degreaser, use a soft brush to gently scrub it, and rinse under running water. This may solve your problem.
Jun 30, 2014 | Bosch Nexxt 500 Dryer
Bosch dryer won't run
bad air flow switch,check wire diagram.
Mar 04, 2014 | Bosch Dryers
Turning off and on in timed cycle
Sounds like you have it on wrinkle prevent, a feature that keeps your clothes from wrinkling before you pull them out of the dryer. Check your user manual.
Nov 07, 2013 | Samsung Dryers
No lint on filter? Where is it all going? Checked exhaust vent bought a vacuum attachment and there is no lint. Twice and sometimes triple the drying time! Help!
Instructions
  1. Dryer Does Not Run
    • 1 Close the door firmly. The dryer will not operate if the door is not completely closed.
    • 2 Press the "Start" button firmly or push the knob in to start the dryer.
    • 3 Turn the dial past the "Off" position and away from "Wrinkle Prevent." The dryer will not start in the "Off" or "Wrinkle Prevent" position.
    Long Drying Times
    • 4 Remove the lint screen. Clean it and replace it.
    • 5 Check the temperature of the room. The dryer will not operate properly in temperatures below 45 degrees Fahrenheit.
    • 6 Inspect the area around the dryer. It requires at least 1-inch clearance on the front and sides of the dryer. A 5-inch clearance is needed on the back of the dryer. Move the dryer, if needed.
    • 7 Separate large loads and do not use an air dry cycle.
    Lint, Stains and Wrinkles
    • 8 Clean the lint screen before drying each load of clothes to prevent lint buildup on clothing.
    • 9 Add fabric softener sheets before starting a drying cycle. If the sheets are added after the load has partially dried, they can leave stains on the clothing.
    • 10 Dry small loads and remove clothing as soon as the drying cycle completes to prevent wrinkling.
    Dryer is Noisy
    • 11 Check the inside of the dryer for loose change, buttons or other items. Empty the pockets on clothing before drying.
    • 12 Separate items that are knotted together and restart the load. Knotted or balled up clothing will bounce and make the dryer vibrate.
    • 13 Level the dryer. Turn the leveling legs on the front of the dryer clockwise or counter-clockwise until the dryer is level. Turning the legs clockwise will lower the dryer. Turning the legs counter-clockwise will raise the dryer.
Jan 15, 2013 | Admiral Dryers
Hi! We have a Bosch Axxis gas dryer that runs for aprox 40 seconds than stops and "Beeps" and the "Drying" & Wrinkle Block/End" lights flash. I have tried running it empty...
your sensor is either dirty, most likely or bad. it is located under the lint trap. if you look down you will see it it has tow screws, be careful when cleaning it as it may break.
Feb 18, 2011 | Bosch Axxis WTA 3510 Electric Dryer
Flashing container light. what is this? Dryer
Try taking out the lint screen and scrubbing it well in the sink with hot water and a brush. If you havent cleaned out below the lint screen, get a vacuum and a crevice tool and remove any standing lint as well as cleaning the vent. Bosch lint screens clog easily especially if you are a big fabric softener user.
Nov 20, 2010 | Bosch Classixx WVF 2402 Front Load...
Kenmore dryer beeps constantly
End of Cycle Signal
The End of Cycle Signal produces an audible sound when the
drying cycle is finished. Promptly removing clothes at the end of
the cycle reduces wrinkling.
@ H_GH
@ LOW
@ OFF
END of CYCLE S_GNAL
Press END of CYCLE SIGNAL to adjust the sound level or turn off
the signal.
NOTE: When WRINKLE GUARD _ is selected and the End of
Cycle Signal is on, a tone sounds every 5 minutes until the
clothes are removed, or WRINKLE GUARD _ ends.
Sep 15, 2009 | Dryers
Dryer not working, indicates "lint filter" When I try to use the dryer (Bosch Nexxt), i first turn the dryer to the setting desired (regular or perm press, and time) it immediately has the "lint filter"...
This is a common complaint with this dryer.The probe generating this problem,is at fault.It likely has a film on it,from the dryer sheets.Remove the lint screen,and wipe down the probe that sticks into the air box.Should fix the problem,if not ,replace the probe.
Sep 01, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch dryer lint light flashes
My Bosch Nexxt electric dryer had the same problem with the lint filter light blinking and the dryer not running. It turned out that the door switch was not engaging. The service technician informed me that there is a plastic tab (available only by opening the top access panel) that was not fully snapped in place. When he snapped the tab back in place and then secured it with a screw, the door switch fully engaged, the lint filter light went out, and the dryer ran perfectly! I hope that helps you!
Feb 28, 2008 | Bosch Dryers
Bosch Nexxt WTMC 3300 Electric Dryer Logo
435 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
