Question about Sony BRAVIA Televison & Video
I got Sony Bravia Kdl-42w670a TV. i plugged aerial and tried to scan with analog and digital but couldn't find any channels. i tried to fix the aerial in different locations but nothing. I cannot find manual tuning for VHS either. Please guide me.
  • Ahmed
    Ahmed Oct 13, 2013
    i use normal cable TV antenna
4 Suggested Answers
mistersony
  • 320 Answers
SOURCE: cant get digital on my tv
The easiest way to fix this is to do a master reset and let the TV reprogram ll of the channels. You must have the original Sony TV remote to do this. When you have the remote, find the circular area of the remote with four buttons in a circle around a center button.. Turn on the TV and Press and hold the top button (the Up button) of the 4 buttons arranged in a circle. Then, while holding down this Up button, press the power button ON THE TV (not the one on the remote) and release both buttons. The TV should now reset and come up and ask for a language choice. You choose the language using the 4 keys mentioned earlier (the top and bottom of the 4 keys for up and down and once you have the choice you want, press the button in the middle). After choosing the language, it will ask to autoprogram the channels. Choose yes and let it autoprogram and all of the channels should reappear.
Posted on Nov 23, 2008
falter
  • 245 Answers
SOURCE: Sony Bravia KDL-46V4000 tuned to digital mode has
YOU LIVE IN A BAD RECEPTION AREA WHERE DIGITAL IS NOT WORKING WELL......
LOOKS LIKE U HAVE TO SWITCH TO ANALOG.....
UNTIL THIS PROBLEM IS SOLVED IN UR AREA.....
Posted on Nov 20, 2009
ladywinn
  • 5138 Answers
SOURCE: Hi There, My Sony Bravia just
What is it that you are trying to do? What are you using for a signal to TV ? Cable or Antenna?
Posted on Jul 03, 2011
How do I fix my Sony Bravia to be able to scan for free to air digital channels?
Hi
after factory setting please select both option to scan digital as well as analog channels then you can scan these channels
Feb 23, 2015 | Sony Televison & Video
My Sony KDL-52xbr4 was working fine until I did a re-scan of the digital channels. After the re-scan the TV finds no digital channels. All other TVs hooked to the same antenna work fine. The sony scans up...
Hi check to make sure the antenna is connected correctly. try tunning the channels manually and if they come up you can save them one at a time. Also try moving the antenna to a different location. make sure the TV is set to scan on the same input that you are connecting the antenna. If all that fails ou might have a defective tuner board.
You can get parts for this tv at www.interliquidparts.com
Nov 06, 2011 | Sony BRAVIA KDL-52XBR4 LCD TV
Hi, I live in a flat in London with a shared rooftop aerial (no idea of spec). I have a Sony KDL-46X2000. The built-in freeview tuner doesn't seem to recieve any HD channels. Is the built-in tuner the...
Make sure you have a good connection from antenna to TV. Check antenna and cable and cable connection to TV. Select DIGITAL button on TV remote when wanting HD channels. Remember HD channels are always digital. Also, any given TV station may not be broadcasting in HD at a given time. They can broadcast in digital but in standard definition sometimes. Your TV has a built-in DVB-T tuner. Try executing a channel scan to pick up all available channels. On-screen menus go to Digital Setup, then Digital Tuning, you can auto-tune or manual tune channels. The TV should take a few min. to scan thru available channels and store the channels its finds. Check with anyone in your area to see if they get HD channels (it is possible to be outside of the range of some TV stations) Your TV is a 2006 model and should still be compatible with local digital TV broadcasts but keep in mind digital signals could change in the near future (DVB-T2) and you may need a tuner/converter box to make the TV compatible.
May 01, 2011 | Sony Bravia KDL-46X2000 46 in. HD-Ready...
My sony Bravia KDL-37P55xx seems to be recieving no signal from our aerial. I know the aerial works as I have checked it with other tvs in the house. Is there a quick fix solution for this
Make sure that the TV is on the right setting, either TV for analog pictures, or DTV for digital. Run a complete auto-setup. This will wipe the tuner memory and re-scan. Hopefully this should sort the problem. If you have tested the aerial cable with another TV in place of that one (not just on a cable from the same aerial in another room) and it works but that one won't, then it will be down to a TV fault. If this helps, please rate me!
Jul 14, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
How do you watch free cable channels on a sony
If you are connecting the cable directly to the TV with no cable box, you'll select Home on the remote control. This will put the menu on screen. Scroll down until you find the Channel Settings option. Set the Cable category to On, Select Auto Program to automatically scan for all analog and digital channels. You can then customize which channels you want to remove when scanning channels.
Feb 10, 2010 | Sony BRAVIA KDL-40V3000 Television
TV works fine on analogue however won't work on digital even when re scanning. When it happened the television froze and then wouldn't work. Now all is has is "no channel available. Please scan" do you...
Power the TV off and uplug from the mains, now remove the aerial, now press the standby button the TV, now plug the mains back in and switch to a DTV channel, wait 5 secs and then put the aerial back in whilst still on that channel, now rescan.
If that didn't work, reset the TV to factory defaults and rescan again.
Thanks
Oct 08, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Can't get digitall channels
I have the same problem, If anyone could help it would be appreciated.... I have the coaxial cable plugged in which on another TV had all 85 channels, and I changed the TV from analog to digital and reprogrammed it but I still only get like 4 or 5 local channels?
Jul 09, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Where are my antenna channels ???
Please try Auto Programming the TV.
Please refer to the page number 37 in the manual to get information about Auto Programming the TV.
Select the Auto Program option under the ANALOG SETUP SETTINGS in the Menu of the TV to Auto Program the TV which should resolve the issue.
Jun 15, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
No digital picture for Sony KDL-40v2500
These tv's receive digital on the atsc 8vsb. Do you know what there broadcasting in New Zealand ? It could be that a Sony tech there can fix your problem. The TV can be set-up for a different digital broadcast and Sony is all over the world even in New Zealand .
May 04, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Televison & Video Logo
106 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
