SOURCE: No sound
The drivers you mention are related to your sound drivers to they are installed. Run this programme to see if there is a driver problem, click Start>Run then type 'dxdiag' and hit enter. It could be the motherboard sound chip thats failed.
SOURCE: Firewire on Inspiron - Connecting Canon MD 120 camcorder
Browsing over the md120 specs, included should be a software disc for the usb connector, so it shouldn't matter whether you use an adapter or the 4 to 4 cable. This disc will have the drivers and software for using the camera in conjunction with your laptop. Have you tried this download for the camera.
http://software.canon-europe.com/products/0010449.asp
Also check out this link. Towards the bottom under additional features it lists software, drivers and utilities, and at the bottom under supplied accessories it lists application software/usb driver. Go to the store you purchased this at or contact Cannon support and get the disc that was supposed to be included.
http://www.einfo.co.nz/shop/product_info.php?pName=sony-dcrdvd908e-20x-optical-zoom-camcorder
SOURCE: Acer Aspire 5100 webcam problems
Here is some great source to solve any kinds of laptop's problem.
» Hp Laptop's Solution
» Compaq Laptop's Solution
» Acer Laptop's Solution
» Dell Laptop's Solution
» Toshiba Laptop's Solution
» Asus Laptop's Solution
» Gateway Laptop's Solution
» IBM Laptop's Solution
Here is some another Great source to download any kinds of laptop Drivers.
» Hp Driver's Download
» Compaq Driver's Download
» Acer Driver's Download
» Dell Driver's Download
» Toshiba Driver's Download
» Asus Driver's Download
» Gateway Driver's Download
» IBM Driver's Download
4s23
SOURCE: Dell Dimension 4700 desktop to Phillips TV
this is what i found about your card on the website. that is if you mean the x1300
Get
high image fidelity with CRT and LCD displays, TVs, rear projection
and plasma TVs, as well as projectors. Avivo introduces new life
to colors across the entire spectrum with an advanced 10-bit-per-color
display engine. Gain better digital signal reception, and maintain
cleaner video with hardware noise reduction. Enjoy high-quality
analog video capture enabled by robust 12-bit analog-to-digital
converters.
So this tells me they have some sort of prgram or decoder for tv's. I'll keep looking
Are you using a pc to tv box?
