Foxconn 761mx how to install and attach cables
    Sergeant:
  • 293 Answers
I'm going to presume that you have a tower or case that is the correct size.
First clean out the case of any junk, dust, etc. Then ground yourself to the case so as to dissipate any static electricity. I suggest you get a static clip for this.
Remove the motherboard from the static free film bag and locate the screw set bag. Most of the screws for ATX and Micro-ATX boards are standardized so it really doesn't matter which screws you use out of the bag. The vast majority of them should have a multi-head (phillips, flat, hex). Take the motherboard and gently place it in the case, making sure the case is on it's "back" so that the side you're mounting the motherboard to is flat on the ground.
Align the screw holes of the motherboard with the best fit of the screw holes found on the case. Note: If it is an intel based processor motherboard, you may need to mount the processor first and then the heat sync and fan before mounting it to the case, as it mounts directly to the motherboard. Since the Foxconn 761mx is an AMD board, this shouldn't be an issue.
Then locate your peripheral components (hard drive, optical drive, fans, heat sync, processor, ram, case fans, video card etc). Mount the AMD processor into the AM2 socket, making sure the socket handle is up or in the unlocked position. Once it is seated lock the processor into the socket by placing the handle down. Be firm but gentle in pushing the arm down. It should lock in smoothly, if you feel any major resistance, stop, release the handle and check to make sure the processor is in place correctly.
Once the processor is installed, cover the base of your heat sync with heat gel (Thermal Compound)(if it doesn't already have it, I suggest Arctic Silver~ http://www.newegg.com/Product/Product.aspx?Item=N82E16835100007~ as it is superior than most of the preloaded gels).
Because this is an AM2 socket with a specialized clip, you'll find that it can be a little persnickety getting it on. The heat sync you have should tell you how to do it. If I remember correctly this particular clip you unscrew and loosen the side clips. The heat sync fits under this type and you then clamp it down. But I'm going off of a picture so I'm not exactly sure.
Once the heat sync is mounted and pressed firmly against your processor you're ready to situate your other components. Install your ram (making sure to match the notches to the spacer. This motherboard uses DDR2 ram so it's not that fast, but you have two slots to fill up to a max of 16 gb). Place your hard drives or SSDs into the drive bay where you'd like them to be, and place the optical drive into the optical drive bay. If you're going to install a zip drive or floppy drive (first why?) connect it to the black IDE connector. The primary hard drive on this motherboard can be either SATA or IDE. You can get SATA to IDE adapters if you need to have more than one SATA hard drive, or you can purchase a PCI-E SATA controller to expand the hard drive space.
Mount your video card in the PCI-Express X16 slot (the long yellow slot) and then mount your power supply in the specified space in the case. Finally mount your case fans. Usually one in the back below the power supply (if it's an upright case) and one in the front near the hard drive bay.
The power supply will have four screws (probably already in the case) that will hold it into place.
Now that all of your components are seated or mounted, it's time to connect the power supply to the components.
First locate the ATX power lead. This is pretty self explanatory. This will either be 12 by 2 or 8 by 2+ 2 by 2, or 12 by 2+2 by 2 connector that fits the main power connector on the motherboard, located next to the two ram slots. You'll find a 2 by 2 power port next to the processor slot. Seat both power power connections on the board.
On this board there are two power input only. The remainder of the power output goes to the hard drives or ssd, the optical drive, fans and heat sync, and possibly video card or other expansion cards. If you've installed legacy equipment (non-sata or IDE hardware) you'll have a large white four prong male plug that will fit tightly into a four prong female plug on the legacy equipment.
Where as if you're working purely with SATA devices, you'll have a flat power supply plug that is keyed (looks like an L) that fits into the smaller power supply plug found most often to the left of the main SATA port on the hardware. This plug will be larger than the SATA plug in width, but thinner in height.
The IDE port and 10 pin IDE port for the legacy hard drive and floppy drive on this motherboard sit next to the main power plug, while the SATA ports are the Two Blue L shaped plugs. The IDE port is blue while the 10 pin IDE port (for the floppy) is black with a lower left hand missing pin (keyed).
Connect your hardware to their respective ports.
Next locate the 8 pin plugs for the Case USB ports labeled USB1 and USB2, usually for the front. Most cases come with a front USB expansion port. This will attach to one of the 8 pin connection points on the motherboard. Some older cases come with firewire or extra usb expansion cables which can be attached to either USB pin plug. USB1 and USB2 ports are painted green on the motherboard.
