Question about Dryers
Frigidaire affinity dryer not heating up after replacing the heating element. It will heat up for a minute then goes cold but dryer keeps spinning.
  • 119 Answers
Did the original element bad? you probably replace the wrong part for the problem. check your coils, there's two of them right in front of the element.
Posted on Oct 16, 2013
AlmostBob
  • 550 Answers
SOURCE: Replacing Heater Element in Roper Dryer
before you replace the heater most common cause of heating failure is burn out of the thermal cut-out. (also called thermal fuse, overtemp cutout and probably half a dozen other names) These are a small screw on device on the exhaust duct, when exhaust air reaches too high a temperature, like a blockage, they fail before a fire.
examin the exhaust duct inside the dryer for devices that look like this 641e982.jpg or like this dd7fd44.jpg with wires connected to the terminals. there may be 2(hi lo), test with a ohmmeter -conductivity good, no conductivity replace.
there are only a few different kinds the local parts guy will have them all. take the dud one for him to match.
Posted on Aug 27, 2008
SOURCE: Frigidaire Dryer WOn't Heat
I have a frigidaire frontal dyer that is 3 yrs old. The dryer works properly, it tumbles, but it is only cold air ???? What's the problem ?
Posted on Sep 15, 2008
dragonsthatk
  • 547 Answers
SOURCE: FRIGIDAIRE AFFINITY ELECTRIC DRYER NOT STOPPED HEATING
eleiment
Posted on Feb 18, 2009
dragonsthatk
  • 547 Answers
SOURCE: Frigidaire affinity dryer doesn't have heat but it tumbles, stops
clean air duct
Posted on Mar 13, 2009
  • 1531 Answers
SOURCE: have a frigidaire affinity electric dryer that doesn,t heat
check your heating element or the thermal fuses located on the back wall the side of the heating element can and the plastic blower ducting
Posted on Sep 17, 2009
Frigidaire Affinity Gas dryer, had a technician replace the thermal limiter after getting an E66 error code, twice, about 6months ago, he advised me not to use the hottest setting and thing have been
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
Oct 06, 2014 | Dryers
How to replace heating element on frigidaire fase7073lao dryer?
Takes Frigidaire (OEM) Part #134792700
http://www.ebay.com/itm/134792700-NEW-Genuine-Electrolux-Frigidaire-Kenmore-Dryer-Heating-Element-OEM-/181461935813?pt=LH_DefaultDomain_0&hash=item2a3ff966c5
~ $87 w/free shipping
Here's more pix on YouTube. Get your screwdriver out and go at it. You'll never learn any younger. Write down and/or label where EACH wire goes as you disassemble. Just remember SAFETY FIRST. NO POWER while you're working on this ! UNPLUG is enough, there is no residual voltage on a dryer. Best help may be on YouTube. ask for (type in) Frigidaire Electric Dryer repair. There are several videos, one of which should serve to give you courage and a starting point if you've never done it before.
Jul 20, 2014 | Dryers
Frigidaire Affinity AEQ6700FSO electric dryer does not heat, then shuts off within 10 minutes.
Hello Scott Joseph Brandt - Since you have already replaced the thermal limiter check your breaker or fuses. Some dryers are run by two separate fuses, one for power and one for heat-ours is. If it is not the power source more than likely the issue lies with your heating coil.
Feb 05, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Heating element quit working on my frigidaire affinity dryer
If the unit still works, it just does not dry, please have a professional diagnose the heating element and the blower assembly. Either, or, could be faulty at this time. This is not a typical DIY job so please consult a professional.
Sep 19, 2012 | Frigidaire Affinity AEQ6000WH Dryer
How to replace the heating element in a AEQ6000CES2 frigidaire affinity dryer
Hello,This youtube video will show ya how to replace the heat element on your dryer.http://www.youtube.com/watch?v=JwMyoSa9ebw
GENE
Oct 21, 2011 | Frigidaire AEQ6000ES Electric Dryer
Affinity aeq7000eg0 no heat stops after 20 minutes
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jul 01, 2011 | Frigidaire Affinity AEQ6000WH Dryer
Have a frigidaire affinity electric dryer that doesn,t heat
Sep 06, 2009 | Frigidaire Affinity 5.8 Cu. Ft. Electric...
Dryers Logo
57 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
