I need a FM1 QRTUZH boiler time switch But it is to replace a 3V DC one already existing. Can't find one anywhere only 240V. Please help it's getting cold here!!!
dave1645
  • 834 Answers
SOURCE: I need a replacement switching power adaptor
go to Bestbuy and buy a universal
Posted on Sep 28, 2009
  • 3238 Answers
SOURCE: gas boiler problem on restart. new themocouple new
Hi sounds lke thermostat problem adjust anticpator arn on thernmostat see if that helps
Posted on Feb 27, 2010
Testimonial: "yea it went beyond thermostat to the aqua stat relay good starting point had profeesional sevice call "
  • 6 Answers
SOURCE: I bought the Sony ICF-CS10iP Clock Radio in
It will say on the adapter which voltages it is compatible with.
If it is not listed, be sure to get a voltage converter from an electronics store.
Posted on Mar 12, 2011
  • 14 Answers
SOURCE: My Acer 5630, suddenly cannot
if you already tried the classic solutions with presing the power button for 20-30sec after you removed the battery and the charger, and no succes then try that:
http://www.fixya.com/support/t4270312-acer_extensa_5630ez_won_t_turn
Posted on Apr 29, 2011
walterkunesk
  • 683 Answers
SOURCE: Our dometic RM 2350caravan fridge
Hi, you have a freon leak in your system, with the caravan refrigerators they use amonia as a cooling media. You need to either have a service person the knows this system or purchase a new one. thanks.
Posted on May 18, 2011
Where do I get a power cord for a euro-pro mod l 9130C
When buying such power adapters, you typically need to watch for:
  1. DC voltage - in this case 19V. This needs to be the same.
  2. DC amp rating - since your adapter is rated at 6.32A, you need a replacement that is rated at a minimum of 6.32A, but there's no harm in going higher. Your device will only draw what it needs.
  3. DC plug polarity. Most are center positive, as is yours.
  4. DC plug size. This is defined by inner and outer diameter. In your case, it's 5.5mmx2.5mm
  5. Input voltage. You haven't mentioned your region, but it's a good idea to get international power adapters that accept 100-240V.
You've stated that you prefer to use the existing power cord, but this is an unnecessary constraint - it's better to use the power cord that comes with the replacement adapter
Sep 20, 2017 | Euro-Pro Sewing Machines
Worcester 35sdi ii, cost of a replacement please, existing boiler approx. 12 years old
Impossible to say as you will need some one to see the job to give you a price . you can get boiler price on line , but its time and material you need from a installer .
Mar 21, 2017 | Heating & Cooling
Trying to purchase adaptor, only descr in manual is 100-240v~,50-60HZ,400mA. Marlin asking me what is voltage output which I cannot see anywhere?
400ma is not a lot of juice. Does the BP monitor have a battery compartment? IF so, just add 1.5 volts for each battery, rounding up. The BPM should have a number itself, where the adapter plugs in, and a "+" with a line pointing to the middle or the outer ring indicating polarity.
In general
2 batteries= 3V-3.7V rated adapter sometimes 5V
4 = 3V, 6V,
Mar 24, 2015 | Homedics Health & Beauty
Hi, I have a Sebo premier and the brush wont work or the green light come on. Can anyone tell me if you should get 240v on the connector from the main vacuum body to the brush head? I have tested this and...
I understand 240v to be 240 volts. of electricity- no vacuum should have 240v. that amount is used on elect. stoves, air conditions,welding machines and large electic appliances. Check the belt drive and the manual for the green light operation- I still don't understand the 240v deal.
Jan 06, 2014 | Sebo Felix Classic Bagged Upright Vacuum
Cannon ir 3025 photocopier displays error code 805-000.
E805
There is a fan error.
0000
Failure in heat exhaust fan (front) (FM2)
When lock signal is detected for 5 sec while the fan is stopped.
- Replace the heat exhaust fan (front) - Replace DC controller PCB
0001
Failure in rotation of heat exhaust fan (front) (FM2)
When lock signal failed to be detected for 5 sec while the fan is driven.
0002
Failure in heat exhaust fan (rear) (FM1)
- Replace the heat exhaust fan (rear) - Replace DC controller PCB
0003
Failure in rotation of heat exhaust fan (rear) (FM1)
there are 2 fame in the right door if you just look on the right door you will see 2 square vents
get in there and remove the fans and clean them out with canned air and apply a small amount of oil in the center then flick the fan to make sure it spins softly
reinstall and try it should fix the problem but please go ahead and order a new fan the part number is on the fan itself in the sticker it will say FK2-????-????
Oct 30, 2013 | Office Equipment & Supplies
Need to buy a charger for my Hyundai S900-charger 100-240V 50/60Hz 9v-2.5A, saw on Amazon you had thisCostMad 7 / 6 Way 1.5A 1500mA max. AC to DC Universal Universally Multi Voltage 3V / 4.5V / 6V / 7.5V /...
You can buy car accessories here,they are one of the best electronics wholesales in China. http://www.ankaka.com/Wholesale-car-accessories_c10005
Feb 18, 2013 | Televison & Video
I have a Powermax 155 boiler that keeps losing pressure. Most of the time, I can usually work around this by closing the tap in the boiler until the pressure rises, but it's not working this time. I...
I would first check the switch on the front to ensure it is set for CH & Water. Push bottom of the switch, check you have a pressure of 1 bar on the gauge to the left of the front panel. If not, top up until it gets to 1 bar. Ensure a demand is being called for (the timer is asking for heat) by pushing the CH button until the grey line is alongside 24 hr. then check if the central heating pump vibrating. If still not come back to me for more info
Dec 13, 2010 | Heating & Cooling
Power coverter to scanner failure.which unit should i buy? present one 240v 50/60hz.0.4A. output 12v.dc.i.25A
I just found my Canon 5000F scanner to have a power supply outputting 3V DC instead of 12V DC. I replaced it with a 12V DC Power Supply from Tandy rated at 1.5 amps. I had the scans getting darker by the day and sometimes completely black. Now I have great scans again. Just test the voltage at the plug that supplies the scanner for a healthy 12V DC with a multimeter.
Jan 20, 2010 | Canon CanoScan 5000F Flatbed Scanner
DC Power supply specifications
here is the info you need...
Input Power 100~240V, 50~60Hz
9V DC,1A Max
Hope this helps...
Feb 09, 2008 | Computers & Internet
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
