Question about GE Profile JTP18 Electric Single Oven
Oven doesn't reach proper temperature - GE Profile JTP18 Electric Single Oven
Oven will not reach proper temperature
Hello Cynthia, contact a professional that your manufacturer suggests. Sounds like the mechanical thermostat, oven sensor or EOC needs to be diagnosed for replacement.
Sep 15, 2012 | Frigidaire FGB24S5A Gas Single Oven
Main Oven does not reach required temperature
check gas pressure and burner if ok bad temp sensor
May 19, 2017 | Electrolux EOD5330 Ultrafan Electric...
Hi i have turbochef speed oven in subway and on display show F6 ec Temp . what is problem
F6 faults occured when temperature reached to 150 degree faharanite in the electrical compartment.
Solutions
1. Clean the dust in the electrical compartment.
2. There is an temperature sensor on the controle board which gets dirty and throw wrong values.Clean it and then try.
3. Check the exaust fan in the top rear location is working properly.
4.Check for proper air ventillation.
Apr 15, 2011 | TurboChef TORNADO Electric Oven
Turn oven on to bake when it reaches temp oven cuts off and f2 sh
This indicates the oven has reached an over temperature. You will first need to check the temperature probe for the proper reading. Refer to the tech sheet located somewhere on your stove. It should be around 1100 ohms. If this checks out good the ERC electronic range control will need to be replaced. Here is a couple links that should help
http://appliancehelponline.com/oventempprobe.html
http://appliancehelponline.com/ovenerc.html
Jul 27, 2010 | GE Profile JTP18 Electric Single Oven
The oven does not get up to the proper teperature
The problem is the ignitor is not reaching the correct amp draw. There is a free video at www.appliancehelponline.com/servicemanual.html this will walk you thru performing the amp draw test.
Mar 29, 2010 | Tappan Ovens
Amana Electric Oven Issue
My oven never reaches the proper temperature sitting for baking. Controls for the oven only is push buttons. How can I adjust this. This has been going on since I have bought the Amana
Oct 27, 2008 | Amana AOCS3040 Electric Single Oven
No heat
check your elements are they red?
Aug 01, 2008 | Neff U1661 Double circotherm super...
Oven doesn't maintain temperature
When an oven doesn't maintain the set temperature, first make sure no one is allowing the heat to escape by opening its door. If not, the oven control either needs to be re-calibrated or replaced. To have the control replaced, call an appliance service person.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
GE Profile JTP18 Electric Single Oven Logo
27 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
