Question about Garden
I have a husqvarna 455 rancher chainsaw aND NEED TO KNOW WHERE TO CONNECT THE KILL SWITCH WIRE THAT COMES FROM THE IGNITION MODULE
    Sergeant:
  • 322 Answers
Generally the wire goes to the kill switch which in turn is screwed down to the body of the saw creating a ground when switched to the off position
Posted on Oct 17, 2013
  • 211 Answers
SOURCE: Repaired Husqvarna 41 chainsaw won't start.
Hi
The off switch of the chainsaw has to establish the continuity to kill the running engine.First check the switch with a measure apparat.Then check the continuity of the two wiring harness,sepparately.One wire is atached to the ignition module with a screw and goes to the off position of the switch.The other one towards the on position of the switch.Check the spring!
regards savumihai71
Posted on Dec 03, 2008
spekgt
  • 60 Answers
SOURCE: 455 rancher chainsaw does not pump oil to the chain
If you look under the machine by the chain you'll see a flat head screw (next to the sprocket) which controls the bar and chain oil flow . Try to turn the screw and check if there's any oil flow to the chain . If not you will need to replace the oil pump (part # 537 10 55-02 which will cost you about $35.00) Hope this help
Posted on Aug 29, 2009
dontbother10
  • 2220 Answers
SOURCE: wanted coil ignition module for Husqvarna 394xp chainsaw
I found an IPL for your saw here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter 394 as model number (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
I chose the 92-10. The coil and wire were manufactured as separate pieces. I found both at Jacks Small engines. It is interesting that the same ignition wire fits a Poulan at 1/2 the cost. About $86 for both pieces at Jacks. HTH
Lou
Posted on Oct 19, 2009
Testimonial: "Most interesting and very helpful Thank You"
dontbother10
  • 2220 Answers
SOURCE: magneto to flywheel gap for Husqvarna 455 Chain Saw
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 22, 2010
dontbother10
  • 2220 Answers
SOURCE: , No.455 Rancher, 20" Gas - Powered Chainsaw: What is the oil mixture ratio for the Rancher 455...
50: 1; You can download an OM here:
HusqvarnaUSA.com
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years and is what Husky suggests for your saw..
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear & Jackson, Stihl & Tanaka; all recommend 50:1.
1 gallon of premium fuel to 2.6 ounces of quality 2-cycle oil.
4 liters of premium fuel to 80 milliliters of quality 2-cycle oil.
McCulloch, Poulan & Wen; recommend 40:1.
1 gallon of premium fuel to 3.2 ounces of quality 2-cycle oil.
4 liters of premium fuel to 100 milliliters of quality 2-cycle oil.
Chinese chainsaws recommend 25:1.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on May 10, 2010
Hello i have a rancher 455e with no spark at times runs a short time boggs down and dies then no start or spark ????
No spark could be a number of issues. Break in ignition wire, faulty switch, incorrect timing space, faulty ignition module, bad sparkplug or the spark plug lead.
The running problem is most likely a fueling issue, check the fuel lines, filter and make sure fuel is getting into the cylinder.
Feb 20, 2016 | Husqvarna , No.455 Rancher, 20" Gas -...
No spark with Huskvarna Rancher 55. New coil
anon re connect the kill switch. If this fail try connecting the two ends of the wire to the kill switch together.
Aug 27, 2014 | Garden
Where does the kill switch wires go
Coil too the kill switch , kill switch too the ground good clean metal.. Kill switch is just making the ground conection.. Goodluck..
Aug 11, 2014 | Husqvarna , No.455 Rancher, 20" Gas -...
Cant figure out how to hook the kill switch back up
There should be a double wire from the ignition unit, both with female terminals on, the insulated terminal is the earth return and pushes onto the spring steel ******** the side of the air filter housing, the other terminal slides into the side of the red plastic switch, if you look at the side of the switch it is moulded in the side for the terminal to slide into it.
Aug 10, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
How do you fix a broken stop switch on a 455 rancher
The stop switch is just a red plastic rocker that connects the earth cut out wire from the ignition unit, to a grouding wire to cut the ignition,it can be changed on the machine, however it is much easier to remove the air filter housing, start by removing the screws, two at the top and two at the bottom, disconnect the earth wire and the earth return wire, the upper wire has a spade conection onto the earthing strip, the lower wire also has a spade conection but just pushes into the red ignition rocker switch,unhook the choke from the carb, once the housing is removed gently pry out the blue choke pull from the housing, once removed pry off the broken rocker switch, this is sprung loaded via the earthing strip, pay close attention to how this is fitted, so as you know where to re fit if ( take a photo with a mobile phone to help with re instalation )now fit the new rocker switch, re install the earthing strip, re fit the choke pull, re assemble the air filter housing onto the back of the carb, re connect the wires.
Feb 26, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Chainsaw will not shut off using stop, I have to use the choke to shut it off. Husqvarna 455 Rancher
the wire on the stop switch probably came of the terminal. take the top cover off 3 screws ,and the air cleaner. you just replug it.
Jan 02, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
New starter switch for a husky 61
The switch grounds the ignition coil through the spade connection to stop the engine. The switch should be mounted in a metal panel (ground). Hope this helps!
Apr 17, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Magneto to flywheel gap for Husqvarna 455 Chain Saw
Ignition module gap
Lou
Mar 22, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna chainsaw no spark
Ignition systems on newer saws are a solid state all-in-one package. Disconnect the kill switch wire from the ignition pack to make sure that the switch isn't broken. Use a fresh spark plug to check spark with. An old one that is black inside is likely shorted. If still no spark, replace the ignition module. Use a piece of card stock to set the flywheel magnets to module gap, then tighten screws
Sep 11, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a 455 rancher i have spark (dont know if good spark) and gas new spark plug and air filter and it wont start.
Check to see if your ignition switch ( on& off) switch still have both wires attached. Common problem with that saw, loose or disconnected wire
Aug 16, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Garden Logo
63 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
