Question about OneRoof Computers & Internet
The microsoft jet database engine cannot find the input tab
4 Suggested Answers
SOURCE: Error#: 0x80040e37
Hi, I got the same problem. The solution for me was: 1) RUN IMDATUpd.exe 2) Start SpySubtract 3) (Update needed so) Update defenition 4) Up-and-running again! Good luck and best regards, Garfied!
Posted on Oct 09, 2006
dbarchitect
  • 150 Answers
SOURCE: Microsoft JET Database Engine error '80040e09'
When putting files up on your hosted site (or on your own server), make sure the file and the directory have the proper writes to Read/Write/Create. A special file called the .LDB file must be created and if it can't a ReadOnly status could be issued. It's a file that contains the names of the users currently accessing the MDB file. It stands for Lock Database.
If you are running on Windows add these attributes, if it's linux (not sure why you'd use MDB on a LINUX box, but it would be chmod +777.
Posted on Nov 25, 2007
kd24911
  • 90 Answers
SOURCE: run time error the microsoft jet database engine
hi,
Can you please elaborate your problem, it seems you are using some api's to fetch data from ACCESS but not defining the type of command object (text, procedure, table...)
Please provide details, we'll help you out.
Thanks.
Posted on Mar 18, 2009
I have a database in mdb format that will not open. When I try to open the file I get an error: The Microsoft Access database engine stopped the process because you and another user are attempting to...
You can use Recovery Toolbox for Access developed for recovering data from corrupted Microsoft Access databases. The MS Access recovery tool is capable of repairing MDB and ACCDB database files.
For more: https://access.recoverytoolbox.com/
Dec 01, 2015 | Microsoft Office Professional 2007 Full...
How to copy a rangewithout scrolling in Microsoft Access step-by-step. Then how to paste the copied information to Excel 2010.
you said time was an issue !
Have a look at this software tool for access database comparison
http://www.fmsinc.com/products/detective/index.html
It costs money but if time is an issue it might be worth buying to get you out of a jam !
Feb 26, 2017 | Microsoft Computers & Internet
What is run time error '-2147467259(80004005)' how i solved it rewati nadan
"The Microsoft Jet Database Engine cannot open the file '(unknown)'"There are several causes for this error message:
  • The account that Microsoft Internet Information Server (IIS) is using (which is usually IUSR) does not have the correct Windows NT permissions for a file-based database or for the folder that contains the file.
  • The file and the data source name are marked as Exclusive.
  • Another process or user has the Access database open.
  • The error may be caused by a delegation issue. Check the authentication method (Basic versus NTLM), if any. If the connection string uses the Universal Naming Convention (UNC), try to use Basic authentication or an absolute path such as C:\Mydata\Data.mdb. This problem can occur even if the UNC points to a resource that is local to the IIS computer.
  • This error may also occur when you access a local Microsoft Access database that is linked to a table where the table is in an Access database on a network server.
Resolution
  • Check the permissions on the file and the folder. Make sure that you have the ability to create and/or destroy any temporary files. Temporary files are usually created in the same folder as the database, but the file may also be created in other folders such as the WINNT folder. For additional information about how to identify which folder does not have the correct permissions and how to configure temporary files, click the following article number to view the article in the Microsoft Knowledge Base: 253604 (http://support.microsoft.com/kb/253604/ ) Microsoft Access 97 database connectivity fails in Active Server Pages If you use a network path to the database (UNC or mapped drive), check the permissions on the share, the file, and the folder.
  • Verify that the file and the data source name (DSN) are not marked as Exclusive.
  • The "other user" may be Microsoft Visual InterDev. Close any Visual InterDev projects that contain a data connection to the database.
  • Simplify. Use a System DSN that uses a local drive letter. If necessary, move the database to the local drive to test.
  • Follow the instructions in the following article to work around this problem: 189408 (http://support.microsoft.com/kb/189408/ ) FIX: ASP fails to access network files under IIS 4.0 and IIS 5.0
Oct 16, 2009 | Microsoft Access 2003 for PC
Retrieving acess data which is password protected thru VB
You will need to use a connection string. But - before you can configure the string correctly, I'd need to know how the data is stored (Access, SQL, ODBC, etc). You can find examples online. Just know that you are looking for "Connection String." Here's two examples:
1. For MS Access (Jet files):
' Set up the connection string.
m_strConn = "Provider=Microsoft.Jet.OLEDB.4.0;" & _
"Data Source=" & strDestDBPath & ";" & _
"Jet OLEDB:Engine Type=5" ' NOTE: Use Type=5 for Jet 4.x.
2. For SQL database:
g_strADOConn = "Provider=SQLOLEDB;" & _
"Data Source=SERVER_NAME;" & _
"Initial Catalog=DATABASE_NAME;" & _
"User ID=mssql_userid;" & _
"Password=mssql_password;"
Apr 22, 2009 | Microsoft Visual Basic 6.0 for PC
What is the compatible database for visual basic 6.0?
Microsoft Access uses the Jet Engine. In VB 6, you can create a data connection using ODBC or OLE DB. Here is an example of OLE DB:
"Provider=Microsoft.Jet.OLEDB.4.0;Data Source=C:\YourAccessDB.mdb;User Id=;Password=;" Good luck
Mar 09, 2009 | Microsoft Press MS Access 2000 and Visual...
Remove error 0*80040e09 cannot update
Mar 04, 2009 | Microsoft Office Standard for PC
Run time error the microsoft jet database engine cannot find the input table or query 'zsms'
hi,
Thanks.
Mar 03, 2009 | Microsoft Computers & Internet
Connection code
_ConnectionPtr con; cn.CreateInstance(__uuidof(connect));
OLEDB cn->Open(L"Provider=Microsoft.Jet.OLEDB.4.0;Data Source=C:\\database.mdb;Persist Security Info=False","","",adOpenUnspecified);
ODBC cn->Open("Driver={Microsoft Access Drive (*.mdb)};;Persist Security Info=False;Dbq=C:\mydatabase.mdb;Uid=Admin;Pwd=;)
I hope this helps.
Thanks, Raphael
Aug 07, 2008 | Wizoo Darbuka
This worked for me in a similar situation; make a copy of the .mdb file in the same folder. Delete the original .mdb file and rename the copy with the name you used for the original. This should get rid of the read-only aspect. Good luck.
Aug 29, 2007 | Microsoft Office Standard for PC
Error#: 0x80040e37
Oct 05, 2006 | InterMute SpySubtract PRO (PP030AA) for PC
Computers & Internet Logo
80 people viewed this question
Top OneRoof Computers & Internet Experts
David Payne
David Payne
Are you an OneRoof Computer and Internet Expert? Answer questions, earn points and help others
