Question about Crafts & Hobbies
Glue gun wiring diagram - Crafts & Hobbies
5 Suggested Answers
  • 2712 Answers
SOURCE: Glue Gun Question
Gather the materials needed and place them on a flat surface near an electrical outlet. Examine the glue gun. Locate the metal rest. This is usually attached to the barrel of the gun and is shaped like a "W." Make sure it folds out and locks into place. Locate the trigger. This is just behind the barrel on the underneath side of the gun. It should be a solid piece of plastic shaped like a slice of pie. Just above the trigger, is the barrel loader. This is where the glue sticks go into the gun. Inside the barrel loader there is a smaller round piece of plastic. This is what actually pushes the glue stick through the barrel. Pull the trigger and watch the piece of plastic move with it. Pick up the electrical cord and examine it. Make sure the prongs are secure and not bent. Make sure the cord has no breaks in the outer lining and there are no frays at the base of the gun where the cord attaches. Plug the glue gun into the electrical outlet. Allow the gun to heat at least 15 minutes so it reaches operating temperature. When the gun has heated at least 15 minutes, insert a glue stick as far as it will go without forcing it. Now pull the trigger until a small drop of hot glue forms on the tip of the gun. Practice gluing on the paper plate. Pull the trigger until a ball of glue forms on the plate. Release the trigger and quickly press the tip of the gun down onto the surface of the plate and pull it to the side. This will break the glue and stop it from stringing out when you pull it away. Continue practicing until you get the right amount of glue you want for the object you imagine using. When you pull the gun away, there may be a small string but this will break off easily. When you have the perfect amount of glue and only a tiny string forming when you pull away, you are ready for your project.
Posted on Aug 27, 2008
  • 5 Answers
SOURCE: Glue Gun Troubleshooting
1. Insert your wax stick into a standard sized glue gun. The fit may be tight. The more wax you use, the smoother the fit. 2. Use a second wax stick in the gun to help advance the first, if needed. 3. Heat the gun up to temperature. 4. Do a few test pulls on the gun to get a feel for the quantity of wax you would like to use with your seal. (Two good pulls of the trigger will produce a full seal for the larger sealing coins.) 5. Wait for 10-15 seconds, then press your seal firmly into the wax before it hardens. 6. Lift the seal slowly off the wax. If it comes away and the wax is still quite soft, wait a little longer before pressing the seal down.
SOURCE: Glue gun support
Try using denatured alcohol from your local hdwe store along with a rag, comb, and even a toothpick . A test area would be my first idea; color fastness and while there is not much odor it may affect some people with allergies and respiratory problems. It will take some time but be careful not to saturate the carpet itself just the immediate area; the alcohol may breakdown adhesives bonding the carpet fibers to the backing or seaming tape on the underside.
Posted on Jan 09, 2009
sonicboomele
  • 1557 Answers
SOURCE: I have a glue gun
i actually did this to one of my workshop guns i found the best way to fix it was to heat the gun up using a hair dryer and then pushing the old glue back up the tube and out and now when im not using the guns i take the glue stick completely out
best of luck
merry christmas
Posted on Dec 07, 2010
How do i reassemble the wiring in my gun..Where does the wire from the thermocouple go to?
I got to be honest, if your gun is this far apart I would recommend replacing as they are relatively cheap. You would be a lot safer by disposing of it.
Jan 09, 2015 | Bostik Hot Melt Glue Guns Adhesives
What surfaces can I use my glue gun on?
Hot glue guns can be used on wood, foam, plastics, metal, wires in electrical devices, diapers, cardboard, fiberboard, and paperboard, although it works better on some surfaces than on others. In addition, it can be used to bond two different surfaces together, or to fill in gaps.
Feb 26, 2013 | Crafts & Hobbies
How to use wire stand on glue gun
the wire stand is there to stop the glue from melting and dripping out the end when you aren't using it. simply fold the wire stand out so that the gun can rest at a 45 degree angle. i would still advise you to set the gun on the wire stand on a paper towel or something, because it may still drip a little.
Feb 16, 2013 | FPC Corporation Trigger fed glue gun
My glue gun stopped squirting melted glue. The volt of the outlet is 250v. My gun's volt is 230v.
Is the glue not heating at all? or is it melting but just not squirting out? In general, a 230 volt gun should work in a 250 volt outlet. If it was bought in Europe, Australia, etc. than it might have different wiring that would cause a problem for use in America, but if you bought it in the states, the problem must be with the gun itself
Feb 15, 2013 | Crafts & Hobbies
Wires detached stanley hot glue gun
Not sure about the wires, but you can contact Stanley customer support here:
http://www.stanleytools.com/default.asp?TYPE=STATICLEFT&PAGE=Support.htm&LEFT=left_support.htm
also, check and see if the gun is still under warranty, you may be able to exchange it for a new one
Dec 24, 2012 | Stanley Bostich Heavy Duty Dual Melt Glue...
How to put a glue gun back together
contact arrow customer service at this link
http://www.arrowfastener.com/requests
and ask them for a manual or a repair diagram
Oct 20, 2012 | Aerobie 12 Mini Glue Guns By Arrow...
Put back together my arrow TR400DT glue gun
contact arrow customer service here
you may need to get a new gun, but they may be able to send you a service diagram explaining how to fix the trigger
Oct 04, 2012 | Aerobie Arrow Fastener TR400DT Dual Temp...
HOW IS THE INSIDE WIRES WIRED?
This is a cordless glue gun... which wires are you referring to?
Sep 13, 2012 | FPC Corporation FPC Pro700 Cordless...
I have a new Surebonder rechargeable glue gun. I was gluing a large pc. and rushed to get another stick and it would not feed by pulling the trigger, There was one glue stick (partial) still in gun, but...
it sound like the charge ran down, recharable glue guns are not typically recomended for large project becuase heating elements run down batteries very quickly. to get the stick out of your gun, you will need to fully charge it and then after that turn it on and when its warm pull the trigger and the glue should once again come out, For large project I would recommend you purchase a wired (plug in the wall) type glue gun. Thanks for you question
Mar 22, 2011 | Crafts & Hobbies
Crafts & Hobbies Logo
57 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
