Question about Watches
Stauer compendium hybrid watch digital will not run, analog seems to be ok
SOURCE: analog clock not in sync with digital clock
This problem may be due to your analog hands being improperly zeroed. To find out, try this: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero. If you do this and your minute hand points to 1 o'clock, or five minutes, you will know that this is the problem. If this is the problem, you can can correct it by zeroing the hands as follows: 1. Put the watch in chronograph mode by rotating the crowon in its normal position to "chr" 2. Pull out the crown two clicks. This should cause all of the hands to point to zero, or close to it. You should also notice the letters "HR" in the lefthand digital display. This allows you to move the hour hand by rotating the crown. If the hour hand is not pointing at 12 o'clock, rotate it so that it does. 3. Push the top button once. The letters "MIN" should appear in the lefthand digital display. This allows you to move the minute hand on the large dial, and the minute and hour hands on the small UTC dial. Rotate the crown so that the minute hand points directly to 12 o'clock. 4. Push the top button again. The letters "SEC" should appear in the lefthand digital display. Rotate the crown to point the second hand directly at 12 o'clock. 5. Push the crown back into its normal position. Set the digiatl time and date in your tie zone, and your analog hands should match the digital read-out. If the zeroing of the hands is not the problem, I don't know what is wrong with the watch.
Posted on Sep 27, 2007
SOURCE: Casio G-Shock G-7400 Watch
Thought this would happen when I sent you a request to help me simply change the analog time on my watch.
Your repsone to free suppor tis asking me to enter into a arrangement that requires payment.
I've solved the problem from another site free of charge.
I'm very disillusioned with the way you promote your site and will definitley recommending to others to stay clear of it.
COmes across as we can help you free of charge but bottomline is that this won't happen.
Onlty wanted to know how I change the analog time on my watch - could go to the Jewler to do this free of charge - thought the internet would help but your company has prolonged the support immensely.
Regards,
Paul Stirling
Posted on Apr 11, 2008
SOURCE: My Citizen Skyhawk Eco-Drive JR3000-51F Wrist
I had the same issue, and was able to reset it doing the following:
1. I let it recharge for at least a day in bright sunlight
2. I turned the selector to "CHR"
3. I pulled the crown all the way out.
4. I held both buttons down for 5 seconds (don't know if this was what did it.
5. I pushed the crown back in.
It did some funky hand movements stuff and then started off working.
Posted on Aug 27, 2009
  • 61 Answers
SOURCE: digital/analog watch... analog part doesn't run
A lot of times they hide a second battery for the analog display under the larger battery used to run the digital display. Also, the 2025 may not have a full charge.
Posted on Oct 17, 2009
  • 2501 Answers
SOURCE: I want to send my atomic stauer watch for repair.
Go to "Stauer.com" and at the bottom of the page you will find "customer service".
Click on this and your customer support details will appear.
Posted on Mar 20, 2010
Hour, minute and second hands don't work, why?
Yes, there are two batteries in the 19093 (Compendium Hybrid). The first battery (CR2025) is visible as soon as you remove the back cover plate. The CR2025 controls the digital half of the watch and the back light. The second battery is underneath the circuit board that the CR2025 is connected to. There are 6 small screws that will need to be removed to lift the circuit board and gain access to the second battery. The second battery is an SR626SW.
Aug 22, 2014 | Watches
Casio CPW-500H-1AV analog watch not working
That certainly wouldn't hurt - be sure you use good new batteries.
Aug 06, 2014 | Casio Watches
How do I remove a link from the Stauer Colossus Hybrid Chronograph
Removing a link from the wrist band of the Stauer Colossus watch is a task that requires some mechanical talent. The links are held together with pins. These pins need to be pushed out. I strongly recommend the purchase of a "Watch Band Link Pin Remover" (got mine on eBay for $7). Prepared with this tool, the steps are as follows.
a) Separate the wrist band at the position where the strap and latch are held together. Careful! This pin is spring loaded.
b) The links that can be removed are marked with an arrow on the interior side. The pin should be removed in the direction indicated by the arrow.
c) With the previously mentioned tool you will be able to perform the hardest part, namely push out the pin by 3/16". In the image below note how the pushed out pin goes into the groove of the tool.
d) Use a small screwdriver or a punch with diameter of less than 0.07" (or 1.8 mm) in order to push out the pin completely (see second picture).
The push pin of the tool can be reversed which is helpful for re-assembly. I recommend smoothing the one end of the pin with a small file or sandpaper. This way the pin enters easily into the hole of the lower section. Else you run the danger of bending the link if the pin is not correctly positioned and you apply too much force.
Oct 24, 2012 | Watches
Stauer watch will not work after battery change.
I have no ideal how old your watch is nor where you had the battery changed. Ideally I would take back to whom changed the battery to see if it was a good battery. If your watch is older it may be time for an adjustment.
Contace Stauer for further assistance at link following:
http://www.stauer.com/customer_service.asp
Good luck.
Aug 21, 2010 | Bulova Watch
I want to send my atomic stauer watch for repair. Could not set watch when newly received. Where do I send Stauer watch for repair?
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
May 12, 2010 | Fossil Watch
Removing Links from the Stauer Atomic Watch band
Click on my profile (escapement), then click on Tips and Tricks. There you will find tip how to add or remove links. Rate me, please .
Apr 08, 2010 | Swiss Stauer Deep Dive Watch
Mar 20, 2010 | Bulova Watch
How to set the time on a stauer atomic watch
i have a stauer 33 watch i can not get the pin to come out so i can set the date and time it is like it is stuck or am i not doing it wright. thanks for your help
Oct 21, 2009 | Bulova Watch
Digital/analog watch... analog part doesn't run
Oct 17, 2009 | Watches
Watch goes slow when wearing it but keeps time when not wearing it Because I started having a problem with an old reliable Acqua quartz analog watch running slow,  I replaced it with a new Timex quartz...
There is nothing wrong with your watch. Probably it's the one measuring heart rate and pulse (heart beats per second).
Use your users manual to set the watch.
By the way: Timex is one of the worst watch producers.
Jan 07, 2009 | Watches
Watches Logo
253 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
