Question about Dryers
What could be wrong with my dryer its blinking but wont start?
  • 119 Answers
You need to give more details for us to help you
Posted on Oct 16, 2013
GLEQ2152ES0 dryer stops after ten minutes and then blinking lights on the right of the side panel. The lights that blink simultaneously.
The dryer is telling you what is wrong with it. Count the number of flashes the drying, cooldown, pressaver and clean filter light are flashing then count the number of times the control/start light is flashing. That will give you the error code number.
Dec 04, 2016 | Dryers
Frigidaire Dryer model # LEQ1442ES0. The lights come on and beep at us like normal when I change settings but when I press start, they just blink and beep but wont turn on.
Thank you for your post, friend!
From my understanding your Frigidaire dryer is not starting and the lights just blink. It sounds like a faulty door switch or control panel. I would check to make sure the latch or door strike is not cracked or broken if the door is not closing properly that could be the cause of your dryer not starting.
You could also perform a reset on your dryer and that could help clear any faulty error codes within your dryer. To reset your dryer you would unplug the power cord for ten minutes. I hope this has been beneficial. -Matt
Oct 17, 2014 | Frigidaire Dryers
The dryer starts then after about 10-15 minutes it stops and all of the buttons are blinking.
how long b4 u can start it agin?
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Jun 02, 2014 | Frigidaire GLEQ2152ES Electric Dryer
Kenmore gas dryer model 84152 wont start
-Make sure turn select knob to correct position.
-try again.
Good luck
Mai
Dec 16, 2013 | Kenmore 800 7982 Dryer
My dryer will not start. the start/pause button on the dryer just blinks when i try to turn the dryer on.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 01, 2011 | GE Profile Wizard DPSE592EAWW Electric...
My Kenmore Dryer, Model #66712690 does not turn on. I have checked the fuse box to verify that the unit has power. What could possibly be wrong?
if you can here the motor running then it is the belt, here is a website that will give instructions as to change the belt, the second is if it won't start:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Oct 27, 2010 | Kenmore 66972 Dryer
Power is on, push start button, light blinks on front but will not run?
may be a reset button on motor:
Oct 24, 2010 | Samsung 7.3 Cu. Ft. Super Capacity...
Whrilpool dryer wont start set selector press start and all lights blink and dryer makes clicking nosie from apprears bottom rear
Sounds like something you will need a repair man for.Unless you are mechanically inclined it sounds like it's electrical.
Oct 20, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer starts but wont stay on
There is a switch on the motor that activates when the drum is turning at the proper speed. This switch should be checked if the drum is turning properly.
Eric
Jun 14, 2009 | Kenmore Dryers
My ge dryer wont start
Hi thanks for the question. You could have a problem with the door switch, On that dryer theres a belt break switch.check that
Dec 16, 2008 | GE DWXR483EBCC Electric Dryer
Dryers Logo
Top Dryers Experts
