Question about Ridgid Saws
My RIDGID Rapid Max Twin 18 volt charger, all it will do is flash red "Evaluate", and not charge any of my batteries.
    Master:
  • 969 Answers
Either bad battery or bad charger. Suspect bad battery, replace battery.
Posted on May 25, 2014
3 Suggested Answers
  • 885 Answers
SOURCE: makita battery charger wont charge
If both lights on the charger are flashing it is indicating you have a bad battery and the charger will not charge the battery. The charger has circuitry that tests the battery and if it 'thinks' the battery is defective it will not attempt to charge it. The only way to verify whether it's the battery or charger is to try charging your battery on another charger or try charging another battery on your charger. Most of the time it's a bad battery.
Posted on Aug 06, 2012
H2_Brad
  • 425 Answers
SOURCE: will a ryobi 18 volt charger replace a coleman powermate battery charger?What's your problem?
They look different in their shape where the battery goes so I would say no. To be safe always use the charger from the same manufacturer. There are a few different types of batteries too so it is always best to use the model number of your original charger to search for the replacement.
Posted on Aug 25, 2012
Red light flashing on charger
A red light indicates the charger is charging the battery, an amber light means it has switched from fast rate charging to trickle to keep the battery topped off, and green would mean the battery is completely charged. But don't be fooled waiting for green, many times the charger will only be on green for a moment before changing to amber and keeping the battery topped off.
Flashing can be a sign of a problem on some chargers.
A rapid flashing red can on some chargers indicate a bad or shorted battery, or a bad battery contact in the charger itself. If in question, try a different battery on the charger or compare with another charger to determine if the blinking is normal.
Best regards.
Nov 19, 2013 | Motorola htn9042a charger,120v,single unit
Makita battery charger wont charge
Aug 02, 2012 | Makita DC18RAX230 230-Volt LXT Lithium-Ion...
My charger is flashing red when i place the battery in it
Ridgid charger lights read as follows: Solid red; charger has power. Flashing red; charger is evaluating the battery, checking if it's cool enough to charge and if it is in chargeable condition. If the battery is hot, i.e. just came off the tool after extended use, it won't charge the battery until it cools down. Flashing red & green; the battery is defective and the charger will not charge it. Solid red & flashing green; battery is charging. Solid green; battery is full.
Dec 07, 2010 | Ridgid Drills
CHARGER PROBLEMS
The flashing light indicates the charger is charging the battery (or attempting it) and if it never finishes charging you should try to charge a different battery, if the charger charges that one ok then the battery is bad.
Jun 18, 2010 | Dewalt 18 Volt Compact Drill Kit
What does it mean when a household battery charger flashes red then green? The charger is a SYNERGY DIGITAL rapid quick charger. I'm trying to charge new AA Energizer Lithium batteries.
When the charger light is changing from red to green that is a indication that it is charging the battery. When the charge is complete the light will stay green until the battery is removed or the charger is unplugged.
Jun 06, 2010 | Energizer Rechargable Battery with Charger
My new Black Max 24v drill charger will not charge the battery
You indicate that the drill is new. I'd suggest you return it for a replacement. Seems to be a defective or wrong charger. If you have problems and If you paid by credit card call the card company and have them stop payment on that charge.
Feb 21, 2010 | Mx Black Max 24v Cordless 1/2 Inch Drill /...
When charging battery flashes red then stays on red.how long should it take to change to green?.its a dewault9130 18 volt
it doesn't change to green, the solid red light means it is fully charged, there should be a legend on the front of the charger to help you with this. If it flashes real fast the battery is malfunctioning and slow flashing is charging and again solid is fully charger.
Oct 03, 2009 | Dewalt 7.2-18.0 Volt One Hour Charger
Batteries don't charge. I have a new battery, and neither of the old or new batteries work in the charger. I get flashing lights only, sometimes red, sometimes green, but in the end, the battery isn't...
Dust getting in the charger is a problem, Try blowing it out with a moisture-free dust remover, found at most any store. Green flashing means improper power, due to dust or power from the outlet, try a differant wall outlet. Red flashing means the charger or battery is to hot and must cool down before it will charge. The charger will not charge a battery if the lights are flashing. Solid Red light means it is charging and solid green light means it is charged. Plug the charger in first before putting the battery on the charger. If the charger has been droped or hit the floor the coil inside could have broke loose and dammaged the charger requiring it to be replaced.
Jul 11, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
GP 360 Radio Charger
On a Motorola charger, when the battery is charging the light should be a constant red (or amber depending on the charger). When the charge cycle is complete the light will change to solid green. Sometimes the solid green time is brief, as the battery will begin to lose charge, and the charger will go back into trickle mode and change once again to red (or amber). In most cases, a flashing light indicates a problem, such as a bad or shorted battery, an incorrectly seated battery, dirty battery contacts, or a bad connection with the battery. (Note: Batteries last 18-24 months typically. Check your date code for the age of the battery.)
There were several chargers made for the GP360, including but not limited to a 60-minute charger, a 90-minute charger, a 10-hour trickle charger and a 6-unit gang charger which would be a rapid rate, either 60- or 90- minute. If you would supply your charger's model number we could tell you which one you have.
Nov 02, 2008 | Motorola HNN9628A Two-way Radio Battery
Saws Logo
261 people viewed this question
Top Ridgid Saws Experts
ken skalski
John Trevino
Are you a Ridgid Saw Expert? Answer questions, earn points and help others
