Question about Airstrike Bell 800 Frame Mount Bicycle Tire Pump
Bicycle tire pump won't pump.
I get heavy resistance when I try to pump the pump.It feels like there is a clog or something but very little air is getting through to the tire.
    Problem Solver:
  • 11 Answers
If you can? unscrew the two pieces of the pump clean and oil it. W/D40 works pretty good.
Posted on May 03, 2009
Resistance when I try to pump, no air enters tire.
Make sure that the end isn't bent and connects to tire good. You will here a little air escaping if hooked up correctly. If that isn't it make sure there is no obstuction in the air line. Release relief valve and let air out.
It could just be the end, your connection to the tire, or at worse a bad pump.
May 29, 2016 | Bell Airstrike 1000 Gauge Frame Pump
Me more elite gas range, left front burner is very hard to light, the igniter sparks as strong as all the others on the range, I can smell the gas and hear it but it only lights after turning the burner...
look for clogs in the air passages - pull the burner cover and pot stand off ( will gas off of course) and clean out with something like a bicycle tire pump or something like that
Jul 11, 2014 | Kitchen Ranges
How do you use it?
there is a little switch looking thing that has to be lifted up from the pump then insert the valve into the bike pump and then puch the switch/lever back down and start pumping then to take off lift lever and quickly take pump off valve otherwise you will lose air you just put into tire
Mar 13, 2013 | Zefal Bicycle Duo 821 XLT Frame Pumps
I have a "Judge"
Sure, A new O-ring and a little grease, the same you use on your bearings to make a good seal.
Without seeing and feeling the actual pump, a sloppy O-ring will cause a loss of pressure.
You will also want to check the head and make sure the rubber still makes a seal around the tube valve, if not then that will need to be replaced as well.
Mar 20, 2011 | Airstrike Bell 1800 Floor Bike Pump
The pressure gauge on my Topeak Joe Blow Ace floor pump is not working. The pump works fine. How do i take the pump apart and what should I be trying to do to repair?
http://www.ehow.com/how_4779541_inflate-bicycle-tire-presta-valve.html
  1. Rotate the wheel so the valve is resting just above the floor. Remove the valve cap.
  2. Unscrew the locking nut on the valve stem. Quickly press down the stem to loosen the seal. You should hear air escaping when the stem is pushed in--if you do not, loosen the nut and try again.
  3. Press the pump head onto the valve and flip the locking lever to make a seal. You'll hear air escape, but it should stop after you've locked the lever. If air continues to leak out, remove the pump head and reattach it.
  4. Make two pump strokes and listen for air moving into the tire. If the pump handle becomes hard to press down after only a few strokes, or if the pressure gauge elevates extremely quickly, remove the pump head and repeat Step 3.
  5. Inflate the tire to its recommended pressure. Remove the head by unlocking its lever and quickly pulling it off the valve stem. Secure the valve's locking nut and cap.
Presta Compressor Toolwww.prestaflator.comInflate Road or Mountain Bike Tires Accurately in Seconds!
Read more: How to Inflate a Bicycle Tire With a Presta Valve ' eHow.com http://www.ehow.com/how_4779541_inflate-bicycle-tire-presta-valve.html#ixzz1Brv5VfAX
Jan 09, 2011 | Topeak Joe Blow Ace Floor Pump
What tire pressure should I use in my mountain bike tires?
The appropriate mountain bike tire pressure can vary significantly between rider to rider and tire setup to tire setup. Trail conditions and the type of terrain can also greatly effect what tire pressure you should run.
The real trick is to find out exactly what mountain bike tire pressure works best for you and your setup under normal conditions. You can then learn to adjust this pressure for different trails and terrain as needed.
Here's the best way I have found to get to the right pressure for your setup:
Find a good reliable pressure gauge or a pump with a pressure gauge. Use this same gauge or pump the whole time you are making adjustments. Gauges are notoriously inaccurate so if you switch around it will make things much more difficult.
Start with a higher pressure somewhere around 40-50 psi (3-3.5 bar)for for 2.2-2.3 inch tires. For tubeless systems, start much lower, 30 to 40 psi. The heavier you are or the smaller your tires, the higher pressure you should start with. Ride with this pressure for a while and get a feel for how the tires hook up in corners and on loose dirt.
Now, drop the pressure by 5 psi (0.35 bar) in each tire. Once again get a feel for how this new setup rides and compare it to the previous setting. You should feel some improvement in tire hookup with the ground and a little more stability. If you don't notice any difference drop the pressure by another 5 psi (0.35 bar).
What you want to find is the lowest pressure you can ride without sacrificing pinch flat resistance. You get a pinch flat when your tire rolls over an object and compresses to the point where the tire and tube literally get pinched between the object and the rim of the wheel. This commonly results in a snake bite or double puncture in the tube.
Continue to reduce tire pressure by 3-5 psi (0.1-0.3 bar) until you feel the tires are hooking up well. If you go too far, you will start getting pinch flats, so stop dropping pressure in your tires as soon as you feel you have good control or you no longer notice any improvement between pressure drops.
If you start feeling your rims contact objects or if you start getting pinch flats, raise the pressure back up in small intervals.
In tubeless systems, since you don't have to worry about pinch flats so much, you can run much lower pressures and some occasional rim contact is OK, but if you start denting your rims, burping air out along the bead, or if you feel the tire roll under the rim during hard cornering, you have gone too low.
There is another balance you play with tire pressure. Lower pressure does increase rolling resistance. However, some argue, the increased control and climbing traction makes up for the extra effort needed to compensate for the extra rolling resistance. I lean toward running nearly as low pressure as you can get away with. Cross country racers may decide to sacrifice a little control for a little better efficiency.
Dec 21, 2010 | Cycling
HOW DO I PUT AIR IN A MOUNTAIN BIKE TIRE WITH A PRESTA VALVE WITH A TOPEAK MINI MASTERBLASTER PUMP.
Nov 02, 2010 | Topeak Mini Master Blaster
I cant find p175 80 r 13 tires for my reliant 1985 ..what do i do, they are making them as trailer tires now
I'd go with 185/70/13. Speedo will read 62 mph when doing 60 mph, but on that year it shouldn't affect anything else enough to be worried about it. Tire will be slightly wider, which will make steering feel a little more responsive, as in pay attention for first while when driving, it will feel like it turns a little quicker when steering wheel moved, so just pay attention a little more in beginning until your used to it, but most people won't even notice. Also make sure you get the proper feel if in snow/slush, or heavy rains, due to wider tire, may tend to hydroplane slightly more. Check with your installer, and they should be able to advise according to your driving conditions.
Oct 15, 2010 | 1985 Plymouth Reliant
I have just purchased a Topeak Mountain Morph pump, which can be used with both Presta/Scrader valves. I have a presta valve on my bike, but am not able to inflate my bike. Not sure if I am doing...
Aug 25, 2010 | Topeak Morph Pump
Topeak joe blow pumps front but not rear tire
What's different?
http://www.youtube.com/watch?v=Ehf6HL0aLTc
Aug 21, 2010 | Topeak Joe Blow Ace Floor Pump
Airstrike Bell  800 Frame Mount Bicycle Tire Pump Logo
1,480 people viewed this question
Top Airstrike Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you an Airstrike Cycling Expert? Answer questions, earn points and help others