You'll find on this motherboard four more plugs, one that looks like a very small black four pin port near your cmos battery, a four pin port that has no plastic around it labeled COM2 with a blue underlay painted on the board. A black painted 7 pin plug near the 4 pin black port and then another 4 pin plug point labeled speaker.
If you want to have a case speaker installed for use with beep codes (a set of CMOS codes that will beep if there is hardware failure) plug the speaker into this port (note: most new cases don't come with this speaker and to acquire one you should check with any second hand computer repair company). The 7 pin black pin plug is where you connect your power and reset button and power on light. The 4 pin port near the Cmos battery is for audio exchange. While most new SATA optical drives run audio through the SATA controller some legacy optical drives that are IDE need to be connected to the onboard audio using a 4 pin cable. COM2 is rarely used, but can be used for other controls, it works as a port extension. Many new motherboards don't have these because everything has gone USB and the old serial port standard isn't used anymore.
That is a complete guide to putting together your computer.
Posted on Oct 15, 2013
Have a Packard Bell Imedia J9415 whith Foxconn RS6007MA-8S2H motherboard.Can not find it on Foxconn support!!??I want drivers for the motherboard. Thanks.
need to go to the web site hp makes packard bell type in boards number for drivers then download them get all updates for your board then install them all to make it run better.then got to foxconn drivers then install them it should work for you jim.ok
Oct 03, 2013 | Foxconn Computers & Internet
Will windows 7 install useing a 661 mx plus motherboard
I have found Windows 7 to be the easiest operating system to install but you need to have a minimum of usually 1 gig of ram. I have gotten it to work with less but it is slow.
Just make sure you are connected to the internet with a Ethernet (network) cable so windows will find and update all your drivers.
Back up and save all important information before starting, and do a clean install. I have used the Windows 7 file and transfer wizard which is easy to use. I have attached that link below.
http://windows.microsoft.com/en-US/windows7/products/features/windows-easy-transfer
If I can be of any more help let me know,Thanks for using FixYa
May 14, 2011 | Foxconn 661MX Motherboard (FOX661MXMB)
I have foxconn 865G7MF with on board graphic. After couple removing and attaching monitor without shutting off PC, the motherboard was loose video output. Rebooting dose not give any results, PC normally...
It's possible that the video processor has been damaged from ESD (electro Static Discharge) from the connecting and reconnecting while it was turned on. The first thing I would try is installing an expansion video card (like a PCI or AGP one) to see if that works. If it does, that was the issue
Feb 28, 2011 | Foxconn 865G7MF-SH Motherboard
Hello, ive got a HP 5189-0466 FOXCONN MCP73M02H1 NAPA HP MOTHERBOARD. and im building just an internet comp for the downstairs for the kids but im having troubles finding the manual for it. Cant seem to...
open side panel remove cable from usb reader i have pulled CABLE AFTER install new mother board same thing stuck no key board 1 blink/ f10 got setup ..... stuck . This may be a chip set driver not installed. or a bad hardware pulling to mush power. I change CPU, MEM sticks. Power supply all the same thing. Just pull these cable to hadrware not hdd. boot right up . BINGO> c:\users\office\appdata\local\temp\msohtml1\01\clip_image001.gif down 1yr.
Jun 23, 2010 | Computers & Internet
CD Rom installation
the cdprom power cable port might be faulty plz check it ...
Jul 07, 2009 | Computers & Internet
Foxconn K7S741GXMG-6L Integrated Input/Output Port Activation
i have same problem on my motherboard and it is due to damage, check and see if your RJ45 (lan) is disabled in the system bios.then see if you are not drawing more than 500ma on the usb. good luck!
Jul 28, 2008 | Foxconn K7S741GXMG-6L Motherboard
Foxconn motherboard
very easy just type your mother board model number in the internet browser then u wil see all the driver u need audio to video...ex "B65MO1-G-6LS driver" ..
Oct 19, 2007 | Foxconn P4M9007MB-8RS2H Motherboard
Problem in foxconn mobo 865gv/775 of sound
Hi, have you got your speakers plugged in and turned on properly? speakers in the green socket. Also check that you have the cable from the CD player connected to the board. This connection is the black one on the board, not the white one. Regards mistyman
Oct 08, 2007 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Computers & Internet Logo
76 people viewed this question
David Payne
David Payne
