Question about Refrigerators
Our 14 year old KitchenAid Superba side by side refridgerator (Mondel KSRS22FGBT01) is not cooling the top half of the freezer section. Bottom half seems to be able to keep cold - but top half doesn't. (Ice make melted isce and made a long icicle down the length of the freezer... Any suggestions? Thank you!
    Scholar:
  • 50 Answers
Do you see any ice build up on the back wall of the freezer compartment? You probably have one of the following problems: A failed defrost system, meaning the defrost timer and/or element has gone out and your evaporator coil is frozen over; you are low on freon and this too will cause your evap coil to freeze over until the freon drops so low all cooling stops; or there could be a clog in the capillary tube which is the very small diamiter copper tube that carries the condensed liquid freon to the evap coil. Unless you have gauges, a licence to buy freon and service valves (or a buddy with such) you are limited to what you can do. Here is my advice:1. unplug the frig and let it defrose over night, unplug the frig and empty the freezer to remove the back cover to look for ice, a frozen fan and if so get your hair dryer out and melt the ice so you can test the fan and the defrost element (you will need a volt/ohm meter to do the element check. You can do it.
If you need further help, reach me via phone at https://www.6ya.com/expert/steve_24d988f3507f7480
Posted on Oct 13, 2013
Testimonial: "Thank you. Today I went in and pulled the back cover in the freezer. There was some ice buildup on the bottom third of the coils. The fan was struggling so I gave it some help, then lubed it and replugged back in and it spins great. Use the hair dryer and melted ice buildup, the put it back together and place a plastic bowl of water in the bottom of the freezer and on the top shelf. Now (6 hours later) the bottom bowl is frozen but not the top one. Plus there's ice beginning to build up again on the bottom of the coils... Does this sound more like the defrost system failing or freon problem? Or? Thank you so much for your assistance. I'm doing this for my parents who are up in age..."
  • 1 more comment
  •  Steve
    Steve Oct 14, 2013
    Your welcome!! Now, you said ice was reforming on the coils. It is important to know this: (and I am making a presumption) if the cover was not reinstalled the freezer will not work properly. You may have reinstalled the cover then again removed it to see. If that is the case and ice fromed that quick, you are probably low on freon. If the cover is not in place the air flow is messed up not properly circulating air across the coils. This will cause a temp gradient with it being colder on bottom and the coil will not be slightly warmed by the circulating air. But if the cover was inplace then your freon level is low and that actually causes the coil, or depending on the level of freon the first portion of the coil, to freeze up because ALL the freon is "Flashing" in a small area instead of across the entire coil.
  •  Steve
    Steve Oct 14, 2013
    meaning you have a leak and a low freon charge.
  •  Steve
    Steve Oct 15, 2013
    What Robert Samples told you is true, IF you have a "failed defrost system" as I mentioned at the start. However I believe that is less likey your problem if you saw ICE on the coil an not "some frost". But I wouldnt have you do what Robert suggested unless I was confident you had the technical skills. There is some hazard involved in that maneuver, in my humble opinion. However, I am not Gods gift to the refrigerator world. Be careful. Let me know as I learn every day.
  • 1314 Answers
SOURCE: FRIGIDAIRE FRS20ZRGD7 (SIDE BY SIDE) WARM FRIDGE/ COLD FREEZER HELP!
look open the freezer door pull the lower kick plate off look for a small little hole there its a mechanical timer model should be close to the wheel in that hole will be a plastic piece open the freezer door you will hear the fan running in the freezer take out the four or five screws on the lower panel where you keep seeing the frost and remove it you will see a silver honeycomb looking piece that's the evaporator on one of the tubes will be clipped a silver dome looking piece with two wires on it that's the defrost thermostat now turn the timer with a screwdriver that's the piece in the little hole slowly to your right till you hear a click and the fan stops in the freezer now as your turning it it will make a ratchet sound you want the click and the fan to stop look at your watch and note the time then wait about 5 minutes and look at the heater to see if its on if its all frosted up the frosted should look all watery if the heater is on then just let it run if not then reach up and turn the freezer control to the off position then un plug the two wires on the defrost thermostat and take the two wires that you unplugged the thermostat from and plug them back together and turn the freezer control back on and wait stay there and watch the heater come on let it defrost the evaporator if the heater comes on when you do that .that means the thermostat is bad if the heater comes on without you having to by pass it that means the timer is bad if you do all that and the heater does not come on then the heater element is bad now its going to get red like an oven and pop and sizzle but don't let it freak you out now if you had to by pass the thermostat and the timer cuts the compressor on before the frost is all clear just turn the timer around again till the fan cuts off and the heater will come back on if you by passed the thermostat then when all the frost is melted then reach up and turn the freezer control back off and reconnect the thermostat.Now after about 30 mins after turning it off the timer should cut back on if its not bad when you change the timer back out the two screws reach under the fridge and turn the timer and its shield till the screws are in the removal position when the timer is loose remove the shield and unplug the timer plug your new one back in then put the shield back on and back where it goes now id recommend changing both the timer and the thermostat as they fail pretty close together the stuff i described above is to make the unit defrost to save your food with out having to use your hair dryer also when all the frost is melted at he bottom of the evaporator on the right hand side is a hole in the cabinet that has to be clear of frost for the fridge to cool properly now any time during this defrost technique if you have a problem turning off the freezer cold control will turn off the defrost system1.gif too if i can be of help or you need to know something just reply to this post
Posted on Mar 30, 2008
  • 77 Answers
SOURCE: I have a ed5fhgxkq00 side by side Whirlpool refridgerator that stopped cooling.
