Question about Pool & Spa
Unlock hot tub control panel
Hot Tub was BUBBLING AND Now it stopped! There is a lock sign on control panel! Just put in new fuse box and it worked. What can I do to fix it??
    Champion:
  • 305 Answers
Air lock maybe?
Posted on Dec 05, 2013
PartsCenter
  • 125 Answers
SOURCE: inside control panel displays 6522 rev GG
Aqualink Guide book
Posted on Feb 26, 2009
  • 990 Answers
SOURCE: My electric went out for 24 hours. I hooked up my
You should start with checking all your breakers to be sure the breaker did not pop just half of your breaker. This is something you should do with all your breakers. When you do this you should shut down all your 220v breakers so you don't get bleed back through the system. Other than that you need to look for resets on the tub. The heater is a good place to start and don't forget the gfci's on the tub or in the bath or laundry room.
Posted on Dec 16, 2009
Ian  Hot Tub
  • 77 Answers
SOURCE: Dream Maker spa - does my dream maker spa 4 person
Depending upon the age, the Dream Maker has a digital thermostat which is easy to change but to be honest I don't think that is the cause of your problem.
Check the keypad connection on the PCB (circuit board).
t could be either the keypad or PCB at fault and withou trying one or the other you'll not be able to determine the problem. My advise would be for you to contact your local parts supplier and ask them whether or not they can supply you a keypad to try with the option to send it back for a refund if it doesn't cure the problem.
A keypad can be trial fitted to the PCB, just unplug the old one, plug the new one in and turn on the power. There's no need to install the keypad to the spa, therefore you wont damage it in anyway.
If the keypad doesn't cure the problem, change the PCB.
Regards,
Ian.
http://hottub.synthasite.com
Posted on Apr 01, 2010
SOURCE: I have a coleman emerald
press program and then mode, it will display "0" and will be unlocked. u locked it by pressing program twice
Posted on Nov 07, 2010
SOURCE: Can't unlock jacuzzi hot tub control panel
control panel not working, cannot control or work control buttons, stays in econ mode all the time. Nothing else works.
Posted on Dec 22, 2010
The display panel on my hot tub shows a lock and none of the function keys respond when touched
didnt specify if you had a 4 8 or 10 button panel your unit is locked the only control that will work is temperature your owners manual has how to unlock it under side panel the following link is for an 8 button panel and the instructions are on page 6
http://qcaspas.com/media/pdf/Jewelp3-8Btn.pdf
Oct 28, 2015 | Qca Spas Jewel Series Topaz Plus Hot Tub
I recently switched some breaker around in my fuse box. There were a few 110's and 220's not being used. I deleted those to make some room to put a larger amp breaker for my hot tub that been sitting
Try for what ?
You removed breakers not needed or ones with little
on them, to make room for a larger 50 amp Hot Tub
Breaker,so you got your hot tub powered up
What is the question,seems you solved the issue
by making room for the new breaker !
Nov 21, 2014 | Electrical Supplies
Hot tub wont come on
What do you mean "Jump it"?
Check with a meter, ACROSS both hot wires to get a reading of 220-240 volts. do not test across 1 hot and the meter lead on ground! You probably are not getting proper voltage to the hot tub. Or you may have a burned system fuse normally 20-25-or 30 amp fuse, which is found within the control box of the spa.
Jan 06, 2013 | Balboa Instruments Duplex Digital Panel 2...
Will a flow switch stop the tub of any operation
Is the board getting power, is the control lighting up?
Do you see any error codes on the top side control?
Improper flow will give you an error code, caused by flow issues or a faulty flow switch. Make sure all gate valves are open and the water can flow freely.
If not then check your Hi Limit sensor. This is the overheat safety sensor if it fails the tub will not function at all.
Sep 23, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
I presssed lock on my hot tub and now nothing will workk
You have engaged the system lock by pressing the lock key on your control panel. You will now have to either enter a code or press certain keys in a certain sequence to unlock the system. If you still have the manual for your system you will want to lookup locking the system to see what the default way to unlock it; if you don't have the manual you will have to contact the place where you purchased the tub from and have them tell you how to unlock the system. You might want to try and power down the tub completely, wait at least 1-2 minutes, then turn it back on. It's possible that the system might reset itself and your control panel will unlock.
Feb 19, 2011 | Sport & Outdoor - Others
Nov 27, 2010 | Jacuzzi Pool & Spa
I have a coleman emerald 455 hot tub and I have managed to lock the electronic control panel. How do I unlock?
Nov 05, 2010 | Pool & Spa
Hot tub has power but nothing else works
MY control panel was replaced ,it cycles but, no lights ,no jets,no heat works..What's the problem .
Oct 01, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Pool & Spa Logo
254 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
