Question about Adidas PEACHTREE watch
Watch reads offset and wont change menu to change time or any thing.
    New Friend:
">Thanks for the hook to gettin' this watch prob resolved. Had the thing for few years and only now is it running like it was designed to.
Posted on Oct 24, 2013
Silicon scientific atomic watch
Should be 4 buttons, 2 on left and 2 on right. Press bottom left 3 times and hour offset digit will be displayed. Press and hold top left until hour offset digit starts to flash. Press either top or bottom right to adjust offset hour to correspond with your time zone. Eastern -5, central -6, mountain -7, pacific -8. These are negative numbers, not positive. Then press top left button once, then press bottom left button to return to time display.
Jul 31, 2016 | ATOMIC Watches
How to set for 24 hrs.
Dec 29, 2015 | Watches
How do I unlock settings (general, user, exercise)?
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs..
Jul 26, 2012 | Polar Electro RS400 Watch
I have done everything possible to set my Adidas Seoul watch but nothing is working. I have read the manual. When I press the D button, it only brings turns on and off the music.
Figured it out - Press & hold 'A' then press 'D'. THEN press 'B' to toggle through the selections to set T1. T2 (for another time zone) is up or down in the offset. Good luck!
btw - A, B buttons are from top to bottom on left and C, D are top to bottom right
Feb 01, 2011 | Adidas ADH1572 Watch
Just bought an Adidas Seoul Watch ADH2044 and can't set the time. I've looked in the manual that came with it and online and can't find anything to help. The Adidas website isn't any help either.
Jan 07, 2011 | Adidas ADH1572 Watch
I need help setiing the time on my adidas adh4004 watch. The manual wont help!
You are right the manual is useless.
To set the watch it needs to be in T1 setting, you can do this by using the C (top right) button, to chose just push once and the number should change, hold to set it to T1.
After that, push the A button (top left), this should hopefully display 'Light'. If it still displays 'Offset' then you are still in T2 (offset lets you offset the GMT). Try the C steps again.
Once 'light' appears you can scroll through the menu using B (bottom left), at which point you should find the time selection option. It should be flasing, use the two far right up and down buttons to then set the time/date etc. Press B to move on to the next setting. When you are done press A.
Nov 02, 2009 | Watches
Diesel DZ7069 watch - how do I set the correct date/time?
ok ,here it is .
Instructions To Set The Time On The Diesel DZ7071 Watch
Ok the first and most important thing to know about this watch is that it has an unusual timezone function (unusual to me at least). This allows the watch to display two different times. Time 1 (or T1) is the primary time (the time of the place where you spend most of your time!). The time can only be adjusted whilst the watch is in the T1 mode (T1 should be displayed in the bottom left corner of the screen). Holding down the top right button for one or two seconds will temporarily replace the current T1 time with the T2 time. Holding down this same button for several seconds will toggle the current time mode to T2 and the watch will continue to function in the second time zone until you toggle it back to T1.
The second most important thing to know is that you can only set the time whilst in the T1 mode. When in T1 mode hold down the top left button until the watch enters the settings menu (it should say "Light" at the top of the screen) now use the bottom left button to toggle through the settings menu until you get to the time settings. I think this part of the process if sufficiently straight forward so I'm not going to go into more details here, all I'll add is that once you have the watch set to the desired time mode 12h/24h time and date you just need to press the top left button to save the settings and return to the main time screen.
To set a secondary timezone time you have to first toggle the watch to the secondary time zone mode (hold the top right button for several seconds and the T1 indicator should change to T2 (and the watch will now be displaying the time that is currently set for the secondary timezone). This time is based on the primary time by simply telling the watch a number of whole hours ahead or behind the primary time. To adjust this hold down the top left button for several seconds, the watch will then say "offset" now use the buttons on the right to add or subtract hours from the primary time. Once set press the top left button again to return to the main time screen. Finally hold down the top right button for several seconds once more to return the watch to the T1 mode.
May 14, 2009 | Diesel Digital Dz7069 watch
How to set time on Diesel DZ 7071 Watch
Just figured it out!! Press and hold Set/El button. Wait until LIGHT On/Off (or similar) flashes on screen. When it does then press the Mode button to scroll through various functions including setting the time. Hope this makes sense and helps
Dec 20, 2007 | Watches
Setting watch
Alright, so the actual solution probably revolves around the fact you are stuck on "T2" time mode. This is found by a symbol that reads either "T1" or "T2" directly above the seconds. So first make sure you are in "T1" by holding the ST/SP button first, then holding the SET button second and simultaneously. After holding both for a couple seconds, the mode will switch from either T1 to T2 or T2 to T1. Once you get the T1 to be selected, you can then press and hold the SET button. Once that is held long enough, a menu will pop up saying "Chime" as the first display. Press the Mode button to start displaying the other features, such as hour, minute, second, month, date, etc. To make changes within a selection use the ST/SP and RESET as up and down changes. When you are all done and back to the Chime feature, you can press SET to exit out of the menu.
As a side note, the T2 function is based off your T1 time, so if you are in a different time zone, you can offset the time by however many hours you off from the T1 time - but the key is to get the T1 time set first.
Hope this helps.
Nov 12, 2007 | Columbia All Sport Digital watch
Compass wont work correctly
if your hands aren't straight when you use the compass try this to sync the hands.
1. Press and hold the middle button to enter T-Touch mode.
2. Press the centre area on the face twice to display 24hr/12hr
3. Press and hold the middle button to enter T-Touch mode untill screen says sync.The hands will face 1200.
4. Press either the upper (East) or lower (West) button to adjust the compass hands. They should both face 1200.
5. Press the middle button to get back to 'regular' compass mode. Note that your offset setting will still show in the digital area.
Oct 10, 2007 | Tissot T-Touch T33759851
Adidas PEACHTREE watch Logo
226 people viewed this question
Top Adidas Watches Experts
Ansel Alberto
Ansel Alberto
Vuk B
Are you an Adidas Watch Expert? Answer questions, earn points and help others
