Locating dvd connection on 46wl863b - Televison & Video
Dynex dx-32l151a11 the picture is black and white with the dvd player
With a Black and White picture it sounds like you're trying to connect the DVD Player's "Composite" connection to the TV's Component Connection.
Composite is a 3 wire system with Yellow for the video, and red and white for the audio. On your TV this connection is located on the side.
Component is a 5 wire system, with Blue, Green & Red for Video, and Red and White for audio. On your TV this connection type is located on the rear panel.
Check to make sure you are hooking the DVD player & the TV to the same input types.
Dec 26, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Can not locate dvd rw drive
Either:
* the "power" cable from the computer's power-supply is not connected to the CD/DVD hardware;
* the "data" cable from the motherboard is not connected to the CD/DVD hardware -- check both ends of the cable.
* electronics inside the CD/DVD drive itself have failed.
* you have entered BIOS SETUP, and have "disabled" access to the drive.
Apr 16, 2010 | E-Machines emachines (emachinees) CD-ROM...
I have the board for my old samsung ms28 but no case is the DVD
The dvd board is located at the back of the drive, it is connected to the motor and things by white strip wires, if you are removing the board pull the wire from the motor not the board,but the others from the board not the dvd drive.
Let us know if this solution works for you.
Jan 12, 2010 | Microsoft Xbox 360 Console
Dvd fuse
fuse is usually located in the power supply area, after you open cover, look near the power cord connecting to the board the type of fuse is usually written on the board near it and on the fuse itself
Nov 01, 2009 | Televison & Video
I have a new element hdtv and a magnavox dvd/vcr. i can't seem to hook the two together. please help
Greetings, Simple hookup would be connecting analog output from DVD/VCR player to your TV. To do this, use the Audio-Video cable which has 3 terminals at both the ends and each terminal has RED,YELLOW and WHITE pin. Your DVD/VCR player would have analog output socket where you would connect one end of these 3 pins, make sure yellow would go in "VIDEO Out, WHITE would go in "LEFT Audio Out" and RED would go in "RIGHT Audio Out", you can easily identify them cause these sockes would also have the colors on them. Now connect other end of the cables to TV, this would be input to your tv. On the back left hand side of the TV, you would see 3 sockes with YELOW, WHITE and RED colors. These are located between "Coaxial" and "S Video" labels. Connect yellow pin to yellow socket which is "Video In", connect RED pin to RED socket and White to white. Switch on the TV, play any dvd on your player. On your TV remote, press INPUT button which is located on the right hand side top corner on remote, press it and if you get the dvd player video and audio, you should repeat the button press to see the video, this button selectes one by one signals given to TV, so your dvd player input might be on the 2nd,3rd or 4th press, so go through till you get the video signals. Hope this helps !!! --Sandy.
Jun 07, 2009 | Toshiba DVR3 DVD Recorder/VCR
Problems establishing audio output from DVD RW to TV
If you own a Digital Video Recorder, such as TiVo, or a DVR from a Cable or Satellite provider, then you know you can record to the device's hard drive to view TV shows at a later time, much like the old VCR. However, saving those TV shows becomes difficult as the Hard Drive starts to fill up. The answer to saving your shows is to record them to DVD! This can be accomplished easily by hooking up a DVD Recorder to your DVR
Here's How:
  1. 1)record a TV show on your DVR that you want to save to DVD!
  2. 2)Turn on the DVR, DVD Recorder and the TV that the DVD Recorder is connected to. In my case, I have my Samsung DVD Recorder (no hard drive) hooked up to my TV via an RCA Audio/Video cable from the rear outputs on the DVD Recorder to the rear RCA inputs on my TV. I use a seperate DVD Player for playing DVDs, but if you use your DVD Recorder as a player as well, use the best cable connections you can to connect to the TV. See the articleTypes of A/V Cables for more info.
  3. 3)Connect an S-Video or RCA video cable and composite stereo cables (red and white RCA plugs) from the DVR to the inputs on your DVD Recorder. If your TV has Component inputs, connect the Component Out from the DVD Recorder to the Component In on the TV, otherwise you can use S-Video or Composite. You will still need to use RCA audio with your video connection.
  4. 4)Change the input on your DVD Recorder to match the inputs you are using. Since I'm using the rear S-Video input, I change my input to "L1", which is the input for recording using the rear S-Video input. If I was recording using the front analog cables it would be "L2", the front Firewire input, "DV". The input select can typically be changed using the DVD Recorder remote.
  5. further instructions continued in my next comment post please read.
Apr 05, 2009 | Sharp Televison & Video
DVD player won't work on my 27gt615
alexa,
good day, if youre saying that you program the DVD to work on channel 2 or 4 does it mean you convert the signal of your dvd player from A/V output to RF out?
because the simpliest way to connect your DVD player to TV screen is by using RCA cable ( 3 wired cable being color marked as yellow/red/white) yellow = video red and white = audio
the connection would be: from dvd back part you'll see colored socket yello/red and white. connect the RCA to those socket following the same color .
and from the TV screen there should be A/V input socket. can be locate at the BACK/Side or FRONT of the screen marked as
"INPUT" ( AV1, AV2,AV3 if multiple inputs). Then select which input you want to place your DVD player ex.AV1 (from AV1 there will be 3 scoket in a row, yellow/red/white)
Connect the other end of your RCA cable following the same color code to TV "AV1 INPUT" yellow = yello/red =red/white=white. then from the remote commander of your TV screen locate a button marked as "TV/AV" or "A/V" press this button until the screen display switch to AV1.
cheers,
mark
Jan 31, 2009 | GE 27GT619 27" TV
Zenith SMS1943S made 1995 Need code to switch to dvd status
nleebrooks,
1) check the RCA cable connection from your DVD to TV screen.
make sure that each cable is in the right place (for DVD player yellow cable = video/ red and white cable = audio) (TV screen: yellow cable = video IN /white and red = audio IN
2) from your TV screen locate and check for A/V IN socket. it's either at the back/front or side of the screen.
note: some of TV screen does have 2 A/V inputs
3) Facing the front of your TV screen, locate a button indicating "A/V" or "AV" or a box picture having a forward arrow inside.
note: if you locate the said button and your screen have 2 A/V inputs press the said button until the right input where you connect your dvd cable been set.
cheers,
mark
Jan 17, 2009 | Zenith C13A05LG 13" TV
HOW DO I CONNECT MAGNAVOX DVD/ VCR TO VIZIO FLAT SCREEN
Is simply. get the audio/vido cables and look on the back of the TV and connect from the audio video outputs from the combo to the audio video inputs on the tv. remember the colors of the terminals and connect them that matches the red, white (audio) and the yellow (video). Using the remote locate the button "input" or "source", and select video 1 or 2, depending where you connected it.
Nov 18, 2008 | Philips Magnavox DVD/VCR Dual Player
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
Electro Med Services...