If the compressor has a fan next to it, be sure it is running. if the relay is clicking every few minutes it may need to be replced. contact local parts distributor.
Posted on Jun 15, 2008
SOURCE: kitchenaid superba icemaker leaking/freezing in freezer section
Thank you, I am going to go check right now
Posted on Nov 09, 2008
appldoctom
  • 311 Answers
SOURCE: amana side-by-side fridge freezer only cold at the bottom
yes the evap fan in the frezer should be running when the compressor is running[it may not for a minute or so as it starts up.Amana's are good for the connectors at the evap fan motor comming apart.the connectors are white and will look like its together but when you pull it will come apart.i would always cut the connector out and use a wire nut so wont happen again.if any other questions please email thru FixYa and i will be glad to help. God bless ,tom
Posted on Jan 30, 2009
  • 531 Answers
SOURCE: GE Profile Side By Side Melting Ice but still freezing lower half
you have adefrost problem
Posted on Apr 02, 2009
The top half of the freezer side is not freezing. The frig side is cool but not really cold.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 19, 2010 | KitchenAid Superba KSRS27CN Side by Side...
Kitchenaid superba side by side top is too warm,
The defrost cycle is suppose to be automatic on this model. To see if you have a defrost problem take the lower container out of the freezer, and empty the bottom shelves enough to see the back panel inside the freezer. If there is a build up of frost on the panel or the slots in the lower back panel the automatic defrost is not functioning. The most likely suspect is the ADC or automatic defrost control. This control runs about $120.00 and is located in the console of the fresh food section (top).
If there is no frost check to see if the fan in the freezer is running. If the fan is not running you have a failure of the fan motor which is a little less expensive but a bit more challenging to replace, the shelves, the shelf slides and back panel of the freezer have to come out to replace this motor.
Apr 18, 2010 | KitchenAid Superba Architect KSCS25INSS...
Refrigerator side not cold
if you have frost build up on rear wall of freezer section then your unit is not going through defrost. its either defrost heater, defrost thermostat (which are both located on evaporator) or defrost timer
Jun 24, 2009 | KitchenAid Superba 21.6 cu. ft. Top...
Upper half of refrig/freezer not cooling
The First thing I would check do you ever hear a fan running inside the freezer . No Fan could cause that. if that is running now check the back wall of the freezer is there frost building up on it if there is then your unit is not defrosting and that could also cause that let me know what you find and I can help from there.
Apr 03, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water stopped and freezer not cooling
you probably have a bad evap fan motor in the freezer compartment. when this motor goes bad it doesnt distribute the cold air around causin subfreezing temp in the bottom of the freezer it then migrates into the fresh food compartment. you can order the motor by the mod# of your refrig and it is fairly easy to change yourself. good luck peyton
Jan 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
Drip/moisture tray inside base of kitchenaid superba refridgerator
need mor info,is there water in the bottom of your frig. or freezer,let me know more-mike
Oct 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
8 year old Kitchenaid not cooling
the floor has no control over the fridgr or the way it works.you said its 8 years old youve already replaced the compressor once so maybe it time for e new fridge.
Sep 01, 2008 | KitchenAid KSRG22FK Side by Side...
Side by Side, Fridge is freezing at lowest setting
Is you fan in the freezer working I would check it first . if not check for power to the motor ... if you have power replace motor...
Sep 01, 2008 | KitchenAid Superba Architect KSCS25INSS...
Freezer too cold frosty, and refrigerator section too warm
Sounds like a defrost problem if the evaporator is frozen over. If it's just Ice blocking air transfer on a top freezer model, then it's a blocked defrost drain.
Sep 10, 2017 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Side by side refrigerator section is not cooling the freezer is over cooling
SINCE THE FRESH FOOD SECTION GETS ITS COOLING BY AIR CIRCULATION FROM THE FREEZER, THERE MUST BE A RESTRICTION IN AIR FLOW SOMEWHERE. CHECK THE FREEZER EVAPORATOR AND FAN TO BE SURE THAT THE FAN IS RUNNING, AND THE EVAPORATOR IS NOT RESTRICTED WITH FROST. CHECK THE DAMPER OPENINGS FROM THE FREEZER SIDE TO BE SURE THEY AREN'T ICED OVER. IF IT IS AN ELECTRONIC CONTROL, CHECK THE THERMISTOR CIRCUIT FOR PROPER RESISTANCE. TECH SHEET INSTALLED BEHIND THE TOE PLATE SHOULD GIVE THAT INFORMATION.
Mar 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
100 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
