Question about Fisher and Paykel DG08 Electric Dryer
Hear motor and lights are on, but won't start
    Problem Solver:
  • 12 Answers
Possible broken or off pulley belt. Check those first.
Posted on Oct 22, 2013
It will not turn on. When I unplug it and plug it back in the start light is constantly blinking. I checked for error codes and the 4 lights blink 9 times and the start button blinks 14 times.
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
https://www.youtube.com/watch?v=MhVUEhngZMg
https://www.youtube.com/watch?v=9xD7lCXJ0ZM
https://www.youtube.com/watch?v=sTRP6kHqAFs
Hey GOD IS GOOD !!!! WHICH IS WHY MY ADVICE IS FREE
Kenmore Whirlpool Dryer Won Start Easy Fix What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix Troubleshooting Why Your Dryer Won Start PartSelect com
Nov 09, 2015 | Kenmore Dryers
Ac fan not running, but compressor runs on and off
switch/ fuse possible if it has one, if not one of the wire going to the motor was severed, or the start up capacitor of the motor if it also has one.
Jun 04, 2013 | Frigidaire FAX054P7A Wall/Window Air...
1991 Toyota corolla seca won't start
With headlights on, try to start the car.
While engaging the starter: Do the lights dim? Do you hear anything? If so, what do you hear?
Mar 30, 2013 | Toyota Corolla Cars & Trucks
Won't spin
The start relay on the motor is bad and you will need to replace the motor. The relay is not sold separate. Here is the motor you need to order.
Oct 30, 2012 | Frigidaire AEQ7000EG Affinity Series...
Car won't start all lights come on thinking it is a fuse for starter?
When you do turn the ignition switch if you do not hear anything is possible the starter motor solenoid.,check also the battery terminals for miss contact,remove and brush the dirt between , or bad earth.
Aug 26, 2012 | 2008 Ford Focus
Starter motor on 130hp Johnson outboard won't
does it turn or can you hear a click as you try ? if its not turning check the starter brushes and if it clicks then replace solinoide !
Apr 04, 2012 | Yamaha Boating
Kenmore 90 series dryer..motor won't turn..hear the klicking sound..kind of hums...but won't turn. changed motor..same problem
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 11, 2011 | Dryers
Water fills in, but wash cycle won't start. spin cycle works, changed motor still won't work
Its either in the lid switch or timer. Examine the lid switch. Try starting the wash cycle and press in on lid switch to make sure it activates. If the lid switch is good and you dont hear the motor trying to activate during wash than its in the timer. Does the timer advance? Please comment me back If you need further assistance.
Jul 28, 2011 | Maytag Atlantis MAV6000 Top Load Washer
I have a09 street bob that won't start. The lights come on, I can hear the engine whine when I put it in on, but when I press the start I get nothing. Not even so much as a click.
Sounds like a battery low on charge. As the bike has huge pistons compared to a 4 cylinder machine, it's harder for the starter motor to turn and needs more power.
Try charging the battery, on a proper charger not an optimate battery conditioner type.
When starting turn any ancilaries (lights, heated grips etc) off.
Good Luck
Jul 15, 2011 | Harley Davidson Boulevard 400 Motorcycles
My dodge dakota truck will not start. It has power we tried to pop the clutch too.
do you mean the truck won`t start and run or do you mean it won`t turn over with the key.if it won`t turn over with the key the you may have a starter problem.if you mean won`t start then it could be the fuel pump not working.with someone cranking the motor you should hear the fuel pump running with the gas cap off and listening at the filler neck.or hear it running listening under the truck at the gas tank.if you don`t hear it then you can hit the tack sharply with your hand or a rubber hammer,it hear the pump start to run then the fuel pump needs replacing.if not check the fuses under the dash and under the hood.if they are good then it may be the pump relay in the relay box under the hood and it should be marked on the box or lid.
Apr 16, 2011 | 2000 Dodge Dakota Quad Cab
Fisher and Paykel DG08 Electric Dryer Logo
65 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Bill Eager
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
