Question about McCulloch Mcs1400 14a Electric Leaf & Branch Chipper Shredder Mulcher Garden
Need V-cutter for mcculloch mcs1400, part number 6250-20003
Oil for Mc Culloch M T 325 Cls, weed trimmer
Hi and welcome to FixYa, I am Kelly. I looked up your manual here:
http://www.mccullochpower.com/node7877.aspx and entered MT325CLS as the model number No such number. There is a different model number / product code that may start with 957 on the data plate / label.
I also checked Australia and UK without any success.
http://www.mcculloch.biz/uk/support/owners-manuals/?query=Trimmer&types=O
http://www.mcculloch.biz/au/support/owners-manuals/?query=Brush+cutter&types=O
I tried trimmers and brush cutters for both regions and the US McCulloch site. If you have a better model number (Product code) I will look again.
Kelly
Sep 24, 2011 | Garden
Tip
McCulloch Chain Saw IPL (Illustrated Parts Listing)
Looking for a McCulloch Illustrated Parts Listing (IPL), Try this:
McCulloch Illustrated Parts Lists:
IPLs (exploded parts lists) are fairly simple, on the underside of McCulloch saws is a small black and yellow tag; the upper number (“Power Mac 320” 600021H or -8 if European) is the model, below it a serial number (11-18555). These 2 numbers are combined to create an IPL number (“Power Mac 320” IPL number = 11-600021H or -8). The IPL number can be used to find the correct IPL for every McCulloch parts supplier I have found. If the parts supplier only list part numbers the proper IPL is the source for the part number.
Utilize the IPL number you just created here:
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
There are many suppliers of McCulloch parts, some with a better selection than this one. Once you have identified your part try an Internet search for "McCulloch YourPartNumber"
Lou
on Dec 02, 2009 | Garden
McCulloch Chainsaw electrimatic EM250-14 how to sharpen chain with electric sharpener.
I am not a great beleiver in electric sharpeners, they get the cutters too hot, this case hardens them making them brittle and they lose there edge quickly, they can no longer be sharpened with a file as they are like glass, purchase a good roller guide sharpener from a Husqvarna dealer, they are simple to use and work well.
May 27, 2011 | McCulloch MCC1514 14Inch 15 HP Electric...
My chainsaw has started to cut on an angle could the bar be up for renewal
The most likly cause is that you have sharpened the cutters shorter on one side than the other, all the cutters must be the same lenght, if this has been going on for some time it will wear the guide bar rail on one side and make it even worse, remove the bar and dress the rails with a file, get both sides as level as you can, now re sharpen the chain to get all the cutters the same lenght, or fit a new chain
Jan 24, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Need manual for mCculloch chainsaw
McCulloch Manuals
Illustrated Parts Lists: (IPLs) are fairly simple, on the underside of McCulloch saws is a black and yellow tag; the upper number (“Power Mac 320” 600021H) is the model, below it a serial number (11-18555). These 2 numbers are combined to create an IPL number (“Power Mac 320” IPL number = 11-600021H). The IPL number can be used to find the correct IPL for every McCulloch parts supplier I have found. If the parts supplier only list part numbers the proper IPL is the source for the part number.
Operators Manuals: are much more difficult. I have dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it! If unsuccessful with McCulloch try here:
Beg for manuals thread (ArboristSite - free to join). Please use the search function first, it has probably been asked and answered.
http://www.arboristsite.com/showthread.php?t=72322 HTH
Lou
Jan 04, 2010 | McCulloch Garden
I need an owners manual for McCulloch 100 series Eager ****** chainsaw
McCulloch Manuals
A complete parts list using the "IPL Number" can be found here:
K&T Parts House
http://www.mymowerparts.com/pdf/McCulloch_Parts_Service_Repair_Manuals/Gas_Powered_Chain_Saws/
Lou
ArboristSite is where I found both my Mac 110 and Power Mac 320 operators manuals.
Dec 13, 2009 | McCulloch Garden
Mcculloch Virginia hedge cutter manual
mcculloch virginia mh542 hedge trimmer, fires 1st time, will only tick over roughly on full choke only then stalls when throttle applied, I have fitted new plug'cleaned air filter and new fuel mix but no change.
Nov 25, 2009 | Garden
Need mccoluch chainsaw MAC 438 manual
I think you are saying you want an "Operators Manual" for a McCulloch. There is no where to download a McCulloch or Poulan Manual. on line. Please inquire about the availability of your manual here:
Poulan.com
http://www.poulanpro.com/node4033.aspx
While there please suggest they make them available. HTH
Lou
Oct 01, 2009 | McCulloch Garden
Muculloch brush cutter wont start. No spark from plug.
If you have correctly diagnosed the problem as no spark, you will need to replace the ignition module. Unfortunately McCulloch dealers and McCulloch parts are very hard to find these days. If yoou do not have a dealer in yoour are who has the part you need, contact southern supply company at 205-833-2525 or email them at southern.supply@mindspring.com and I feel sure Jason or someone there can help you.
Sep 21, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
What ratio of oil do you reccomend for the
Depending on the age of the McCulloch cutter it could be 25:1 32:1 or on rare occasions 50:1.
Regardless you can't go wrong with 32:1. This ratio can be used in ANY 2 cycle engine with great results.
Jun 23, 2009 | Garden
McCulloch Mcs1400 14a Electric Leaf & Branch Chipper Shredder Mulcher Garden Logo
121 people viewed this question
Top McCulloch Heavy Machinery Experts
Bill Boyd
Daryl Gleaton
Tom Chichester
Are you a McCulloch Heavy Machinery Expert? Answer questions, earn points and help others
