Question about Frigidaire Dryers
My name is Maurice, I have a frigidaire gas dryer model#glgq942cs0 the problem is when i select normal cycle which is 55 minutes, the dryer runs for 5 minutes then it jumps right away from 50 minutes to 27 minute. How can I fix this problem? please advice. Thank you
  • 4 Answers
Check to see if there is a worn cam inside the control panel.
Posted on Apr 24, 2009
My dryer turns off within few minutes of turning on. i get error code 55. what does that mean?
google: frigidaire dryer "put model here" error code 55. I couldn't find anything. So there's more to the error code than 55, or it is model perhaps year dependant.
Feb 25, 2015 | Frigidaire Dryers
Turns on, no heat, stopas after about 5 mins and all lights start blinking.
Good Afternoon Amanda,
I understand that your Frigidaire Affinity dryer, model# FAQE7001LW, is not heating as well as only running about 5-7 minutes of the cycle before shutting off. There are a couple things to check.
    1)The gas supply valve is not open. Check to make sure that the gas valve is open.
    2)The dryer does not have enough air supply to support the burner flame. Check with your local gas company to make sure that your dryer is installed correctly.
    3)There is a possibility that your LP gas supply tank is empty or there has been a utility interruption of natural gas. Try refilling or replacing the tank.
    If you are still having trouble with your dryer, I suggest giving it a hard reset, by either unplugging it or shutting the power off at your homes circuit breaker for 3-5 minutes. When power is restored, start any cycle. If you are still noticing that there is no heat and it stops 5-7 minutes into the cycle, I suggest contacting your local authorized technician. Hope this is helpful.
    -Best Regards-
    WP
May 14, 2014 | Frigidaire FAQE7001LW Dryer
Brand new Frigidaire FFLG2022MWO Washer/Dryer Laundry Center. After a wash cycle is finished, the washer will start again after a few minutes. A truly never ending cycle. Please help.
Good Afternoon Mauricio, thank you for your question! Try resetting the unit by either unplugging it or flipping the household circuit breaker to the off position. Wait roughly ten minutes and turn on the appliance. Select a normal cycle and verify if the washer continues to run after ending cycle. If resetting the power does not correct the issue, your appliance could be experiencing a communication error with the control board, timer or could have a wiring failure. I would suggest contacting an experienced service technician to determine the precise cause.
Aug 19, 2013 | Frigidaire FFLE2022MW Electric...
Agq6000es2 frigidaire affinity gas dryer comes on the ingniter glows but the gas does not lite
Hello Tim, I understand the dryer comes on but will not heat. Let's try resetting the unit by either unplugging it or flipping the household breaker to the off position. Wait approximately two minutes, turn on the dryer and select a normal cycle. If these troubleshooting steps prove ineffective, you may wish to contact a professional as the unit may possibly have a defective cord, wiring, power supply, control board or door switch. In this case the service can accurately diagnose the dryer to determine the root cause to reduce the risk of unnecessary parts.
Aug 13, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
My affinity frigidaire gas dryer wont stop running
Hello Kenneth Joynt - Often when a dryer will not stop running, it is because the unit may have a potential wiring failure, faulty timer, or a communication error with the main control board. Try resetting the unit by either unplugging it or flipping the household breaker to the off position. Wait approximately two minutes, turn on the dryer and select a normal cycle. If issue persists, I would suggest contacting an experienced service technician to determine the precise cause.
Apr 12, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
I have model LEQ1442ES1 and it beeps on the normal, high settings
Hello charityscrug - Try reprogramming the dryer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and restart unit. Select a normal cycle and if issue continues then the dryer could possibly be experiencing a communication error from the control board or wiring failure. Contact a professional to move forward accurately.
Feb 11, 2013 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire electric dryer error code AD
Hello - Typically error code AD indicates that the Auto Dry option has been selected. Using no heat in any Auto Dry cycle will result in long drying times and/or wet loads at the end of cycle. I would suggest selecting other option or resetting the unit. You may either unplug it or flip the household breaker off for approximately two minutes. Restart unit, select a normal cycle and verify if it will heat. If the dryer does not heat the unit it could possibly have a faulty heating element, blower assembly or a communication problem with the control panel. Contact a professional to move forward accurately.
Jan 07, 2013 | Frigidaire AEQ6000ES Electric Dryer
Dryer heats during function test but thats it
There are several potential causes of not heating up. You have addressed the thermostat issue already. Check the switch mounted on the motor. Use a multimeter to check the switch. Unplug and reseat the electrical connections. Two of the terminals on the switch are for supplying power to the gas valves. You can check the sensor mounted on the side of the burner housing. The contacts should open after the glow bar has been red for a few seconds. Other things to look at are a faulty heat selection switch and a bad timer. Hope this helped and best wishes.
Aug 19, 2009 | Dryers
Dryers Logo
57 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
