Question about EnGenius DURAFON1X DuraFon 1X System Phone
Wont connect to base - EnGenius DURAFON1X DuraFon 1X System Phone
My kettle wont start. it seems the connection from the base to the kettle is not connecting. if I hold the kettle firmly down it will start but as soon as I take weight off the kettle it stops.
The contacts inside the base are carboned up and possibly misaligned. Take the base apart and clean the contacts with a nail file, check the alignment and correct if needed. Also clean the contacts on the bottom of the kettle. If you still have the same issue, open the base and inset a small piece of cork gasket material under the three contacts so they will not drop down when you put the kettle on top of the base. Don't make the cork pieces too thick or the kettle will not sit flat.
Mar 05, 2015 | Magimix Brushed Stainless Steel Jug Kettle...
THE HEADPHONES ARE CHARGED BUT WONT WORK. THERE IS A CONTIOUSE GREEN LIGHT WHICH IS ON. ON THE HEADPHONES.
Wireless? Are they connecting with the base? Try unplugging the base to reconnect. What are they connecting to? TV? computer? What?
Nov 10, 2012 | Sennheiser RS 120 Consumer Headphones
The phone wont pick up the base and the phones wont charge on the base - there is power to the base
Check that the connections are clean and the battery is good. Interstate Batteries carry lots of batteries and can make you one if they don't have what you need.
Sep 19, 2012 | Siemens Gigaset A140 Cordless Phone
My phone doesn't have dial tone. Each time I dial a number and try to call,it wont work. I call my phone but it wont ring. I need help on this. What happen to the phone? Or what should I do?
If you have another phone connect it to the wall outlet to see if you get a dial tone. This will indicate if your base unit is faulty.
Check the power adapter to the base unit, make sure it is getting mains power.
If the base unit has dual phone lines and if line 1 is only connected and the line 2 has beed selected then you cannot get a dial tone. In the chase press the line 1 to get a dial tone.
If your base unit has only one line then check the phone line at the wall socket make sure it is plugged in tight, also check the the connection at the base unit.
If this does not work then ring the phone company and get the to test your phone line, you may have a faulty line to your home.
Feb 03, 2012 | AT&T E2116 2.4 GHz Cordless Phone
My phone is showing OUT OF RANGE message and wont let me dial out. Please help
You phone has lost the connection to the base set...
Either you are too far away...
The base set has become unplugged from the power or the phone line...
or the base set has stopped transmitting a signal for the phone to pick up.
heatman101
Jun 18, 2011 | Office Equipment & Supplies
The phone lights up when put to charge also the red light on the base,, but when the phone line is connected it wont work ..What do u think is the problem?
The battery in the handset could be bad . First I would test that the base unit is recieving dial tone by pressing speaker button on base unit. If there is dial tone then problem is in handset or in base unit communication to handset. Try resetting power to base unit. Check manual for any re-initialization procedure. If the base unit is not receiving dial tone then I would test that the phone line is delivering dial tone to the base unit by connecting a known good phone to the line cord. If the dial tone is not present , problem could be in line cord from outlet, outlet, building wiring, or service provider.
Dec 08, 2010 | Uniden Cordless Phone
My uniden DSS7855 with 1 base station and 3 handsets wont connect when i dial a number and hit the talk button it tries to connect and then comes up "'out of range" much appreciated for any help...
Clear the Handset's Base Data
  1. To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.
  2. It will now be de-registered from the base.
Note: This requires that the base and handset can communicate with each other.
Clear the Base Handset Data
  1. To de-register all handsets from the base, remove power to the base, and remove the handset from the base.
  2. Press and hold the 'flash/find hs' button while applying power.
  3. Wait for the beep and release the button.
  4. The charge light will now flash.
  5. Sit any handset in the cradle.
  6. When the flashing stops, re-register the handsets to the base.
Re-Register a Handset to the Base
1. Remove Handset Battery.
2. Reconnect battery while holding down "*" and "#" key.
3. Then press the right upper key under the LCD.
4. Press the "End" key.
5. Wait a few seconds and then the phone will be ready to register to the base.
Nov 12, 2010 | Uniden Lands Phones
Uniden 2.4 GHz cordless phone won't register to base
Same happened to me. Unplug the base from power and the phone line for 30 minutes. Same for the handsets - all. Take out the batteries. Retry. After it says 'registration failed'. Leave it in the cradle. Several minutes later it found itself.
Mar 10, 2009 | Uniden 2.4 GHz Cordless Phone System
Handsets wont work at all
it may be that the handset is registred to another base unit-
we had one base and one handset replaced by uniden, but the second (old) handset was still registred to the old base, therefore everytime we tried to deregister the handset it was looking for the old (replaced) base and of course could not connect and therefore wouldnt deregister. still havent figured out what to do yet
Dec 20, 2008 | Lands Phones
EnGenius DURAFON1X DuraFon 1X System Phone Logo
19 people viewed this question
Top EnGenius Lands Phones Experts
John L radiodude365
Bill Boyd
Are you an EnGenius Lands Phone Expert? Answer questions, earn points and help others
