Question about Garden
No gas to carb. replaced fuel pump and push rod. Still no fuel. Reversed hoses on fuel pump and works great, except pumps oil out. Any ideas
  • 38 Answers
Pumps oil out for sure hooked up wrong
Posted on Oct 14, 2013
SOURCE: gas not getting to carb. Blew out all lines gas, new gas filter
fuel line cracked in shroud just fixed one just like it check fuel line from filter to carb
Posted on Apr 08, 2009
  • 79 Answers
SOURCE: push rod loose
Hi
Very possible that the valve is stuck open and piston could have hit valve causing it to bend at the head. This would cause valve not to close completely. Would have to remove head and remove valve and most likely replace intake valve.
Posted on Apr 09, 2009
  • 109 Answers
SOURCE: model#917.276020 25hp 48
On the bottom of the carb., there is an anti-after fire solenoid, take it off and make sure that it is working with the key switch, it should retract when the key is turned on and go back out when the key is turned off, if it doesn't check the red wire to make sure it is still connected
Posted on Apr 24, 2009
redbeard00
  • 957 Answers
SOURCE: Occasionaly the engine shuts off and won't start on JD gx345.
If the fuel pump is working correctly then the problem is between the tank and the pump. run a fuel line from the pump to a gas can. If the pump is working it will siphon the fuel into your filter. If the pump is fine then there is blockage, broken fuel line (sucking air), or something blocking the pick up inside the tank.
Posted on May 23, 2009
  • 6468 Answers
SOURCE: John Deere L110 won't start.
check the solenoid on the bottom of the carb see if there is power if no power check the safety switch on the brake/clutch if there is power remove the solenoid and put power and ground to it to see if it opens if not try and clean it with carb cleaner if that works and opens remove the bowl from the carb and check the needle valve on the float make sure it moves
Posted on Sep 03, 2012
1989 dodge ram 50 2.0 engine
Fuel pump
REMOVAL
  1. Disconnect the battery ground cable.
  2. Disconnect the fuel inlet, outlet and return hoses at fuel pump.
  3. Remove the two fuel pump mounting bolts, and remove the fuel pump.
  4. Remove the fuel pump gaskets and insulator.
Check for leakage, if there is oil or fuel leaking from the breather hole, oil seal or diaphragm of fuel pump, the pump is defective. Replace fuel pump as an assembly.
INSTALLATION
  1. Turn the crankshaft so the No. 1 cylinder is at top dead center on the compression stroke. NOTE : This is to minimize cam lift for ease of installation.
  2. Insert the push rod into the cylinder head.
  3. Install the new gasket and insulator, install the fuel pump.
  4. Tighten the bolts firmly.
  5. Connect the fuel hoses to the fuel pump ******* and tighten the hose clamps.
  6. START the engine.
  7. Check for fuel or oil leaks.
Jun 25, 2015 | Dodge Cars & Trucks
Huskvarna Riding Lawn mower will not start
Stating the obvious when the fuel line is off the carb and the engine is cranked there should be fuel coming from the hose, if not the pump is not working, there is normally three conections on the pump, fuel in, fuel out, and pulse from the engine, this hose takes a pulse from the rise and fall of the piston in the cylinder, make sure the hoses are connected corectly and tight, if there is still no fuel check the inline fuel filter ( if fitted ) is not blocked, if all appears ok, then it can only be a faulty pump.
May 09, 2013 | Garden
Not getting fuel to carb, mechanical fuel pump replaced.
SOUND LIKE STOP UP FUEL LINE.OR SOCK IN FUEL TANK STOPPED UP WITH RUST AND DEBRIS.YOU COULD HAVE A WORN FUEL PUMP PUSH ROD OR CAM SHAFT LOBE WORN WHICH DRIVES THE FUEL PUMP PUSH ROD.
Apr 28, 2010 | 1986 Chevrolet Chevy
Evinrude, 15hp 4cycle outboard, 2000 model - starves for gas
hi obviously a fuel fault someware / when motors are winterised the fuel system is usualy emptied, this causes gaskets and diaphrams to dry out and split try it with the tank filler off /replace the diaphram in the carb and i am pretty shure that will solve the problem /nb / as this motor has stood for a time and does not do much work /outboards love work check the water pump impellor and put a spoonful of oil in a full tank of gas hope this helps merlin v12
Aug 28, 2009 | Boating
Need instructions for fuel pump replacement on 1988 Chevrolet Truck.
You didn't state if it was fuel injection or regular carb type.
If fuel injection, you have to drop the gas tank. Undo bolts on tank straps, lower slowly, disconnect the fuel lines and the wire connector for the pump. Make sure surface is clean, take a screw driver and hammer and tap the pump assembly locking ring until it's loose. Remove pump assembly. Installation is just reverse.
If it is carb type, the pump is on the drivers side of the engine.
Disconnect the fuel lines, take off the two bolts, remove pump.
To install that pump you need a pair of needle nose pliers to hold up the push rod while you are installing the new one. Hope this helps.
Jun 27, 2009 | 1989 Chevrolet Suburban
1992 Pace Arrow Motor Home 454 Chevy...not getting fuel to start
After you dump the fuel in the throttle body it will continue to run on its own or die as soon as it burns up all the fuel you dump in? Do you have access to (Noid lights)? Are both plugs attached to the distributor?
Jun 24, 2009 | 1985 Chevrolet Chevy
ONAN 4000 RUNS FOR ONE HOUR AND DIES--ANY IDEAS WHY?
Try to restart to see what happens. However, make sure to have a volt meter to check output voltage. You may be loosing voltage and therefore it shuts down. Check oil pressure switch, rings, brushes. Replace brushes if they are less than 1/2" short and clean rings with emory cloth until copper is noticable.
Jan 21, 2009 | Watts Onan Portable Generator - 4000 ,...
After pumping the gas alot my truck starts and then shuts off
Check the fuel filter, if ok, disconnect the fuel hose from the carb and ask someone to start the engine, if fuel comes from the disconected hose the problem is in the carb, if not, check the fuel pump.
Make sure before you disconnect the fuel hose to disengage the coil.
Dec 12, 2008 | 1984 Ford F 150
How to change fuel pump ?
  1. Disconnect the negative battery cable.
  2. Disconnect fuel tank hose at the fuel pump, and plug the hose with a bolt or wooden dowel to keep any fuel from flowing out wires. Check the hose and if it is frayed or cracked, replace it with new fuel line hose.
  3. Disconnect the outlet line to the carburetor. Use a wrench on the fuel pump fitting and another on the line nut.
  4. Remove the two attaching bolts and remove the old fuel pump. Clean off any old gasket material from the mounting surface of the engine.
Installation:
  1. Apply a coat of gasket sealer on both sides of the new gasket. Put the attaching bolts through the new pump and slip the gasket over the bolts.
  2. Install the new pump on the engine. Make sure that the rocker arm in the pump is against the eccentric inside the engine, or that the push rod is correctly installed in both the engine and the fuel pump. If the push rod slides out, you can pack it with some heavy grease to hold it in place while you install the pump.
  3. Attach the fuel outlet line that runs to the carburetor. If it's difficult to connect, remove the other end of the line from the carburetor. Connect the line to the fuel pump, and then reattach the other end to the carburetor. Use a wrench to hold the fuel pump fitting and tighten the line nut with another wrench.
  4. Attach the fuel inlet hose from the gas tank, and the vapor return hose (if the vehicle is equipped with one). Tighten all clamps.
  5. Reconnect the battery ground cable, start the vehicle and check for leaks.
Hope that works
Nov 19, 2008 | 1991 Eagle Talon
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
