Question about LG Washing Machines
My lg wm2233hd model washer was running fine then made a horrible noise so I stopped it. I tnoughtI maybe put to many clothes in it so I took some out and restarted it and it was fine . I then stopped it put the other clothes back in and it wouldn't do anything. I've tried unplugging it, tried a new load of clothes and it won't start the load. What can I do?
SOURCE: GE Top load washer makes horrible noise when agitating clothes
it's off balance
Posted on Dec 15, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: LG WD-3243RHD Front Load Makes grinding, crackling noise
Check the motor at the bottom of the machine. Also check the timer on the unit to make sure the timer is work
Posted on Feb 10, 2009
SOURCE: Fisher/Paykel Smart-drive 5.5 auto washing
hi i turn on the wasing machine set the settings and press start -nothing happens -no water running can someone please help?
Posted on Aug 10, 2011
  • 6277 Answers
SOURCE: Hotpoint Aqualtis AQ9L29I 1200 9kg washer has
Check that the washer supply is OK using another item - a kettle for instance. If it's not check your breakers/fuses. Reset/replace if necessary and if the same thing happens, or if there was nothing wrong with the breakers/fuses in the first place, sorry but with such a fault it is virtually impossible for anybody on this forum to remotely guess what could be wrong with your washer. It could be internal wiring/plugs sockets, control panel switches, control PCB.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Aug 12, 2011
richroth
  • 9472 Answers
SOURCE: Kenmore 70 series washer making knocking noise
Check to see that the springs that hold the tub assembly to the frame are attached. Sounds like one may have come off on the machine.
Posted on Oct 12, 2011
My Maytag washer model MAV208DAWWmakes a loud screech at the end of the spin cycle, and the clothes are sill wet
That is the brake. Your clutch maybe wearing out. Or the belt maybe slipping because the rollers for the motor maybe wearing out.
Jan 15, 2016 | Maytag Washing Machines
My washer makes a horrible noise in the final spin cycle on all washes
does ur washer shake & move also? if so, it may be that the loads r too small. especially with top loaders, when the machines not full, the clothes r not evenly distributed and that could do it. if u stop the cycle and evenly distribute the clothes, it should stop. hope that helps.
Jan 10, 2012 | Whirlpool Washing Machines
Near the end of the rinse cycle there was a load noise accompanied with a lot of vibration. I stopped it and took out the wet clothes and fininshed manually. To test i put the machne on spin cycle and...
if the clothes bunch up on one side the tub doesn't spin evenly and goes off balance,the tub will start banging all around,if this happens,open the lid and move the clothes around to even them out so all the wieght isn't on one side,it's a common thing mostly with a few items in the washer but can happen with any size load.if it keeps happening send the brand name and the model number.you should be fine.
Apr 17, 2011 | Washing Machines
My washer is about three years old. Last night as it was spinning out the clothes it started making a very loud "clunking" sound. I rearranged the clothing thinking that it was just unbalanced...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems Washer noise when spinning
heatman101
Mar 08, 2011 | Frigidaire GLTF2940ES Front Load Washer
I have a LTF2940ES1 horrible noise and wet clothes
you ahve a clogged pump
remove the toe kick
the pump will be right there on the right
get a towel and disconnect the hoses
you will see a sqaure sump take that hose off
and clean it out
check to make sure there is nothing in the pump
reassemble and should be fine
Oct 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Loud Grinding noise in Dryer
I know this prob is old, but I had the very same prob with my dryer (very loud squeaking noise). The prob was that there was a screw stuck between the rotating part and the stationary part. Meaning - look inside the dryer (main area - where the clothes go) and rotate it by hand. You may hear and see something causing the friction. Gerard
Dec 29, 2008 | GE DSXH47EGWW Electric Dryer
Excessive wobble
If there's a loud thumping noise during the spin cycle, the load of clothes has probably gotten unbalanced. Open the lid, redistribute the clothes in the washer, then re-start it. Repeat these steps if necessary.
Sep 06, 2008 | Maytag Neptune Washer
Washing Machines Logo
15 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
