Question about Amana F1560 Microwave Oven
Lamona HJA 7020 not heating up on microwave setting
Change a bulb in a Lamona electric oven & grill
usually just unscrew it as any normal light bulb and put in a new OVEN proof bulb . standards will not last in excessive heat .
Mar 09, 2015 | In Microwave Ovens
What is the reason for high voltage fuse to blow outon microwave.
The only reason for any fuse to "blow" open is a direct short. The most common reason, in a microwave oven, is the Magnetron. This is the device that generates the microwaves. If this is the case, repair is not very economical.
If you have a volt meter or a device that can check for resistance, check for anything that is shorted or "0" Ohms to ground.
I hope that his helps answer your question.
If you have any further questions please feel free to ask.
Mar 01, 2015 | Microwave Ovens
Can anyone please advise on Lamona combi HSA7020 which will not work as a microwave despite all the display looking as if it will heat up but then it doesn't?
mw not working is either the magnetron or the diodes in the HV power supply.
If u r brave and want to fix it start with the diodes as they r a lot cheaper than the magnetron. Otherwise, take it to the dump.
Dec 09, 2014 | Microwave Ovens
Lamona HJA7020
FIRST REMOVE THE POWER CORD FROM POWER SOCKET AND OPEN THE COVER OF MICROWAVE OVEN REPLACE THE BULB
Jan 04, 2014 | Microwave Ovens
I need a Lamona microwave/grill manual
Start by contacting you distributor of the appliance to get a lead on the manufacturer. They will provide the manual. Be sure to state whether you want the customer user manual or the technical manual.
Oct 20, 2013 | Microwave Ovens
We have a Lamona HJA7020 microwave and it is not heating up? Help please
Someone can take the cover off the microwave and see if there is a replaceable fuse.
Some have them, some do not.
If there is none, likely the magnetron has failed, and it is time to replace the machine, as new magentrons often cost more than a new microwave.
God bless your efforts.
Caution: Stay away from the capacitor. If you don't know what that is, let someone who knows do this.
Aug 15, 2011 | Amana F1560 Microwave Oven
Lamona microwave has stopped heating everything else is working but food is the same temperature when finnished
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 08, 2011 | Microwave Ovens
My intergrated lamona microwave is only 18 months old and has stopped heating the food
heatman101
My Lamona single fan oven. The problem is it always flashes to 'auto PO:OO' so the oven does not go on unless it stops flashing and then sets it self for two minutes, sometimes it stays on the flash mode...
can someone please tell me what is wrong with my Lamona single oven it will not turn off. you have to switch it off by useing the switch on the wall if you can help please email me
sarahnichols206@hotmail.com
Oct 17, 2010 | Microwave Ovens
Amana F1560 Microwave Oven Logo
91 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
