Question about Coffee Makers & Espresso Machines
We have a Schaerer bean to cup coffe machine and the problem we have is that the water does not stop flowing when the machine is on. Pls help.
    Master:
  • 492 Answers
Bad water sensor.
Posted on Oct 17, 2013
Hello, i have a krups xp7220 and i have two problems with her.
A common place for a leak under the machine is the barista seal that goes in the bottom of the boiler around that eject rod. Barista seal part number is MS5002202, Seals on the tamping piston are MS5002040 (there can be 1 or 2 of these piston seals) If fixing the leaks does not fix error 6 then I expect it will end up being the distributor. Part number MS2A01500
Jun 17, 2017 | Krups Coffee Makers & Espresso Machines
I need the user manual
Dear friend: I bought mine in 1996 in Orlando. The user manual was so simple with some b/w pictures.
1.- Heat the water.
2.- Over one cup place the thin filter that match perfect and is the bigger one of two elements supplied.
3.- Over the thin filter place the coffe deposit the one that have small holes at the bottom.
4.- Fill the deposit it with coffe for one cup and fill over with hot water slowly from one cup trying not to overflow.
5.- Wait untill the water flows down and your cup of coffe is ready.
6.- For another cup repeat this procedure.
Is a bit long but you can enjoy a room coffe for two.
Its what my experience was. Excelent when you don't find where to boil a cup of water. Now mine machine burns suddenly the heater and I am trying to find the replacement part, but probably should be and adaptation of it.
Good luck. The manual is not much than what I told. Not much manufacturer info. A pitty for a well designed help machine.
Claudio.
Apr 03, 2013 | Franzus TJ-10 Coffee Maker
Just picked up a new Franzus TJ-10 Coffee Maker at a garage sale, but it has no instructions with it. Can you please tell me just how to operate it. Appreciatively, Vincent
1.- Heat the water.
Claudio.
Aug 07, 2011 | Franzus TJ-10 Coffee Maker
Will grind the coffee beans but no water passing
Either the grind is too fine or the brew unit is blocked at the screen.
Feb 05, 2010 | Gaggia Titanium Espresso Machine
How do I clean and descale my Schaerer siena 1 espresso maker. We have lost the manual.
Remove the coffee grounds container & leave it out.
Press & hold the cleaning button for approx 5 seconds, you will then see the words " Caution Hot"
Then push the cleaning button once (the one with the plus sign on it) This will start the descaling....I have a Siena-2 & I too could not figure out how to descale, I sent an email to schaerer who sent me an pdf with these instructions which are close to what I was doing. They said it sounds lie I had an older model version - They were very helpful.
remo.weber@Schaerer.com
see the guy who helped me - email above.
Jun 05, 2009 | Schaerer Siena Espresso Machine
Out of 10 cups of coffe maybe i get 4 cups
Try to make a cup of water (the) and see if you can make a full cup.
Try to take out the brewing unit (central unit) and wash it in warm water.
/Best regards
/Mirran
Jan 29, 2009 | Saeco Incanto Classic Espresso Machine
Water does not blend with coffee
When you mount the grinder back, do you turn it so the red mark fit together?
Try to check the brewing unit, on the top off the brewing unit you will see a little pin. Take it out and make sure this is clean and put it back again.
/Mirran
Sep 02, 2008 | Saeco Incanto Classic Espresso Machine
Grinder runs with NO beans inside
Fill beans before they run out!
If you hear the grinder running empty, press the same button you pressed to start making coffe to cancel the current cup -or, if some beans were ground, stop the water a bit earlier to make a shorter coffe using the same method (press the button you pressed to start the cup). The auto-detect of beans missing is a very minor and largely useless feature.
Jul 29, 2008 | DeLonghi EAM3500 Espresso Machine/Coffee...
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
