Question about Magnavox H2160MW9 HDD Recorder
M-F recording every Sunday resets to default time (2009) and recording fails
How do I reset the date and time on Toshiba Rd-88dtkb hid recorder? It shows Wednesday but today s Sunday
My Toshiba is today showing the correct date, so yesterday's incorrect date must have been a glitch, perhaps in the original programming of the chip.
Mar 01, 2015 | Toshiba Televison & Video
How do you set the clock
I'm afraid you will need to contact the manufacturer.
Dear customers,
if your emails were rejected by Tech.support@tgegroup.com
pls try another email address TGE.customer.service@gmail.com
if you still failed to reach us, pls try the on-line service by MSN: TGE.customer.service@hotmail.com
our on-line service time is(EASTERN TIME):
Monday~Thursday 8:00~9:00 am
8:00~9:00 pm
Sunday : 8:00~9:00 pm
Good luck
Apr 12, 2011 | Audiophase CDT432M Personal CD Player
The date is showing as Sunday 1 November 2009 instead of Sunday 4 October 2009. How do you change it?
Problem fixed. I removed the battery and allowed the phone to do an auto adjust for time and date when it was turned back on.
Thanks anyway.
Oct 04, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Can no set date on VCR past 2008
dig around for old calendars or maybe the internet. compare dates. like for example. (my birhtay) july 12 in 1998 was a sunday. in 2009 july 12 was also a sunday. so u know that all dates in 2009 will line up with 1998. so in setting the vcr, make like its 98.
May 03, 2009 | Televison & Video
Burn errors cant get drive to write
It looks like from error codes that yoi may have a hardware error, or a disk format problem, if this is only burning problem you have on pc and it worked before, then uninstall and reinstall Nero, info gathered from here,
http://www.isobuster.com/help.php?help=305
sense code 5 ASC 2c= 5 / 2C / 00 COMMAND SEQUENCE ERROR
5ASC2700=5 / 27 / 00 WRITE PROTECTED
Please give good rating if this helps you or points you in right direction, thanks
Apr 12, 2009 | Computers & Internet
My DVD-RW has stopped burning.
Try uninstalling the burner using the Device manager and letting Windows reinstall the drivers on reboot.
Right click on My Computer then Properties > Hardware > Device Manager > click on the '+' next to DVD/CD ROM drives, right click on the drive and 'uninstall'. Reboot and Windows will re-install the drive.
Mar 15, 2009 | Pioneer DVR-112D DVD RW Dual Layer Burner
Date & time.
To reset system time you must be at the attendant station and with the handset cradled:
Dial: #06 4321 1 # (4321 is the default password)
Then:#55 YY, MM, DD, W, HH, MM, # time will be saved and phone will go back to normal operation.
Naming convention:
YY - Last two digits of the year
MM - Month (1-12)
DD - Day of month (1-31)
W - Day of Week (monday = 1.... sunday = 7)
HH - Hour (24hr format)
MM - Minutes (00-59)
ex: To set the time For Monday, Jan. 5, 2009 at 8:31pm I would enter: 09 01 05 1 20 31 #
Good Luck,
BB
Dec 02, 2008 | Samsung Prostar 816 Phone
File failed message
The same thing happens to me when I try to record thru the "A/V in jack". It appears (my first thought) that the camera is trying to record to the internal drive and it runs out of memory really quick. But then, when I play it back, (the small 15 seconds or so) the audio and video are not sync'd. Most of the time at least. Very inconsistent. It also locked up and froze for me too. I had to remove the battery to reset it. Once or twice it recorded normal, (once when I reset the default settings and another time just out of the blue) - I thought I had it solved but it went back to "File Failed" after about 17-20 seconds of recording on the next record session.
I have the thing packed up ready to take back, but am looking for a solution so I can keep it..
Jul 26, 2008 | Aiptek A-HD 720P Flash Media Camcorder
Hard reset
If you put a disk in and all it does is click several times, it's more than likely the spindle motor. It's best just to replace the DVD drive. Recording in the default high speed mode tends to cause the spindle motor to fail over time. Usually in a very short period of time. It's best to set your record speed to the standard mode to avoid premature failure of the spindle motor.
Mar 14, 2008 | Panasonic DMR-EH55 DVD Recorder/HDD...
Magnavox H2160MW9 HDD Recorder Logo
16 people viewed this question
Top Magnavox Televison & Video Experts
Demonic-2011
Demonic-2011
Tom Chichester
Are you a Magnavox Televison and Video Expert? Answer questions, earn points and help others
