Question about Pentair IntelliFlo VS-3050 & VS+SVRS Variable Speed Pump -
No power hayward salt system on but no display on
No power hayward salt system on but no display on pump
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Pentair Master
  • 1,448 Answers
Check incomming voltage and switch
Posted on Sep 07, 2014
Hayward swimpure plus no power light led
if voltage to unit and switch check transformer if voltage check display
Mar 08, 2015 | Hayward-Goldline Aqua-Rite Electronic...
Does the salt system affect my pool pump?
Over time it will attack the motor, yes. There are pumps especially designed for salt water pools, with 316 stainless steel parts, and an open section in the casing between impeller housing and motor casing, and seals on either side with a flinger on the shaft. Eventually though the salt will get to the motor somehow. Mind you we are talking years. On my salt water pool, now 23 yrs old, it is on its 3rd motor, which is about 5 yrs old.
May 19, 2014 | Hayward 1.5hp Pool Pump Motor Motor A O...
Hayward rp30 salt chlorinator
You should get a new one
Feb 25, 2014 | Pool & Spa
Wiring two 240 v loads to a switch
threw a intermatic t104 timer, hook the salt gen. to the same side as the motor .. you should have a timer already on the house for the pol pump ? use it the same way .. Jay the pool pump motor repair guy longwood Fl
Apr 06, 2012 | Hayward Pool & Spa
Salt level reading is higher than the actual salt level by about 800ppm. how can i cal the H-40
Thank youfor posting your question here on Fixya.com.The measurement of salinity of water in some salt water chlorination systems is not calibrated very well. This is especially true when the device has been in use for some time. The value is not used in the system except to display it and to determine if it is way too low or way too high. If this occurs then it shuts off the chlorination.
If you want to do something about this value then you could callthe Hayward technical support at 908-355-7995and they might be able to help you figure this issue out. I hope this helps.
Ifthis answer does not fix your problem, please comment with additional detailsprior to rating the answer. Positive feedback is appreciated once your problemis solved! Thank you.
Aug 25, 2011 | Hayward Pool & Spa
How do you clean the cell on the salt water system
Unplug from power then remove from system and soak in a 50% solution muratic acid and water for five or ten minutes the rinse with a high pressure nozzle on your hose. Repeat till it comes pretty clean. Being sure plates are free and loose from one another.
Sep 13, 2010 | Hayward SAND FILTER, PRO SERIES
Ph level for saltwater intex system is too high and water is a bit cloudy what do I do?
Get your water tested at your local pool store and they are going to tell you to add Muriatic Acid. Follow their instructions carefully, hopefully they are a good company. Salt water systems tend to drift the pH slightly basic (high) because of the offgasing of Hydrogen ions in the water. Hayward Mineral Springs salt has pH and alkalinity buffers in the salt already, depending on what brand of salt you are using, that might be your problem.
Jul 07, 2010 | Intex Automatic Salt Water System for ...
Hayward pump hose and intex pool
Im thinking that hot glue would not harden completly in a direct sun situation not to mention the potential mess
What I did was go to my local hardware store and bought rubber o rings ( sorry dont remember what size) put them on the fitting slipped the hose over it and clamped on top of that area. Has been fine all summer
hope you figure it out
Aug 04, 2009 | Intex Automatic Salt Water System for ...
Pentair IntelliFlo VS-3050 & VS+SVRS Variable Speed Pump -  Logo
69 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
