Question about Pioneer Audio Players & Recorders
Pioneer Elite VSX-60 volume will not stay at level chosen , it will slowly decrease on its own all the way down to 0db. This has just recently started to occur and is a real pain constantly adjusting the volume up after a few minutes.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Pioneer Master
  • 924 Answers
You have a bad Rotary Encoder or Display Microprocessor IC(computer inside you receiver) I wrote a very detailed seminar ,a VSX49TX, when I worked for Pioneer. If you are interested in having your VSX-60 repaired, please visit my website at audioserviceclinic.com. Thank you.
Posted on Jun 26, 2015
    Problem Solver:
  • 15 Answers
It's because it uses ama motorized potentiometer for the volume level, I think that its neccesary to change it
Posted on Nov 23, 2013
4 Suggested Answers
  • 4 Answers
SOURCE: Pioneer VSX-36TX popping and crackling during warm-up period
I have the exact same amplifier with what sounds like the exact same problem. I opened up the amplifier, and while it was powered on started tapping around until I heard the popping and crackling suddenly increase. I was using a piece of wood and the plastic part of a screw driver for this. The popping and crackling suddenly burst out onto all channels when I was tapping on the DSP board (encased in a metal enclosure to the very right of the amplifier).
I took off the metal enclosure (with the receiver turned off, of course :), and with the receiver on, and started tapping around the DSP board, and I found that the biggest crackling effect was achieved when I tapped on the Cirrus Logic CS493292-CL chip which does all the decoding and switching.
I detached and took out the DSP board and looked at it very carefully but of course couldn't find any bad connections. I tried resoldering all the feet of the Cirrus Logic chip and many many components all around to no avail.
Finally I tried applying pressure to the chip while the popping was going on, and it stopped. Further investigation revealed that bending the board around the chip produced the same effect.
For the life of me I couldn't figure out why bending the board eliminates the problem, but my solution was to put a piece of eraser wrapped in masking tape and taped to the Cirrus Logic chip, and two other pieces on the back of the board in such a way that when the metal enclosure was replaced onto the board, it put gentle but firm pressure onto the Cirrus Logic chip and at the same time bent the DSP board slightly.
It's been a few days without popping, clicking or static, but time will tell. Good luck!
Posted on Feb 05, 2009
  • 979 Answers
SOURCE: pioneer vsx-d307
You have a flashing "mute" on the display?...accordianman
Posted on Nov 26, 2007
  • 35 Answers
SOURCE: Pioneer Amp VSX-D409 Volume
I have a VSX D508 Looks just like the VSX D409. Had the same prob with the volume control when I bought it. I first tried the cleaner. Better than what it was but didn't compleatly solve the problem and before long it was getting worse again.
It does have a rotary encoder instead of the traditional varible restance volume control. I finally broke down and removed it from the board and lightly sanded the contacts with fine sandpaper.
This involves removing the whole face from the main board and chassis. Not that bad, a couple screws and some ribbon jumpers and latches and it's off.
Next carefully pull the volume control straight off the shaft, remove the nut under it and lay it face down on a soft surface. Remove the screws that hold the circuit board to the face and slowley seperate the too, you'll have to release some latches also to sepperate them.
If you replace the volume control with a new one or clean the old one you have to go this far because it's soldered to the front side of the board. Yes, it has to be de-soldered from the board.
This control was not designed to be dissassembled but I was able to carefully open it and remove the shaft to totaly expose the contacts for a complete even couple of passes with the sandpaper.
I did have to use some 5-minute opoxy when I put it back together because I couldnt get the metal tabs to close as tightly as they were before it was opened.
I soldered in the volume control, put it back together and it's worked perfectly ever since. I don't know how much pioneer wants for a new one but I can tell you they wanted $69 plus shipping for a new remote for my receiver. And with this style of volume control you might be at their mercy as far as finding one from another source that fits.
Posted on Apr 03, 2010
How come i can only adjust the volume levels on the center, surround sound left and right, and the sub, down but not up? is 0 max volume?
Some equipment use 0dB as the reference, and you can choose to decrease the volume from that point. If you need to "increase" beyond 0dB, you need to reduce volume on the main speakers so the volume is finally balanced between all speakers.
May 15, 2016 | Audio Players & Recorders
Pioneer VSX-60 Volume Decrease each 2 min
it's a somewhat common problem with that model. It needs a new cpu board.
Apr 21, 2014 | Pioneer Elite VSX-60 7.2 Channel Network...
