Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
J deere 310 leaks between the hydraulic filters there is silonoid between them
  • 51 Answers
Wipe down and clean the filter, filter housing and hydralic lines, run your jd until you see hydraulic fluid, stop the machine and look to see where it originated from... If it's from the filter, change the filter, make sure the old oil rings are no stuck on the housing, and there's a o ring that comes on the new filter, pre lube the filter o-ring and install,,, if it the hydralic housing or pump, check for hair line cracks, check the threads on the filter head on the housing for cross threading, and last but not least and the greatest possibility... The hydraulic line connections to the filter housings and pump... The will most likely be the issue... Spray brake cleaner all over the connections to clean them run the machine and look to see which one is leaking... When replacing the hose connections, replace with a quick connect hose end to save on value time and efforts in the future.
Posted on Nov 18, 2013
2 Suggested Answers
harlan301
  • 205 Answers
SOURCE: john deer 310 g wont start after it sitts a day
if its turning over check your spark. if you have spark remove the air cleaner and spray some carburetor cleaner to see if it start than stops- let me know
Posted on Oct 14, 2009
How do I replace the lift lock lever (hydraulic) for the mower deck of my John Deere 310 Riding Mower?
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Sep 28, 2016 | John Deere Garden
Hydraulics 3130 john deere
hydraulic pump not working
filter to the pump blocked
valve stuck open
Sep 06, 2016 | John Deere Garden
Where do I add hydraulic fluid to a John Deere 310 B backhoe
There are several places for checking and adding fluid. What seems low, the bucket hydraulics, or the drive hydraulics (ie: tranaxle)
Jul 09, 2016 | John Deere Garden
How do I increase the hydraulic power in my 1985 john deere 1050. Speed of hydraulics is fine. Just changed oil and filter with no difference
Power in a hydraulic system is perceived as Pressure ! there for more power is more pressure , id use a pressure gauge plugged into a remote port , to test your pump . an 85 id bet sure has some wear to pump , pressure for that id suppose should be right about 1200 to 1500 psi at 1050 rpm , if its less than that you could have pump rebuilt or replaced
do ck all the simple things 1st , filter, belts, hoses ,leaks
Jun 23, 2015 | John Deere Garden
John Deere 310G that the hydraulics quit working
You just go to the link I attached I'm sure you will get the solution of your problem.
John Deere 310G
May 29, 2017 | John Deere Garden
Hydraulic system overheating
check all hydraulic filters and check hydraulic valves. Filters is maybe not good or old, hydraulic valves is damaged or soiled. If your model hawe oil cooler check is it clean out and in!
Apr 04, 2011 | John Ertl 132 John Deere 648g Log Skidder
Transmission oil foaming and pushing out of dipstick tube during normal transmission operation. Transmission has been serviced - oil & filter replaced with OEM components.
Has the suction filter been serviced? And what transmission oil have you used? Is it John Deere hydraulic oil or hydraulic/transmission oil? Does the tractor have a loader?
Dec 10, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
95 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
