Question about Garden
Hi there, I've bought a honda hrx 537 21 inch mower cheap because the previous owner went over a tree stump and although cuts well, it vibrates when just idling-without the blades spinning! could this just be the clutch that needs replacing?
  • 28 Answers
Sorry to tell you this but that will never go always . It has a bent crankshaft usually right by the blade. It will need to be rebuilt with a new crankshaft. Oh, use can use it like it is, but your hands will fall asleep with vibration.
Posted on Oct 13, 2013
hunter19_46m
  • 7482 Answers
SOURCE: My wife hit a stump
Hi ptcbob7...
Yes, she bent the crankshaft...very hard to get the bend out, most of the time a new engine is in line.
Being that your going to have to replace the motor anyway...I would take a large hammer and give it a good whack in the opposite direction of the bend, it may not take it all out, but it will take out some of the bend.
Please take time to rate me
Posted on Aug 30, 2011
mowerman1857
  • 389 Answers
SOURCE: parts for a honda lawnmower hrx 537
It would depend upon WHERE in the world you are located but you should be able to contact your nearest Honda Mower dealer or do an internet search for
>> "hrx 537 honda parts" << and it will return quite a few places both on-line and in-person place where you may purchase them
Posted on Oct 12, 2009
SOURCE: Need to replace the rotostop .
I found the manual from a french dealer .
Thanks for help .
Posted on Nov 03, 2009
SOURCE: Hi, I have recently bought at auction a Honda HR194 Mower
Hey Graham:
Here is an owner's manual for your lawnmower.
sysdoc.doors.ch/HONDA/31VA5030.PDF
Enjoy!
Steve
Posted on Dec 09, 2009
hunter19_46m
  • 7482 Answers
SOURCE: after hitting a low bearing tree stump with my
You will need to replace the key under the flywheel because it probably sheared when you hit the stump and you will need to replace the bent blade before starting the mower again.
I hope this helped
Please Rate Me
Posted on May 24, 2010
Mower starts, dies when you release clutch.stumped. is it time to replace mower or is this relatively cheap fix
My Husqvarna 48-Inch Mower Will Not Stay Running ' Home ...
homeguides.sfgate.com > ... > Other Real Estate Terms & Definitions
Among its offerings is an extensive list of riding tractors and mowers. ... Mowerissues can prevent you from performing your lawn-maintenance program. ... If yourHusqvarna 48-inch mower dies without spinning down, check the drive belt ... If yourHusqvarna mower runs until you release the clutch, chances are you have an ...
Aug 01, 2015 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
How to remove silver cover on front of engine
Bumped a tree and the mower died ?? If so, you broke the Keyway on the flywheel which threw off the Timing. Flywheel has to come off and a new keyway ( very cheap) has to be installed.
Aug 24, 2013 | Husqvarna 21" Lawn Mower with Honda GCV160...
Honda lawn mower not pulling hrx 217
Clean pulleys, replace belt.
May 21, 2012 | Honda Garden
Honda HR215 hits stump - still runs and cuts but engine vibrates when running IF the BLADE IS NOT TURNING.
you could have bent the blade or the crank look at the blade then remove the blade mount and spark plug turn on its side and turn the engine over and look for crankshaft runout
Apr 07, 2012 | Garden
Craftsman LT1000 mower deck cutting uneven. How
try biger wheels on the low side???? ha ha?
no you hit and bent the bed hight ajusters you may need to take the mower bed off to fix this part,,,,,
look as were the morer hight ajuster is,,, is it in the same place on both sides,,, my gess is its not
the bed has a tilt on it,,,they dont cut down trees very well do they?
Jun 11, 2010 | Garden
Why does my 42 inched deck craftsman tractor cut uneven?
It needs to be leveled. Level it from side to side and front to back, then drop the front 1/4" lower than the rear. The hangers holding the deck in place are adjustable.
Jun 05, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Parts for a honda lawnmower hrx 537
Oct 11, 2009 | Garden
Replacing front fender
My son went around a curve one night and hit a tree stump that was in the middle of the road. It put the front bumper under the truck, busted the radiator, the framing brace that supported the radiator and the A/C condenser. There was even wood in the frame from the impact. He also needed to replace a fender from a previous accident. After getting everything installed on the engine, they had a problem putting the fenders back on.
The passenger's side fender fit perfectly except where the hood was hitting in one spot. The fender was about 2 to 3 inches too high and the guys were threatening to take a hammer and beat it down. But after getting a stronger light and searching the frame of the truck from all angles, they found out there was still one bolt that needed to be removed. Once it was removed, the fender went on smoothly. They didn't get to use the hammer like they were threatening!
Nov 08, 2008 | 2000 Dodge Dakota Quad Cab
Garden Logo
166 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
