Question about Neiko 31228A Air Spray Texture Gun 5 Nozzles
Need parts list for Neiko 31228A texture Gun - Neiko 31228A Air Spray Texture Gun 5 Nozzles
I have a Kraft tool texture sprayer 500 model, I have noticed lately that the oil is slowly syponing out of the holding tank and its running into the air hose so when I turn it on it spits out oil lef
As the hopper gun does not use oil, you are either spraying an oil based material which is separating in the hopper, or you are using a compressor that is leaving oil in the airline; this could happen if the compressor is worn and oil is leaking past the piston into the air.
Nov 22, 2014 | Kraft PC501 Standard Texture Gun & Hopper
How do I connect the air hose to the compressor and the air gun?
Yes you need a quick release couple r kit male/female kit prob 3/8
also get a roll of Teflon tape wrap the male ends in it before you add the new fittings also you might to buy a "swivel" quick release and use it on the end that goes to the gun this helps stop the hose or line from bindind up on you and they don't cost to much oh ya keep a dab of oil on the ball bearings...
Sep 14, 2014 | US Freight Neiko Pro 2.0mm HVLP Gravity...
I need an instruction manual for a Neiko air metal shear
Try contacting a seller of Neiko tools, they do not have their own website. you can try someone like this: http://www.etoolscity.com/neiko-air-metal-shear-1-6mm-capacity
Oct 09, 2013 | Neiko Tools USA Hammering
My senco frame nail gun isn`t working
First get an exploded view of gun and parts list and numbers from senco.com,,take nail gun apart,,,take a good look at the rubber bumper stop to see if it is broken,,look at the driver nut to see if it is tight,,,,you can go to juldan.com once you have gotten a list of the worn parts,,,juldan sells complete o ring kits along with nearly all parts needed for your repair
Jan 18, 2013 | Senco Air Tools & Compressors
What is the manufacture website for neiko tools usa ...so i can replace a tool...
Neiko Tools USA are actually made in China and owned by chinese people. So, better purchase that single tool from amazon (than buying a whole set). take a look here Amazon com neiko tools. cheers
Apr 08, 2011 | Neiko Tools USA ProfessionalGrade 27Piece...
Neiko Rotary tool set 40 piece.
i check a site i use and it was not listed. what are you wanting to do?
Jun 09, 2010 | Neiko Tools USA Rotary Tool Kit with Micro...
Was wondering if anyone had any contact information for the Neiko company. for the welding helmet, it mentions that the shield should be replaced every so often, but I can't find anywhere that sells the...
Good Day To You,
Follow this link it will bring you to an on-line distributor where you can purchase what your looking for. I found several lens replacements for different helmets and a solar powered Auto darken helmet though not just the lens for it, it could be further down the list if that is what your looking for. Sometimes people just pick the closest thing to what they have. Need any further assistance will be glad to provide. Thanks for using FixYa and have a great weekend. Jeff
Neiko Welding
Apr 23, 2010 | Neiko Tools USA Solar-Powered Auto-Darken...
How do you stomp texture or stipple a ceiling?
There are a ton of different ways you can get this done. You can purchase what is called a popcorn sprayer that works like an air powered paint gun for ceilings of course you'll need a compressor also. Some hardware stores rent this equipment. You'll be spraying on a material also available at most local hardware stores that is sort of like drywall joint compound only a different consistency.
If you choose to texture by hand you can use a number of tools to get different textures paintbrushes, brooms sponges, precut stencils, rags, etc.. Basically clear out the room cover anything you don't want to get messed up gt a bucket of drywall joint compund your texture tool of choice and a trowel. spread a thin layer of compund on the ceiling and texture away. The thicker you spread it the more texture you will get. Be sure to have a helper that can switch off as this does get tiring, and you'll need extra hands to help get clean water for your tools so your texturing project is consistent. Plan accordingly, this is not a project you want to leave halfway through and finish another day. If you start a room, finish it. or you will notice the difference in texture every time you sit down and try to relax.
Feb 15, 2010 | SK 17855 Long Reach Needle Nose Compound...
Where does NEIKO USA come from?
Hi, Please do not give me a bad rating for this information as you asked and I am going to give you the answer - even though you ain't gonna like it!
Credit to "tenmmike" for his research. Neiko USA is manufactured by Zhejiang Kangle Group in China. As you have found out the USA stamp means nothing. In my opinion it should not be legal. Sorry, Good Luck to you!
Mar 13, 2009 | Neiko Tools USA Solar-Powered Auto-Darken...
Neiko 31228A Air Spray Texture Gun 5 Nozzles Logo
74 people viewed this question
Top Neiko Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you a Neiko Air Tool and Compressor Expert? Answer questions, earn points and help others