Pioneer elite vsx 60
Most remote controlled volume pots are motorized. To be sure your remote isn't the culprit, set the volume and take the batteries out of the remote effectively killing it. If it still continues to fall off in volume, relocate the receiver to a different room to rule out environmental issues of it picking up a stray transmission from some other device. If all else fails take it to work if you can and see if it does it at a completely different location. If it still does it you'll have to take it to a shop for repair.
Oct 13, 2013 | Audio Players & Recorders
I have the following setup: AV Receiver: Pioneer
Very common problem with today's receivers. Receivers made today don't have a true preamp section in the amplifier and do not amplify the sound to the extent of an older receiver. I have large 15" front speakers on my system, and have stuck with my 15 year old receiver just because I know that a new receiver will not have the power to drive them well. Many of the newer receivers need to be turned up to 50-60% before you can even hear anything from the speakers.
Aug 08, 2013 | Pioneer Audio Players & Recorders
Hi ! I have a Pioneer AV receiver VSX-D710S and i have a problem with sound ! At the maxim volume (0db) the sound it's verry low an when i make volume ajustments i heard in speakers some knoking !...
The first thing you need to do is to disconnect all the speakers.
Then connect them one at a time and see if you get the correct volume on any of them.
If you don't get the correct volume on some of the speakers then it's those speakers that are faulty.
If you don't get the correct volume on any of the speakers then the fault is with the internal amplifier and you'd need to take it to get it repaired.
Jul 29, 2011 | Pioneer VSX-D710S Receiver
I HAVE A PIONEER VSX35 ELITE RECEIVER THAT HAS BEEN OVERLOADING. IT SEEMS TO NEED MORE VOLUME TO MAINTAIN NORMAL LEVELS. IT CYCLED OFF THEN CAME BACK ON TWICE. NOW IT ACKS LIKE THERE IS NO OWER, ONLY RED...
Having a live-and-kicking VSX-36TX receiver which I love, I feel for you. But the prices have come down dramatically since we bought them. I paid $1200 for mine new. If I needed to replace it I would go with a used one from eBay and consider searching specifically for one that uses the same remote but doesn't have one included. The price would be low.
Like this beasty, no remote for $250 delivered:
http://cgi.ebay.com/Pioneer-Receiver-VSX-1014TX-Multi-Channel-Receiver-/150581038944?pt=Receivers_Tuners&hash=item230f544f60
or this one with a remote for $232 delivered.
http://cgi.ebay.com/Pioneer-VSX-516-S-7-1-Channel-Home-Theater-Receiver-/250783994297?pt=Home_Theater_in_a_Box&hash=item3a63e411b9
Apr 11, 2011 | Pioneer VSX-36TX
On my Pioneer vsx-55txi, the protection circuit cuts in whenever I raise the volume to a reasonable level. If I sit 10 feet or more, the volume is too low. I don't like my music or movies loud, but this...
The protection circuit is enabling because the output transistors are 1. drawing too much current causing them to heat-up 2. the transistors are going out 3. the threshold level for the quiesce state is set too high and may need to be adjusted internally. Try to cool down the Unit and see if it occurs again.
Nov 28, 2010 | Pioneer VSX-55TXi 6.1 Channels Receiver
I want to connect a pair of Bose 901 speakers to the VSX and use them as my front speakers powered by a separate amplifier but can't find an appropriate pre-out from the VSX.......what analog VSX output...
It doesn't really have one. The DVR-Out (or any other available Line-Out) COULD provide a mixed-down analog stereo program but it won't be volume controllable from the VSX and it won't be Front-Channel specific. Sorry.
You would then connect the EQ between the chosen Line Out and the amp input. If you had a Pre-Our you would just run speaker assignment, levels, etc and have fun. With a Line Out feed you will have to ride herd on the 901 volume via its dedicated amp controls. Bummer. My older VSX-36TX allows me to have the right setup.
Nov 27, 2010 | Pioneer VSX-818V-K Receiver
My pioneer amp vsx d508 reads overload.what to do?
Sounds like a bad amplifier IC.
Unhook all speakers at the back of your pioneer. turn it on and turn down the volume. If it's no longer in overload you have a bad speaker or speaker wires touching somewhere.
If its still in overload it's prlobley a amp IC and will cost between $25-$60 just for the part if you can replace it yourself.
Dec 27, 2009 | Pioneer VSX-D508
Overload
Ok, how much is "a bit"? If you are operating your unit at the 50% or more level, your unit is working as it should, as DVD and CD players output more signal than other sources...accordianman
Nov 26, 2007 | Pioneer VSX-D307 Receiver
157 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
