Question about Nokia 3100
Nokia 6100 In the display mentioned "Contact Service" what is the possible solution for this. I don't have software program.
Try to freshen up ur fones memory by removing ur battery and sim.if it still persist,go to BISMARK TELECOM
Posted on Oct 17, 2007
SOURCE:
Clear contact service display on nokia c2-00
How can i resolve this problem? Contact service
Dec 10, 2017 | Nokia mobile C2-00 Dual SIMbiosis
I would like to change from french to english on nokia 6100
Go to phone settings and select the option display. You can find the the settings for language there you can choose your language.
OR:
you can find in the settings>>phone settings>>language.
hope this helps.
if you need, and you don't have copy of the manual, let me know
Nov 02, 2012 | Nokia 6100
In nokia 5200,phone setting has a option to software update when i select this the rply is "no setting found contact ur service provider".i'm using aircel so plz give me suggestion how to i...
"No setting found contact your service provider" means you have No Internet Connection.(GPRS).But Don't ever try to do this procedure it is working only 10% in the universe.If you want to update your phone better to contact mobile repairing shop Or Follow the tricks what I've given below.The only thing you have to buy is original USB Cable.
First download and install Pheonix from this link. Nokia Phoenix Service Software 2011 - Download secondly Download flash file from this link Rm-181 file /Rm-174 file.(there are two types of 5200 so,I've given two files, choose what is written in your phone) and install it to C / program files/pheonix.. after finished this installation open pheonix . Inside the interface at the> top left <there you see "File" click there and choose "open file" and then select the approprait Product type i.e "which is written on the back panel inside the battery of every Nokia(Type RM-000).After doing this again at the left top count from "File"1..2..3..the 4th one is "Flashing" press there, when you click there you'll see three sub-menus, just select the "Firmware Update" again you'll see another interface. Look at the product code there should be blank and put your "mouse tool" at the straight end from the "Product Code" there is a Button and choose the code which is written in the back side of your phone. e.g CODE:0000000.if the same code does not found just take one which is higher. After this you can see "Dead phone USB flashing" click that box. Now this is the last stage... Connect your phone with the USB to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just finished (In case your phone is Dead, unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish" button after this, a message will prompt you "press power botton" etc. insert charger or press it and wait until the phone will Restart automatically in normal mode 10-15 minutes. If you cannot understand just leave a Comment / Click here1. thanks for visiting fixya. Good luck.
Aug 31, 2011 | Nokia 5200 Cellular Phone
Contact service of nokia 6100 flashing ok but ui settings not responding
Hi
Instead of flashing you can unlock your mobile by using codes.you Can get free codes from http://www.unlock-free.com/nokia/nokia-6100.html.Try this dude.
Jan 24, 2011 | Nokia 6100
Cannot connect my nokia 6100 with pc by ca 42 data cable
Hi Friend,
You have to install the Nokia PC suite required for the Nokia 6100
i will provide the link for you download the pcsuite for the Nokia and install in your PC and then try to connect the mobile and the PC
http://www.nokia-asia.com/get-support-and-software/download-software/nokia-pc-suites/compatibility-and-download#download
Copy and pate the above mentioned link in the browser
select your model in the table provided
then at the bottom select your language
u will be able to save it to your Pc
Regards,
Ayyasam
Jun 26, 2009 | Nokia 6100
Nokia 2626 contact service
SOLUTION NOKIA 2626 CONTACTE SERVICE
Jan 27, 2008 | Cell Phones
Contact service
Maybe the hardware got wrong. Better u try to reset the software by restore factory setting. def password : 12345
Jan 22, 2008 | Nokia 1600 Cellular Phone
Nokia 6100
Contact Service ... There something seriously wrong with your phone and it needs technical attention.
Sep 25, 2007 | Nokia 6100
Nokia 3100 Logo
73 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
