Question about Scotsman Kitchen Appliances - Others
Answering machine repair
Water fills all the time even when its unplugged?
    Sergeant:
  • 446 Answers
Bad water inlet valve
Posted on Apr 07, 2014
My LG TROMM Hot water continually fills even after machine is turned off and unplugged. I have to shut off water supply to stop it.
Unplug the washer removing all electrical power from the machine. Turn the water back on and confirm that water is still entering the machine.
If the condition is true no power to washer and water enters machine it is very likely that the fill solenoid has failed.
this part is not that difficult to replace.
Water Inlet Valve part 5220FR2008F LG Washer Repair
Dec 31, 2015 | LG Washing Machines
Wshing machine keeps filling with water
You probably have a stuck fill valve. This is the part where the hot and cold water hoses connect. Just to be sure unplug the machine and if it still fills Remove and replace the fill valve assembly. Don't forget to unplug the machine and turn off both the hot and cold water supply valves. This is a rather simple repair.
Aug 07, 2014 | Russell Hobbs RH1042 Frontload Washing...
Washer water will not turn off . You have to turn water off & let wash & then turn back on to rinse
Hello, Thank You for using FixYa. I will be helping you today.Unplug the machine if when you turn the water on and it fills with unit unplugged you need a new fill valve. If its unplugged and water on and it doesn't run its the timer
Thank You and please rate my answer if it was helpful..
Jun 14, 2011 | Admiral AW22 Top Load Washer
My washing machine is a hotpoint WF240. It started to overflow with water and spilling onto floor. We pulled it out from wall and found outgoing pump had fallen down, we put it back where it was supposed...
The machine will fill with it connected to the Electrical supply then stop if unplugged providing the fill valves/ water is okay....If it keeps on filling after unpluged then sounds like faulty fill valve,if on the other hand it fills without stopping when plugged in then its your air hose or Pressure switch at fault,Good luck
Apr 06, 2011 | Washing Machines
Colder water wont shut off after filling up the machine, the hot water does shut off.
Sorry to read about your problem, I hope this helps you out.
you have defective cold water fill valve.. just turn off cold water, until you can have repaired
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
Dec 25, 2010 | Roper RAX4233PQ Top Load Washer
Washer fills with hot water even when unplugged
The freezing messed up the fill valve. This is the part that your hoses connect to on the back of the washer. Replace it and you will be fine.
Jan 11, 2010 | Maytag PAV2300 Top Load Washer
Help! My fisher paykel washing machine won't stop filling up!
If the water continues to fill even if unplugged the water valve is sticking and needs replaced. if removing power turns the water off the water level pressure switch is bad or there is something plugging the sensor tube somewhere.
Eric
Nov 22, 2009 | Washing Machines
Water coming out bottom of door on wash cycle.
you have a bad fill valve. unplug the unit from the wall or turn breaker off and tell me if the water still comes in if the answer is yes you have a bad fill valve.
Jun 11, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Water will not stop filling wash basket, even when off
Your water fill (mixer) valve is failed in the open position.
CLICK HERE for the part.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 20, 2009 | GE WBSE2090A Top Load Washer
Drum keeps filling with water when not in use
Hi, You will need a new water inlet valve. the valve has stuck open just enough to let water trickle in. Until you can repair it, just turn the valve off at the wall. If you have not yet found your answer, let me know and I will assist you in getting part#.
I hope this helps. If so, please rate my answer so I know how I am doing.
May 10, 2009 | Frigidaire GLTF1670A Front Load Washer
Kitchen Appliances - Others Logo
23 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
